- Posted on
Tue Sep 12, 2017 2:46 pm
Different Computers
offline
Another example of what's similar to above, at least in terms of the cause, if not the generated errors:
- Code: Select all
Nanoleaf Error StandardError detected communicating with NANOLEAF lamp:
Nanoleaf Error Traceback (most recent call last):
Nanoleaf Error File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/sendReceiveMessages.py", line 105, in run
Nanoleaf Error success, statusMsg, self.globals['nl'][nanoleafDevId]["auroraInfo"] = self.globals['nl'][nanoleafDevId]["aurora"].info
Nanoleaf Error File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/nanoleaf/aurora.py", line 84, in info
Nanoleaf Error return self.__get()
Nanoleaf Error File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/nanoleaf/aurora.py", line 37, in __get
Nanoleaf Error errorMsg = e.args[0].reason.message.split('>: ')[1]
Nanoleaf Error AttributeError: 'ProtocolError' object has no attribute 'reason'
Once again, powering off the Aurora, turning it back on, then reloading the plugin and all is working.
