New version error
Thu Oct 05, 2023 1:43 pm
Different Computers offline
New version error
I wanted to test this in 2022.2 before making the jump.
   Loading plugin "Nanoleaf 2022.0.2" using API v3.0
   Starting plugin "Nanoleaf 2022.0.2" (pid 47773)
   Nanoleaf Error                  Error in plugin execution InitializeMain:
  File "plugin.py", line 21, in <module>
type: No module named 'nanoleafapi.discover_nanoleaf'
   Stopping plugin "Nanoleaf 2022.0.2" (pid 47773)
   Stopped plugin "Nanoleaf 2022.0.2"
Is it incompatible with 2022.2?
Thu Oct 05, 2023 2:09 pm
Re: New version error
I have just downloaded and re-installed it from the Indigo Plugin Store and it is starting up OK on Indigo 2023.1 (it also worked on Indigo 2022.2).
Maybe the download got corrupted as the nanoleafapi.discover_nanoleaf is there in the plugin in my system.
As a first step, can I suggest that you download it again and try and install it. If it still goes wrong we will have to dig deeper.
Fri Oct 06, 2023 10:27 am
Redownloaded. Exact same error:
 Stopped plugin Nanoleaf
   Upgrading plugin Nanoleaf to newer version 2022.0.2 (previous version moved to trash)
   Starting plugin "Nanoleaf 2022.0.2" (pid 59971)
   Stopping plugin "Nanoleaf 2022.0.2" (pid 59971)
Fri Oct 06, 2023 11:33 am
I don't understand that :?
I have created a new pre-release version and uploaded it to Github: Nanoleaf Control Version 2022.0.3
I have downloaded it and successfully installed it on my Indigo system.
Please try that and let me know what happens. :)
Fri Oct 06, 2023 12:30 pm
No joy.
Oct 6, 2023 at 2:28:37 PM
   Stopping plugin Nanoleaf (pid 60001)
   Nanoleaf                        Autolog 'Nanoleaf V1 Controller' Plugin shutdown requested
   Nanoleaf                        Stopping 'Canvas'
   Nanoleaf                        Stopping 'Indicator'
   Nanoleaf                        Stopping 'Wall Art'
   Nanoleaf                        Autolog 'Nanoleaf V1 Controller' Plugin shutdown complete
   Upgrading plugin Nanoleaf to newer version 2022.0.3 (previous version moved to trash)
   Loading plugin "Nanoleaf 2022.0.3" using API v3.0
   Starting plugin "Nanoleaf 2022.0.3" (pid 61865)
   Stopping plugin "Nanoleaf 2022.0.3" (pid 61865)
is it possible that changes I may have made to my python environment outside of Indigo may have affected this? I messed around with the Nanoleaf python library months ago.
Fri Oct 06, 2023 1:28 pm
No joy.
OK, I have had a few other code-related things suggested to me by @Jay.
I will incorporate those into a new version that I will get to you tomorrow at some point (UK time).
I guess that is possible given that it works on my system and doesn't work on yours.
It is something we could pursue if the next version doesn't work for you.
Fri Oct 06, 2023 2:00 pm
If you installed the nanoleafapi module using a pip which is pointing to the Indigo installed python, then that might be the problem.
Fri Oct 06, 2023 8:30 pm
THat’s pretty likely. I’ll figure out how to uninstall.
Sun Oct 08, 2023 9:04 am
pip uninstall nanoleafapi
fixed the problem.
Starting plugin "Nanoleaf 2022.0.3" (pid 89513)
   Nanoleaf                        Logging to Indigo Event Log at the 'Info' level
   Nanoleaf                        Logging to Plugin Event Log at the 'Info' level
   Nanoleaf                        Host IP Address overridden and specified as: '192.168.0.150'
   Started plugin "Nanoleaf 2022.0.3"
   Nanoleaf                        Initialising to poll at 300 second intervals
   Nanoleaf                        Autolog 'Nanoleaf Controller' initialization complete
   Nanoleaf                        Discovering nanoleaf aurora, canvas and shape devices on network - this should take ~30.0 seconds . . .
   Nanoleaf                        Starting  'Canvas' . . .
   Nanoleaf                        . . . Started 'Canvas'
   Nanoleaf                        Starting  'Indicator' . . .
   Nanoleaf                        . . . Started 'Indicator'
   Nanoleaf                        Starting  'Wall Art' . . .
   Nanoleaf                        . . . Started 'Wall Art'
running without error!
Thanks very much. This means I am now ready for Indigo 2022.3, as the only two plugins left on old python are Plex and EPS Device Extensions, neither of which I use much and neither of which are likely to be updated.
Tue Nov 07, 2023 10:09 am
joeaug offline
Im having the exact same problem. I'm not sure I understand where the previous poster typed in that "uninstall" command or what it did. I'm only now learning about python and have a long road ahead of me, so pardon my ignorance.
Tue Nov 07, 2023 10:35 am
Open a terminal window and paste this command in:
pip3.10 uninstall nanoleafapi
If it was installed outside the plugin, that will remove it. If not, the command will just fail (which is fine, no harm done).
Tue Nov 07, 2023 11:12 am
joeaug offline
Thanks for the clarification. I executed the command and the api was not there, so no harm (or anything) done. The problem persists though so any additional thoughts?
Nov 7, 2023 at 12:07:41 PM
Enabling plugin "Nanoleaf 2022.0.2" using API v3.0
Starting plugin "Nanoleaf 2022.0.2" (pid 3903)
File "plugin.py", line 20, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/Plugins/nanoleaf.indigoPlugin/Contents/Server Plugin/nanoleafapi/nanoleaf.py", line 12, in <module>
type: No module named 'sseclient'
Stopping plugin "Nanoleaf 2022.0.2" (pid 3903)
Tue Nov 07, 2023 11:59 am
joeaug offline
UPDATE: I have tried installing the pre-release version as the developed suggested another user do, but this still gives the same problem.
Tue Nov 07, 2023 12:58 pm
Try:
pip3 install sseclient
Tue Nov 07, 2023 1:35 pm
joeaug offline
Thanks Jon, I had just come to the same conclusion ;-)
Thanks again!
