What is the URL for your cameras?
Different Computers wrote:I just downgraded to 1.5.0 and it instantly started working again.
Can you turn off all but one camera and then turn on logging for a bit and send time the output?
Also, try turning on one camera at a time to see if it is an issue with a specific camera.
Can you send a list of the files created in the base folder. I want to make sure it is creating all of the needed files correctly.
Archive (folder) (this is empty. I have no archive actions)
Cam Breezeway (folder)
20-some constantly changing images from the appropriate cam
Cam C2 (Folder)
contents as for the Cam Breezeway folder
Cam Cherry (folder)
Cam FrontYard (Folder)
Security Camera Debug Starting main loop
Security Camera Debug Starting Carousel
Security Camera Debug Starting Master Image
Security Camera Debug Unable to run Master Image
Security Camera Debug Starting Device Loop
Security Camera Debug Starting Device Loop for:Cam Breezeway
Security Camera Debug Set State Timers
Security Camera Debug Get Camera Image
Security Camera Debug Check Motion
Security Camera Debug Starting Device Loop for:Cam C2
Security Camera Debug Starting Device Loop for:Cam Cherry
Security Camera Debug Starting Device Loop for:Cam FrontYard
Security Camera Error Error in plugin execution ExecuteAction:
File "plugin.py", line 670, in MasterCamera
File "plugin.py", line 314, in MasterImage
File "plugin.py", line 45, in getSortedDir
OSError: (2, 'No such file or directory', '/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/video/0')
File "plugin.py", line 315, in MasterImage
IndexError: list index out of range
