Security Camera Plugin
Tue Dec 27, 2016 6:58 pm
johnpolasek offline
Re: Security Camera Plugin
bkmar1192 wrote:
Download and upgrade to 1.3.10. I am working on a version with auto update but don't have it ready yet.
-Bert
Updated to 1.4.1. and did a new install... Got:
    Dec 27, 2016, 6:51:51 PM
    Upgrading plugin Security Camera to newer version 1.4.1 (previous version moved to trash)
    Loading plugin "Security Camera 1.4.1"
    Starting plugin "Security Camera 1.4.1" (pid 27115)
    Security Camera Error Error in plugin execution InitializeMain:
    File "plugin.py", line 22, in <module>
    ImportError: No module named PIL
    Stopping plugin "Security Camera 1.4.1" (pid 27115)
    Stopped plugin "Security Camera 1.4.1"
Is there another module I need to install instead of ImageMagic?
Tue Dec 27, 2016 10:19 pm
bkmar1192 offline
johnpolasek wrote:
-Bert
Yes - see the updated install docs. It uses the python PIL module. Instructions are in the readme.
Thu Dec 29, 2016 5:29 am
johnpolasek offline
Installed Pip, then Pillow (with insecure platform warning). Now when I enable the plugin, I get:
    Dec 29, 2016, 5:24:59 AM
    Enabling plugin "Security Camera 1.4.1"
    Starting plugin "Security Camera 1.4.1" (pid 68782)
    Started plugin "Security Camera 1.4.1"
    Security Camera Checking for update
    Security Camera Running the current version of Security Camera
    Security Camera Error Error in plugin execution runConcurrentThread:
    File "plugin.py", line 496, in runConcurrentThread
    File "plugin.py", line 278, in MasterImage
    KeyError: 'key not found in database'
    Security Camera Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Do I need to restart the server? I'd rather not if I don't have to because it's running other stuff as well.
Thu Dec 29, 2016 11:06 am
bkmar1192 offline
No need to restart the server. I'll do some investigative work and let you know.
Sat Dec 31, 2016 11:17 am
bkmar1192 offline
Re: Security Camera Plugin - version 1.4.2
Just released new version with fix for the above issue. Go to the Security Camera plugin menu and select Update Plugin, then accept the upgrade on your server.
Let me know if you have other issues.
-Bert
Sat Dec 31, 2016 12:41 pm
Different Computers offline
Any chance this addresses the runaway CPU usage issue too?
Sat Dec 31, 2016 1:02 pm
jalves offline
Just getting around to trying this out and apparently I'm not doing something correctly.
I'm working with a Foscam 9821v2 to start off with and the URL I'm using is
http://192.168.0.4:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=name&pwd=password
which works properly when I past it directly into a browser window. However, the plugin produces the following error repeatedly:
  File "plugin.py", line 487, in runConcurrentThread
IndexError: list index out of range
  File "plugin.py", line 498, in runConcurrentThread
Looking forward to getting this working properly so I can eliminate a couple of other plugins and scripts. Appreciate your work!
Jeff
Sat Dec 31, 2016 6:55 pm
bkmar1192 offline
It should. Using the python library is a bit more CPU intensive out of the gate. However, the revised code does a bit better at tracking and managing threads.
I am consistently around 30% CPU and 10 threads with 6 cameras.
Sat Dec 31, 2016 6:56 pm
bkmar1192 offline
What version are you running? Try doing an update (from the plugin menu). I did an update this morning that should have resolved this issue.
Sat Dec 31, 2016 7:43 pm
jalves offline
Pretty sure it was the latest version. I made a point to go look for that when I decided to give it a try today. Will need to verify that tomorrow....
Jeff
Sun Jan 01, 2017 7:13 am
jalves offline
Its version 1.4.2. When starting the plugin it verifies that I'm running the latest version.
I've restarted it several times, also have re-saved the camera. Same result.
Jeff
Sun Jan 01, 2017 11:42 am
bkmar1192 offline
Dang thought I fixed that. When the plugin first runs there is no master image set and I think that is what is causing the error.
I'll take another look.
Sun Jan 01, 2017 12:06 pm
bkmar1192 offline
Ok - update to 1.4.3 and try it again.
Sun Jan 01, 2017 1:53 pm
jalves offline
No joy.
Jan 1, 2017, 2:49:29 PM
   Upgrading plugin Security Camera to newer version 1.4.3 (previous version moved to trash)
   Loading plugin "Security Camera 1.4.3"
   Starting plugin "Security Camera 1.4.3" (pid 81806)
   Started plugin "Security Camera 1.4.3"
Jan 1, 2017, 2:50:04 PM
Jan 1, 2017, 2:50:20 PM
   Disabling plugin "Security Camera 1.4.3"
   Stopping plugin "Security Camera 1.4.3" (pid 81806)
   Stopped plugin "Security Camera 1.4.3"
I wonder if I messed up on the original installation. This was going to be installed in the ...PerceptiveAutomaiton/Indigo 6 library directory. I changed that to Indigo 7. Might that be the issue?
Jeff
Sun Jan 01, 2017 7:22 pm
johnpolasek offline
Same issue when I just updated to 1.4.3...
Page 4 of 13 1, 2, 3, 4, 5, 6, 7 ... 13
