Ok, so I'm finally getting back to this issue and have still not solved it.
In the Plugin's debug, I can see a field called "Device State". There are only 3 states for "Device State":
- Schedule
- TempHold
- PermHold
Here is a sample from the debug log file and I've highlighted in red the field I'm identifying:
Honeywell Total Connect Comfort Thermostat Debug Getting data for thermostatId: 4342076
Honeywell Total Connect Comfort Thermostat Debug ThermostatID: 4342076
Honeywell Total Connect Comfort Thermostat Debug DeviceName: THERMOSTAT
Honeywell Total Connect Comfort Thermostat Debug UserDefinedDeviceName: Main Level
Honeywell Total Connect Comfort Thermostat Debug state: 3
Honeywell Total Connect Comfort Thermostat Debug Device Name: THERMOSTAT
Honeywell Total Connect Comfort Thermostat Debug ***Device SystemSwitch: Cool
Device State: TempHold Honeywell Total Connect Comfort Thermostat Debug Updating Device: TMain Level, State: temperatureInput1, Value: 74.0000
These 3 states reflect that operating status of the thermostat and I need to insert the current operating status (Device State) into an Indigo variable.
I cannot find in Indigo a field that allows me to use "Device State" as a condition or as a source for plugging the state into an Indigo variable. The list of fields available is found in the attachment
What am I missing in my quest to get this to work?
- This is the list of fields to choose from in Indigo...none of which is "Device State"
- Screen Shot 2020-08-08 at 8.05.04 PM.jpg (202.76 KiB) Viewed 1678 times
