Plugin update errors in log
Sat May 19, 2018 12:55 pm
dz1rfj offline
Hi - Love the ring plugin! I have these odd entries in my log when I try to check for a ring update. I have no Mr. Slim thermostat , and I have tried to uninstall and reinstall the plugin from the new Github site.
Any ideas whee Mr. Slim is coming from, and why only when updating the ring plugin ?
Ring Doorbell Debug Initializing Ring device: Ring_UpperGate
Ring Doorbell Checking for updates...
Ring Doorbell Debug Plugin version detected: 0.1.27
Ring Doorbell Debug Current version is: 0.1.27
Ring Doorbell Debug Getting latest release from mpoulson/Indigo-Ring...
Ring Doorbell Debug GET /repos/mpoulson/Indigo-Ring/releases/latest
Ring Doorbell Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 153, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/MrSlim.indigoPlugin/Contents/Server Plugin/ghpu.py", line 88, in checkForUpdate
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/MrSlim.indigoPlugin/Contents/Server Plugin/ghpu.py", line 175, in _prepareForUpdate
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/MrSlim.indigoPlugin/Contents/Server Plugin/ghpu.py", line 97, in getUpdate
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/MrSlim.indigoPlugin/Contents/Server Plugin/ghpu.py", line 117, in getLatestRelease
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/MrSlim.indigoPlugin/Contents/Server Plugin/ghpu.py", line 145, in _GET
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1053, in request
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1093, in _send_request
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1049, in endheaders
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 893, in _send_output
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 855, in send
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1274, in connect
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 352, in wrap_socket
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 579, in __init__
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 808, in do_handshake
SSLError: [SSL: TLSV1_ALERT_PROTOCOL_VERSION] tlsv1 alert protocol version (_ssl.c:590)
Ring Doorbell Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
-Brian
Sat May 19, 2018 2:26 pm
Re: Plugin update errors in log
Sun Jun 03, 2018 1:35 pm
mpoulson offline
Version 0.1.28 should resolve this
Mon Jun 04, 2018 4:57 am
dz1rfj offline
8) , many thanks, I’ll check it out tonight. Thanks for the awesome plugin!
-Brian
Wed Dec 12, 2018 1:52 pm
mgolden50 offline
Hi Mike,
I keep getting this error in the log:
2:15:45 PM
Ring Doorbell Error Reached max retry attempts. Won't Refresh from Server. !
Ring Doorbell Error You may need to contact Mike for support. Please post a message at http://forums.indigodomo.com/viewforum.php?f=235
Any help much appreciated.
Mike
