Download Issue
Wed Mar 14, 2018 2:23 pm
BruceP offline
Download Issue
I downloaded the Ring plugin from the Store. I am now getting errors with the Mr. Slim listed in the error list. Not sure what is happening.
File "plugin.py", line 153, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/MrSlim.indigoPlugin/Contents/Server Plugin/ghpu.py", line 88, in checkForUpdate
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/MrSlim.indigoPlugin/Contents/Server Plugin/ghpu.py", line 175, in _prepareForUpdate
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/MrSlim.indigoPlugin/Contents/Server Plugin/ghpu.py", line 97, in getUpdate
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/MrSlim.indigoPlugin/Contents/Server Plugin/ghpu.py", line 117, in getLatestRelease
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/MrSlim.indigoPlugin/Contents/Server Plugin/ghpu.py", line 145, in _GET
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1053, in request
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1093, in _send_request
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1049, in endheaders
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 893, in _send_output
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 855, in send
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1274, in connect
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 352, in wrap_socket
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 579, in __init__
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 808, in do_handshake
SSLError: [SSL: TLSV1_ALERT_PROTOCOL_VERSION] tlsv1 alert protocol version (_ssl.c:590)
Wed Mar 14, 2018 2:31 pm
Re: Download Issue
It's not a problem with the Ring plugin, it's a problem with the MrSlim plugin.
Wed Mar 14, 2018 2:46 pm
Colorado4Wheeler offline
Re: Download Issue
And on top of that it's also the much discussed SSL issue with Git that a lot of devs used to keep their plugins updated.
Fri Mar 16, 2018 4:54 am
BruceP offline
Re: Download Issue
Yes there is obviously an issue with Mr. Slim, but I downloaded the Ring plug-in. I also tried an earlier version from another site and same issue. So I am missing something here on my end or there is an issue with the plug-in itself.
Fri Mar 16, 2018 5:49 am
Re: Download Issue
I don't understand. The log excerpt you show is only for MrSlim. If there's a problem with Ring, show the log for it.
Mon Mar 19, 2018 5:47 am
BruceP offline
Re: Download Issue
What I reported IS FROM the Ring download.
I go to plugins, select Ring Doorbell, Enable, then this
Mar 19, 2018, 7:46:18 AM
Enabling plugin "Ring Doorbell 0.1.25"
Starting plugin "Ring Doorbell 0.1.25" (pid 3666)
Started plugin "Ring Doorbell 0.1.25"
Ring Doorbell Number of devices found: 1
Ring Doorbell Front Door (id: 5780042)
Ring Doorbell Checking for updates...
Ring Doorbell Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 149, in runConcurrentThread
Ring Doorbell Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Mar 19, 2018, 7:46:41 AM
Disabling plugin "Ring Doorbell 0.1.25"
Stopping plugin "Ring Doorbell 0.1.25" (pid 3666)
Stopped plugin "Ring Doorbell 0.1.25"
Mon Mar 19, 2018 6:13 am
Re: Download Issue
Delete that copy of the plugin and get the current one (0.1.27) from the plugin store.
Mon Mar 19, 2018 6:26 am
Re: Download Issue
FYI I’m getting the same error with mine. did as per previous instructions but no joy. running on macOS 10.11.
Mon Mar 19, 2018 6:38 am
Re: Download Issue
I see the problem. The plugin has a ghpu.pyc file (compiled Python), but no ghpu.py file (Python source). And the compiled version was for the MrSlim plugin, so it has the wrong pathname in it.
Until the developer can fix it, set the update frequency in the plugin prefs to 0. If you can't do it in the Indigo UI, edit the preferences file for the plugin directly.
   <updateFrequency type="string">0</updateFrequency>
Mon Mar 19, 2018 12:36 pm
BruceP offline
Re: Download Issue
Thank you for the reply, but your explanation as a little above my pay grade, but I got it. Will wait until corrected.
Thanks again
