Ring Doorbell Plugin
Wed Dec 28, 2016 5:20 pm
ELWOOD offline
Re: Ring Doorbell Plugin
I have a pro version and it works fine.
Will the plugin eventually be able to view the recorded video, or a least a still jpeg?
Wed Dec 28, 2016 5:36 pm
mpoulson offline
What would be the use case where you would use the image or video?
The only thing I can think of would be maybe saving the video/image then using the Twillio plugin to send it over MMS.
Thu Dec 29, 2016 3:52 pm
mpoulson offline
Just pushed 0.1.5 update out
Includes:
-Fix for issue where Rescan for devices was missing
-Adds support for Sending usage telemetry - Default is Opt-in
Thu Dec 29, 2016 4:12 pm
Could you add a trigger state for motion or press? At the moment it just does if becomes X but of course if it were that state before the trigger wouldn't action.
Thu Dec 29, 2016 4:15 pm
mpoulson offline
Sure. I will get it out today.
Thu Dec 29, 2016 10:34 pm
mpoulson offline
I just added two additional states for the device you can trigger on.
lastButtonPressTime and lastMotionTime
Fri Dec 30, 2016 1:57 pm
roquej online
Again, thank you for the plugin, but running into a few issues still.
When I load the plugin, I get:
Ring Doorbell Number of devices found: 2
Ring Doorbell Front Door (id: 560077)
Ring Doorbell Front Gate (id: 1535374)
which is correct.
I then proceed to define the first Ring device, Front Gate. No error in the log. However, when I try to go back and define the second Ring device, I get as soon as the dialog opens:
Ring Doorbell Error Error in plugin execution GetUiDynamicList:
File "plugin.py", line 210, in doorbellList
KeyError: key ringId not found in dict
After this, nothing works.
Suggestions?
JP
Fri Dec 30, 2016 3:03 pm
mpoulson offline
Pushed 0.1.8. Should be happier with >1 device now. A few typos. Because I don't have more than one device I had to do some tweaks to simulate that I did.
Fri Dec 30, 2016 3:07 pm
roquej online
That did it!
Thank you!
JP
Sat Dec 31, 2016 12:02 pm
ryanbuckner offline
The Ring Doorbell plugin doesn't appears to play well will the Nest Plugin and the Fing plugin for my setup. After installing the Ring plugin, I started seeing this contention.
Dec 31, 2016, 8:02:04 AM
   NEST Home Error                 Error in plugin execution runConcurrentThread:
  File "plugin.py", line 1942, in runConcurrentThread
StandardError: ServerCommunicationError -- timeout waiting for response
   NEST Home Error                 plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
   Ring Doorbell Error             Error in plugin execution runConcurrentThread:
  File "plugin.py", line 108, in runConcurrentThread
   Ring Doorbell Error             plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
   Script                          Looks like no sleepover tonight!
   Schedule                        Determine Guest Mode (delayed action)
Dec 31, 2016, 8:03:08 AM
   fingscan                        in Line '5979' has error='expected a character buffer object'
   fingscan                        -2  can not update variable ipDevsLastUpdate
  restarting fingscan
 exception code: ServerCommunicationError -- timeout waiting for response
   Reloading plugin "fingscan 7.22.2"
   Stopping plugin "fingscan 7.22.2" (pid 84897)
   Stopped plugin "fingscan 7.22.2"
   Starting plugin "fingscan 7.22.2" (pid 28182)
   Started plugin "fingscan 7.22.2"
Sat Dec 31, 2016 1:42 pm
mpoulson offline
Does it only happen when the Ring plugin is enabled? Are you using the newest version?
I use fingscan on my network with the ring doorbell without issues.
Sat Dec 31, 2016 2:47 pm
ryanbuckner offline
I just upgraded to the newest version so we'll see, Confirmed, it only happens when Ring is enabled.
Sat Dec 31, 2016 3:21 pm
mpoulson offline
I just pushed 0.1.9 which has a few tweaks to error handling and adds a new option to stop processing if a Max number of consecutive errors are reached.
Sun Jan 01, 2017 5:53 pm
mpoulson offline
I have pushed version 0.1.10 that now adds a new device value called 'recordingUrl' This is the URL for the Video Recording of the most recent event. This requires a Cloud Recording subscription.
Mon Jan 02, 2017 8:39 am
Woetjes offline
The recordingUrl value remains empty here and it's generating an error message when running a script that includes the ring device:
"Ring Doorbell Error             [Mon Jan  2 14:44:06 2017] No value found for device: Buiten: Voordeur - Deurbel, field: recordingUrl"
Any idea? (I have the Cloud Recording Subscription)
