Display Battery Level for custom devices
Tue May 12, 2020 9:15 pm
jheddings offline
Posting this in case anyone can help for a future release...
Is there a way to use the built in
batteryLevel
device state for custom devices? When I try to use that in this plugin, the device state is hidden and no meter shows on the UI. I'm currently using a generic
level
state, but it would be nice to build on the known states where possible.
-jh
Wed May 13, 2020 5:21 am
Re: Display Battery Level for custom devices
For it to show in the UI, in your device definition you need:
            <Field id="SupportsBatteryLevel" type="checkbox" defaultValue="false">
                <Label>Device reports battery status:</Label>
            </Field>
If the custom device always has a battery level, then just set that to True and hide it in the Devices.xml.
         <Field id="SupportsBatteryLevel" type="checkbox" defaultValue="true" hidden="true" />
Wed May 13, 2020 8:26 am
jheddings offline
Works like a charm, thanks! I've kept the legacy state for compatibility with existing devices. Any new Battery devices will display the battery indicator. I'll make note of this when I do a new release.
