UnicodeEncodeError: 'ascii' codec can't encode characters
Fri Dec 30, 2016 9:34 am
yassi offline
HI jheddings,
I have to write here, because the other subforums are locked.
It seems so, the plugin has an issue with the "umlauts" characters when in the title or in the message field:
Prowl Error                     Error in plugin execution ExecuteAction:
  File "plugin.py", line 97, in notify
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib.py", line 1347, in urlencode
UnicodeEncodeError: 'ascii' codec can't encode characters in position 0-5: ordinal not in range(128)
Can you have a look please, when you have the time?
Yassi
Bildschirmfoto 2016-12-30 um 16.34.04.png (142.89 KiB) Viewed 3344 times
Fri Dec 30, 2016 10:02 pm
jheddings offline
Re: UnicodeEncodeError: 'ascii' codec can't encode character
Yikes... I will definitely try that out and get back to you with a fix to test soon. I'm hoping it is a quick fix based on the encoding I'm using in the plugin. Be back to you shortly.
Sat Dec 31, 2016 4:32 am
yassi offline
Ok, thanks for looking into it!
Yassi
Sat Dec 31, 2016 9:25 am
jheddings offline
I have a version ready for you to test (download link below)... I was able to reproduce the issue on my end and this seems to take care of it. Please let me know if it resolves the problem for you as well. If you confirm that it fixes the issue, I'll release the new version after running a few more tests.
NOTE this (and all future) version only works with Indigo 7.
Download Here
Sat Dec 31, 2016 10:55 am
yassi offline
Great!
It's working, was able to send "umlauts" in the title as well in the message body!
Thank you very much!!!
Yassi
