- Posted on
Tue Apr 02, 2024 12:59 pm
Different Computers
offline
OK, you're right, it is a lot. But here it is. I've redacted the IP addresses and serial numbers and installer password.
Surprised me at first, but some of the lines in the code section that follows are *very* long before the line break. scroll right.
- Code: Select all
Enphase Envoy Plugin Checking endpoints.
Enphase Envoy Plugin Checking all possible Endpoints...
Enphase Envoy Plugin Pausing usual updates for 3 minutes
Enphase Envoy Plugin Installer Password:
REDACTED
Enphase Envoy Plugin Trying Endpoint:https://REDACTED IP ADDRESS/ivp/pdm/energy
Enphase Envoy Plugin Failed, Response Code 401
Enphase Envoy Plugin Trying Endpoint:https://REDACTED IP ADDRESS/ivp/pdm/production
Enphase Envoy Plugin Trying Endpoint:https://REDACTED IP ADDRESS/production.json
Enphase Envoy Plugin Success: https://REDACTED IP ADDRESS/production.json
Enphase Envoy Plugin Response: {'production': [{'type': 'inverters', 'activeCount': 36, 'readingTime': 1712083367, 'wNow': 1352, 'whLifetime': 182386}, {'type': 'eim', 'activeCount': 1, 'measurementType': 'production', 'readingTime': 1712083426, 'wNow': 1220.784, 'whLifetime': 177982.741, 'varhLeadLifetime': 508.159, 'varhLagLifetime': 89214.81, 'vahLifetime': 257606.074, 'rmsCurrent': 11.971, 'rmsVoltage': 249.921, 'reactPwr': 713.973, 'apprntPwr': 1495.84, 'pwrFactor': 0.81, 'whToday': 6261.741, 'whLastSevenDays': 171799.741, 'vahToday': 15251.074, 'varhLeadToday': 1.159, 'varhLagToday': 11419.81}], 'consumption': [{'type': 'eim', 'activeCount': 1, 'measurementType': 'total-consumption', 'readingTime': 1712083426, 'wNow': 1128.013, 'whLifetime': 140352.743, 'varhLeadLifetime': 88942.767, 'varhLagLifetime': -69936.0, 'vahLifetime': 302759.309, 'rmsCurrent': 12.024, 'rmsVoltage': 250.028, 'reactPwr': -210.902, 'apprntPwr': 1501.777, 'pwrFactor': 0.75, 'whToday': 13586.743, 'whLastSevenDays': 1540.743, 'vahToday': 19979.309, 'varhLeadToday': 13812.767, 'varhLagToday': 0.0}, {'type': 'eim', 'activeCount': 1, 'measurementType': 'net-consumption', 'readingTime': 1712083426, 'wNow': -92.771, 'whLifetime': -37565.89, 'varhLeadLifetime': 89450.925, 'varhLagLifetime': 19278.81, 'vahLifetime': 302759.309, 'rmsCurrent': 0.053, 'rmsVoltage': 250.028, 'reactPwr': -924.875, 'apprntPwr': 5.246, 'pwrFactor': -1.0, 'whToday': 0, 'whLastSevenDays': 0, 'vahToday': 0, 'varhLeadToday': 0, 'varhLagToday': 0}], 'storage': [{'type': 'acb', 'activeCount': 0, 'readingTime': 0, 'wNow': 0, 'whNow': 0, 'state': 'idle'}]}
Enphase Envoy Plugin Response: {'production': [{'type': 'inverters', 'activeCount': 36, 'readingTime': 1712083367, 'wNow': 1352, 'whLifetime': 182386}, {'type': 'eim', 'activeCount': 1, 'measurementType': 'production', 'readingTime': 1712083429, 'wNow': 1224.715, 'whLifetime': 177983.834, 'varhLeadLifetime': 508.159, 'varhLagLifetime': 89215.457, 'vahLifetime': 257607.415, 'rmsCurrent': 12.06, 'rmsVoltage': 249.927, 'reactPwr': 724.127, 'apprntPwr': 1503.547, 'pwrFactor': 0.82, 'whToday': 6262.834, 'whLastSevenDays': 171800.834, 'vahToday': 15252.415, 'varhLeadToday': 1.159, 'varhLagToday': 11420.457}], 'consumption': [{'type': 'eim', 'activeCount': 1, 'measurementType': 'total-consumption', 'readingTime': 1712083429, 'wNow': 1134.316, 'whLifetime': 140353.753, 'varhLeadLifetime': 88943.599, 'varhLagLifetime': -69936.647, 'vahLifetime': 302760.495, 'rmsCurrent': 12.121, 'rmsVoltage': 250.002, 'reactPwr': -212.125, 'apprntPwr': 1513.986, 'pwrFactor': 0.76, 'whToday': 13587.753, 'whLastSevenDays': 1541.753, 'vahToday': 19980.495, 'varhLeadToday': 13813.599, 'varhLagToday': 0.0}, {'type': 'eim', 'activeCount': 1, 'measurementType': 'net-consumption', 'readingTime': 1712083429, 'wNow': -90.399, 'whLifetime': -37565.974, 'varhLeadLifetime': 89451.758, 'varhLagLifetime': 19278.81, 'vahLifetime': 302760.495, 'rmsCurrent': 0.061, 'rmsVoltage': 250.002, 'reactPwr': -936.252, 'apprntPwr': 6.474, 'pwrFactor': -1.0, 'whToday': 0, 'whLastSevenDays': 0, 'vahToday': 0, 'varhLeadToday': 0, 'varhLagToday': 0}], 'storage': [{'type': 'acb', 'activeCount': 0, 'readingTime': 0, 'wNow': 0, 'whNow': 0, 'state': 'idle'}]}
Enphase Envoy Plugin Trying Endpoint:https://REDACTED IP ADDRESS/inventory.json
Enphase Envoy Plugin Success: https://REDACTED IP ADDRESS/inventory.json
Enphase Envoy Plugin Response: [{'type': 'PCU', 'devices': [{'part_num': '800-01375-r02', 'installed': '1711547458', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083216', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547458', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627390225, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547462', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083217', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547462', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627390481, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547470', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083218', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547470', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627390737, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547475', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083246', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547475', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627390993, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547491', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083219', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547491', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627391249, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547495', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083126', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547495', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627391505, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547499', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083247', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547499', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627391761, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547503', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083366', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547503', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627392017, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547508', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083220', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547508', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627392273, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547512', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083127', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547512', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627392529, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547516', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083157', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547516', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627392785, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547520', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083128', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547520', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627393041, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547526', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083249', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547526', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627393297, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547530', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083158', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547530', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627393553, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547533', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083158', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547533', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627393809, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547536', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083250', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547536', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627394065, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547543', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083159', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547543', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627394321, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547547', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083221', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547547', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627394577, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547550', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083222', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547550', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627394833, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547554', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083223', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547554', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627395089, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547561', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083224', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547561', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627395345, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547564', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083187', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547564', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627395601, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547568', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083251', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547568', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627395857, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547572', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083252', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547572', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627396113, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547579', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083188', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547579', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627396369, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547582', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083252', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547582', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627396625, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547586', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083225', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547586', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627396881, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547590', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083253', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547590', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627397137, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547596', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083189', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547596', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627397393, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547600', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083254', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547600', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627397649, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547604', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083255', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547604', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627397905, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547608', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083190', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547608', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627398161, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547614', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083191', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547614', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627398417, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547618', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083256', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547618', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627398673, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547622', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083191', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547622', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627398929, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}, {'part_num': '800-01375-r02', 'installed': '1711547626', 'serial_num': 'REDACTED', 'device_status': ['envoy.global.ok'], 'last_rpt_date': '1712083367', 'admin_state': 1, 'dev_type': 1, 'created_date': '1711547626', 'img_load_date': '0', 'img_pnum_running': '521-00005-r06-v02.61.01', 'ptpn': '549-00041-r01-v02.61.01', 'chaneid': 1627399185, 'device_control': [{'gficlearset': False}], 'producing': True, 'communicating': True, 'provisioned': True, 'operating': True, 'phase': 'ph-a'}]}, {'type': 'ACB', 'devices': []}, {'type': 'NSRB', 'devices': []}, {'type': 'ESUB', 'devices': []}]
Enphase Envoy Plugin Trying Endpoint:https://REDACTED IP ADDRESS/api/v1/production
Enphase Envoy Plugin Success: https://REDACTED IP ADDRESS/api/v1/production
Enphase Envoy Plugin Response: {'wattHoursToday': 6183, 'wattHoursSevenDays': 171721, 'wattHoursLifetime': 177904, 'wattsNow': 1271}
Enphase Envoy Plugin Trying Endpoint:https://REDACTED IP ADDRESS/api/v1/production/inverters
Enphase Envoy Plugin Success: https://REDACTED IP ADDRESS/api/v1/production/inverters
Enphase Envoy Plugin Response: [{'serialNumber': 'REDACTED', 'lastReportDate': 1712083216, 'devType': 1, 'lastReportWatts': 37, 'maxReportWatts': 328}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083217, 'devType': 1, 'lastReportWatts': 37, 'maxReportWatts': 328}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083218, 'devType': 1, 'lastReportWatts': 38, 'maxReportWatts': 326}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083246, 'devType': 1, 'lastReportWatts': 37, 'maxReportWatts': 325}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083219, 'devType': 1, 'lastReportWatts': 37, 'maxReportWatts': 326}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083126, 'devType': 1, 'lastReportWatts': 39, 'maxReportWatts': 325}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083247, 'devType': 1, 'lastReportWatts': 37, 'maxReportWatts': 328}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083366, 'devType': 1, 'lastReportWatts': 36, 'maxReportWatts': 324}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083220, 'devType': 1, 'lastReportWatts': 37, 'maxReportWatts': 330}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083127, 'devType': 1, 'lastReportWatts': 39, 'maxReportWatts': 323}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083157, 'devType': 1, 'lastReportWatts': 39, 'maxReportWatts': 328}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083128, 'devType': 1, 'lastReportWatts': 38, 'maxReportWatts': 327}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083249, 'devType': 1, 'lastReportWatts': 38, 'maxReportWatts': 324}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083158, 'devType': 1, 'lastReportWatts': 39, 'maxReportWatts': 325}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083158, 'devType': 1, 'lastReportWatts': 39, 'maxReportWatts': 329}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083250, 'devType': 1, 'lastReportWatts': 37, 'maxReportWatts': 326}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083159, 'devType': 1, 'lastReportWatts': 38, 'maxReportWatts': 328}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083221, 'devType': 1, 'lastReportWatts': 37, 'maxReportWatts': 324}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083222, 'devType': 1, 'lastReportWatts': 38, 'maxReportWatts': 329}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083223, 'devType': 1, 'lastReportWatts': 37, 'maxReportWatts': 329}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083224, 'devType': 1, 'lastReportWatts': 37, 'maxReportWatts': 329}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083187, 'devType': 1, 'lastReportWatts': 38, 'maxReportWatts': 325}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083251, 'devType': 1, 'lastReportWatts': 37, 'maxReportWatts': 329}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083252, 'devType': 1, 'lastReportWatts': 37, 'maxReportWatts': 329}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083188, 'devType': 1, 'lastReportWatts': 38, 'maxReportWatts': 326}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083252, 'devType': 1, 'lastReportWatts': 37, 'maxReportWatts': 328}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083225, 'devType': 1, 'lastReportWatts': 37, 'maxReportWatts': 329}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083253, 'devType': 1, 'lastReportWatts': 37, 'maxReportWatts': 326}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083189, 'devType': 1, 'lastReportWatts': 39, 'maxReportWatts': 324}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083254, 'devType': 1, 'lastReportWatts': 37, 'maxReportWatts': 329}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083255, 'devType': 1, 'lastReportWatts': 37, 'maxReportWatts': 326}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083190, 'devType': 1, 'lastReportWatts': 38, 'maxReportWatts': 326}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083191, 'devType': 1, 'lastReportWatts': 39, 'maxReportWatts': 327}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083256, 'devType': 1, 'lastReportWatts': 37, 'maxReportWatts': 328}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083191, 'devType': 1, 'lastReportWatts': 38, 'maxReportWatts': 325}, {'serialNumber': 'REDACTED', 'lastReportDate': 1712083367, 'devType': 1, 'lastReportWatts': 36, 'maxReportWatts': 328}]
Enphase Envoy Plugin Trying Endpoint:https://REDACTED IP ADDRESS/auth/check_jwt
Enphase Envoy Plugin Success: https://REDACTED IP ADDRESS/auth/check_jwt
Enphase Envoy Plugin Trying Endpoint:https://REDACTED IP ADDRESS/ivp/meters
Enphase Envoy Plugin Success: https://REDACTED IP ADDRESS/ivp/meters
Enphase Envoy Plugin Response: [{'eid': 704643328, 'state': 'enabled', 'measurementType': 'production', 'phaseMode': 'split', 'phaseCount': 2, 'meteringStatus': 'normal', 'statusFlags': []}, {'eid': 704643584, 'state': 'enabled', 'measurementType': 'net-consumption', 'phaseMode': 'split', 'phaseCount': 2, 'meteringStatus': 'normal', 'statusFlags': []}]
Enphase Envoy Plugin Trying Endpoint:https://REDACTED IP ADDRESS/ivp/meters/readings
Enphase Envoy Plugin Success: https://REDACTED IP ADDRESS/ivp/meters/readings
Enphase Envoy Plugin Response: [{'eid': 704643328, 'timestamp': 1712083446, 'actEnergyDlvd': 177989.661, 'actEnergyRcvd': 0.002, 'apparentEnergy': 257614.859, 'reactEnergyLagg': 89218.866, 'reactEnergyLead': 508.159, 'instantaneousDemand': 1230.697, 'activePower': 1230.697, 'apparentPower': 1575.506, 'reactivePower': 721.981, 'pwrFactor': 0.783, 'voltage': 250.286, 'current': 12.59, 'freq': 60.0, 'channels': [{'eid': 1778385169, 'timestamp': 1712083446, 'actEnergyDlvd': 89043.095, 'actEnergyRcvd': 0.001, 'apparentEnergy': 128847.99, 'reactEnergyLagg': 44669.828, 'reactEnergyLead': 225.468, 'instantaneousDemand': 616.044, 'activePower': 616.044, 'apparentPower': 788.43, 'reactivePower': 362.157, 'pwrFactor': 0.783, 'voltage': 125.25, 'current': 6.294, 'freq': 60.0}, {'eid': 1778385170, 'timestamp': 1712083446, 'actEnergyDlvd': 88946.566, 'actEnergyRcvd': 0.002, 'apparentEnergy': 128766.869, 'reactEnergyLagg': 44549.038, 'reactEnergyLead': 282.69, 'instantaneousDemand': 614.653, 'activePower': 614.653, 'apparentPower': 787.076, 'reactivePower': 359.824, 'pwrFactor': 0.783, 'voltage': 125.035, 'current': 6.295, 'freq': 60.0}, {'eid': 1778385171, 'timestamp': 1712083446, 'actEnergyDlvd': 0.0, 'actEnergyRcvd': 0.0, 'apparentEnergy': 0.0, 'reactEnergyLagg': 0.0, 'reactEnergyLead': 0.0, 'instantaneousDemand': 0.0, 'activePower': 0.0, 'apparentPower': 0.0, 'reactivePower': 0.0, 'pwrFactor': 0.0, 'voltage': 0.0, 'current': 0.0, 'freq': 60.0}]}, {'eid': 704643584, 'timestamp': 1712083446, 'actEnergyDlvd': 98448.337, 'actEnergyRcvd': 136046.812, 'apparentEnergy': 302767.103, 'reactEnergyLagg': 19278.81, 'reactEnergyLead': 89456.156, 'instantaneousDemand': -102.961, 'activePower': -102.961, 'apparentPower': 1405.749, 'reactivePower': -929.232, 'pwrFactor': -0.044, 'voltage': 250.354, 'current': 11.257, 'freq': 60.0, 'channels': [{'eid': 1778385425, 'timestamp': 1712083446, 'actEnergyDlvd': 27594.266, 'actEnergyRcvd': 75662.502, 'apparentEnergy': 142265.371, 'reactEnergyLagg': 11538.046, 'reactEnergyLead': 44331.158, 'instantaneousDemand': -416.929, 'activePower': -416.929, 'apparentPower': 706.554, 'reactivePower': -467.343, 'pwrFactor': -0.531, 'voltage': 125.294, 'current': 5.663, 'freq': 60.0}, {'eid': 1778385426, 'timestamp': 1712083446, 'actEnergyDlvd': 70854.071, 'actEnergyRcvd': 60384.311, 'apparentEnergy': 160501.732, 'reactEnergyLagg': 7740.765, 'reactEnergyLead': 45124.999, 'instantaneousDemand': 313.968, 'activePower': 313.968, 'apparentPower': 699.195, 'reactivePower': -461.89, 'pwrFactor': 0.449, 'voltage': 125.061, 'current': 5.594, 'freq': 60.0}, {'eid': 1778385427, 'timestamp': 1712083446, 'actEnergyDlvd': 0.003, 'actEnergyRcvd': 0.0, 'apparentEnergy': 167.069, 'reactEnergyLagg': 12.377, 'reactEnergyLead': 0.462, 'instantaneousDemand': 0.0, 'activePower': 0.0, 'apparentPower': 1.161, 'reactivePower': 0.0, 'pwrFactor': 0.0, 'voltage': 7.426, 'current': 0.156, 'freq': 60.0}]}]
Enphase Envoy Plugin Trying Endpoint:https://REDACTED IP ADDRESS/ivp/livedata/status
Enphase Envoy Plugin Success: https://REDACTED IP ADDRESS/ivp/livedata/status
Enphase Envoy Plugin Response: {'connection': {'mqtt_state': 'connected', 'prov_state': 'configured', 'auth_state': 'ok', 'sc_stream': 'disabled', 'sc_debug': 'disabled'}, 'meters': {'last_update': 1712065254, 'soc': 0, 'main_relay_state': 1, 'gen_relay_state': 5, 'backup_bat_mode': 1, 'backup_soc': 0, 'is_split_phase': 1, 'phase_count': 0, 'enc_agg_soc': 0, 'enc_agg_energy': 0, 'acb_agg_soc': 0, 'acb_agg_energy': 0, 'pv': {'agg_p_mw': 829967, 'agg_s_mva': 1212188, 'agg_p_ph_a_mw': 829967, 'agg_p_ph_b_mw': 0, 'agg_p_ph_c_mw': 0, 'agg_s_ph_a_mva': 1212188, 'agg_s_ph_b_mva': 0, 'agg_s_ph_c_mva': 0}, 'storage': {'agg_p_mw': 0, 'agg_s_mva': 0, 'agg_p_ph_a_mw': 0, 'agg_p_ph_b_mw': 0, 'agg_p_ph_c_mw': 0, 'agg_s_ph_a_mva': 0, 'agg_s_ph_b_mva': 0, 'agg_s_ph_c_mva': 0}, 'grid': {'agg_p_mw': -187999, 'agg_s_mva': 61387, 'agg_p_ph_a_mw': -187999, 'agg_p_ph_b_mw': 0, 'agg_p_ph_c_mw': 0, 'agg_s_ph_a_mva': 61387, 'agg_s_ph_b_mva': 0, 'agg_s_ph_c_mva': 0}, 'load': {'agg_p_mw': 641968, 'agg_s_mva': 1273575, 'agg_p_ph_a_mw': 641968, 'agg_p_ph_b_mw': 0, 'agg_p_ph_c_mw': 0, 'agg_s_ph_a_mva': 1273575, 'agg_s_ph_b_mva': 0, 'agg_s_ph_c_mva': 0}, 'generator': {'agg_p_mw': 0, 'agg_s_mva': 0, 'agg_p_ph_a_mw': 0, 'agg_p_ph_b_mw': 0, 'agg_p_ph_c_mw': 0, 'agg_s_ph_a_mva': 0, 'agg_s_ph_b_mva': 0, 'agg_s_ph_c_mva': 0}}, 'tasks': {'task_id': -239540594, 'timestamp': 1712082912}, 'counters': {'main_CfgLoad': 3, 'main_CfgChanged': 3, 'main_CfgNotFound': 7, 'main_taskUpdate': 19, 'MqttClient_publish': 32889, 'MqttClient_respond': 264, 'MqttClient_msgarrvd': 132, 'MqttClient_reconnect': 2, 'MqttClient_create': 3, 'MqttClient_setCallbacks': 3, 'MqttClient_connect': 3, 'MqttClient_subscribe': 3, 'SSL_Keys_Create': 3, 'sc_hdlDataPub': 32683, 'sc_SendStreamCtrl': 136, 'sc_SendDemandRspCtrl': 1, 'rest_Status': 4462}, 'dry_contacts': {'': {'dry_contact_id': '', 'dry_contact_type': '', 'dry_contact_load_name': '', 'dry_contact_status': 3006020}}}
Enphase Envoy Plugin Trying Endpoint:https://REDACTED IP ADDRESS/ivp/meters/reports/consumption
Enphase Envoy Plugin Success: https://REDACTED IP ADDRESS/ivp/meters/reports/consumption
Enphase Envoy Plugin Response: [{'createdAt': 1712083451, 'reportType': 'total-consumption', 'cumulative': {'currW': 1139.844, 'actPower': 1139.844, 'apprntPwr': 1574.268, 'reactPwr': -206.93, 'whDlvdCum': 140360.486, 'whRcvdCum': 0.0, 'varhLagCum': -69940.913, 'varhLeadCum': 88949.105, 'vahCum': 302768.768, 'rmsVoltage': 250.108, 'rmsCurrent': 12.596, 'pwrFactor': 0.73, 'freqHz': 60.0}, 'lines': [{'currW': 210.954, 'actPower': 210.954, 'apprntPwr': 88.873, 'reactPwr': -105.188, 'whDlvdCum': 40950.99, 'whRcvdCum': 0.0, 'varhLagCum': -33132.212, 'varhLeadCum': 44106.246, 'vahCum': 142266.203, 'rmsVoltage': 125.136, 'rmsCurrent': 0.71, 'pwrFactor': 1.0, 'freqHz': 60.0}, {'currW': 928.89, 'actPower': 928.89, 'apprntPwr': 1485.395, 'reactPwr': -101.742, 'whDlvdCum': 99409.496, 'whRcvdCum': 0.0, 'varhLagCum': -36808.701, 'varhLeadCum': 44842.859, 'vahCum': 160502.565, 'rmsVoltage': 124.971, 'rmsCurrent': 11.886, 'pwrFactor': 0.63, 'freqHz': 60.0}]}, {'createdAt': 1712083451, 'reportType': 'net-consumption', 'cumulative': {'currW': -87.786, 'actPower': -87.786, 'apprntPwr': 0.471, 'reactPwr': -928.949, 'whDlvdCum': -37566.527, 'whRcvdCum': 0.0, 'varhLagCum': 19278.81, 'varhLeadCum': 89457.264, 'vahCum': 302768.768, 'rmsVoltage': 250.108, 'rmsCurrent': 0.011, 'pwrFactor': -1.0, 'freqHz': 60.0}, 'lines': [{'currW': -403.507, 'actPower': -403.507, 'apprntPwr': -698.574, 'reactPwr': -466.87, 'whDlvdCum': -48044.598, 'whRcvdCum': 0.0, 'varhLagCum': 11538.046, 'varhLeadCum': 44331.714, 'vahCum': 142266.203, 'rmsVoltage': 125.136, 'rmsCurrent': -5.583, 'pwrFactor': -1.0, 'freqHz': 60.0}, {'currW': 315.721, 'actPower': 315.721, 'apprntPwr': 699.045, 'reactPwr': -462.079, 'whDlvdCum': 10478.071, 'whRcvdCum': 0.0, 'varhLagCum': 7740.765, 'varhLeadCum': 45125.549, 'vahCum': 160502.565, 'rmsVoltage': 124.971, 'rmsCurrent': 5.594, 'pwrFactor': 0.45, 'freqHz': 60.0}]}]
Enphase Envoy Plugin Trying Endpoint:https://REDACTED IP ADDRESS/info.xml
Enphase Envoy Plugin Success: https://REDACTED IP ADDRESS/info.xml
Enphase Envoy Plugin Trying Endpoint:http://REDACTED IP ADDRESS/ivp/pdm/energy
Enphase Envoy Plugin Failed, Response Code 301
Enphase Envoy Plugin Trying Endpoint:http://REDACTED IP ADDRESS/ivp/pdm/production
Enphase Envoy Plugin Trying Endpoint:http://REDACTED IP ADDRESS/production.json
Enphase Envoy Plugin Trying Endpoint:http://REDACTED IP ADDRESS/inventory.json
Enphase Envoy Plugin Trying Endpoint:http://REDACTED IP ADDRESS/api/v1/production
Enphase Envoy Plugin Trying Endpoint:http://REDACTED IP ADDRESS/api/v1/production/inverters
Enphase Envoy Plugin Trying Endpoint:http://REDACTED IP ADDRESS/auth/check_jwt
Enphase Envoy Plugin Trying Endpoint:http://REDACTED IP ADDRESS/ivp/meters
Enphase Envoy Plugin Trying Endpoint:http://REDACTED IP ADDRESS/ivp/meters/readings
Enphase Envoy Plugin Trying Endpoint:http://REDACTED IP ADDRESS/ivp/livedata/status
Enphase Envoy Plugin Trying Endpoint:http://REDACTED IP ADDRESS/ivp/meters/reports/consumption
Enphase Envoy Plugin Trying Endpoint:http://REDACTED IP ADDRESS/info.xml
Enphase Envoy Plugin Success: http://REDACTED IP ADDRESS/info.xml
Enphase Envoy Plugin ------- End of Check Endpoints -------
There might be a twist in this because at the moment, the Enphase app is "experiencing delayed data from IQ/Gateway/Envoy. There is no impact on the system operation."
Thanks for looking at this and let me know if there's anything else you need from me!
