Enphase Envoy-S Solar Power Plugin (with Panel Monitoring)
Wed Dec 21, 2016 6:24 pm
GlennNZ offline
Re: Enphase Envoy-S Solar Power Plugin (with Panel Monitorin
Bollar wrote:
GlennNZ wrote:
Bollar wrote:
Neat. I wonder if it works on my legacy Envoy? I'll play with it over the weekend.
Cool,
Let me know how you go.
Yeah, no luck. the local API on my Envoy is quite limited and it doesn't even respond to your plugin.
What model?
The local API on mine is very limited as well - the plugin doesn't use the documented API - rather than undocumented javascript links/json output (hence the panel info)
Glenn
Wed Dec 21, 2016 6:27 pm
Bollar offline
Wed Dec 21, 2016 6:29 pm
GlennNZ offline
Bollar wrote:
Do you have web page access? (seems so some reading)
The basic info on Envoy-S is http://IP/production.json
But if web access - Chrome Debug will point to other links as well (googling as I type)
Glenn
Wed Dec 21, 2016 6:33 pm
Bollar offline
Glenn
Yes, here's a script a wrote a couple of years ago:
import urllib2
import simplejson
f = urllib2.urlopen('http://envoy.bollar.com/api/v1/production')
json_string = f.read()
parsed_json = simplejson.loads(json_string)
enphaseCurrentPower = parsed_json['wattsNow']
enphaseEnergyLifetime = parsed_json['wattHoursLifetime']
enphaseEnergyToday = parsed_json['wattHoursToday']
enphaseEnergyWeek = parsed_json['wattHoursSevenDays']
indigo.variable.updateValue(1404241247, value=str(enphaseCurrentPower))
indigo.variable.updateValue(1837054298, value=str(enphaseEnergyLifetime))
indigo.variable.updateValue(1329850163, value=str(enphaseEnergyToday))
indigo.variable.updateValue(1342408763, value=str(enphaseEnergyWeek))
f.close()
And the results from the raw call:
  "wattHoursToday": 32167,
  "wattHoursSevenDays": 234269,
  "wattHoursLifetime": 66336922,
  "wattsNow": 0
Like I said. Limited. I switched to getting my data from the online version of the API.
Wed Dec 21, 2016 6:37 pm
GlennNZ offline
Glenn
import urllib2
import simplejson
f.close()
  "wattsNow": 0
My version has the same result from that query - but I don't use that API result - because it is so limited.
There is far much more info available through the non-API - straight to what they web client uses such as production.json result above, or
http://ip/inventory.json
http://IP/backbone/application.js?version=04.02.43
(for javascript app with all the links buried deep)
Presumably you get nothing with these calls?
Glenn
Wed Dec 21, 2016 6:57 pm
Bollar offline
GlennNZ wrote:
Glenn
import urllib2
import simplejson
f.close()
  "wattsNow": 0
I get nothing (a 404) from the first one, even if I try the api/v1 path but a whole bunch of jquery data from the second.
Wed Dec 21, 2016 6:58 pm
GlennNZ offline
Can you post me the javascript - probably zip and attach.
Its essentially the web code for running the page - and will in there somewhere have the pages with the raw data.
Glenn
Wed Dec 21, 2016 7:27 pm
Bollar offline
Sure, here you go. It has a .txt extension, but it's a .zip
Enphase Local API jquery.txt
(174.12 KiB) Downloaded 177 times
Wed Dec 21, 2016 7:51 pm
GlennNZ offline
Cool
Will see what I can find - when back on computer
Glenn
Wed Dec 21, 2016 8:15 pm
GlennNZ offline
Looking Now (and will edit post) Hard to tell if software is for multiple versions though.
But...
Try
http://IP/inv
http://IP/
http://IP/api/v1/production/inverters
(this should be panel ouput)
might need password
http://ivp/tpm/tpmstatus
Think that is about it -- if they work then you are missing more detailed consumption/production info - but rest depends on output of /inv and /api/v1/production/inverters (if they are similar then could add another device model for this device - and hopefully still get per panel output)
Glenn
Glenn
Wed Dec 21, 2016 8:42 pm
Bollar offline
But...
Try
http://IP/inv
http://IP/
might need password
Interesting - the password on the two pages that require passwords isn't known to me - I left it at admin/admin and confirmed that I can get into the administration page. I'll have to see if someone has published it somewhere.
Wed Dec 21, 2016 9:15 pm
GlennNZ offline
Password for new system is
envoy (all lowercase)
and
last 6 digits of serial number
Glenn
Wed Dec 21, 2016 9:46 pm
Bollar offline
and
No, that and variations I could think of didn't work - will hunt around.
Thu Dec 22, 2016 9:30 am
midd offline
I must have the Envoy legacy module too because the Envoy in my device column is saying unknown.
Indigo 7, Monterey (12.1) on a 2009 Mac Pro..
Thu Dec 22, 2016 9:58 am
Bollar offline
The legacy Envoy looks kind of like a pill - rectangular with rounded edges. The Envoy-S is definitely rectangular with sharp edges.
I'd consider upgrading, but it's $500.
