Enphase Envoy-S Solar Power Plugin (with Panel Monitoring)
Mon Sep 10, 2018 3:17 pm
mclass offline
Re: Enphase Envoy-S Solar Power Plugin (with Panel Monitorin
Glenn,
That sounds great, thanks.
If the tariff’s in a user defined variable, it should be possible, using Indigo’s actions and schedules, for anyone wanting multiple tariffs to modify the variable outside of the plugin.
mclass
Mon Sep 10, 2018 4:51 pm
GlennNZ offline
mclass wrote:
Glenn,
mclass
More thinking out loud follows!
Yep - could use a variable or set up a plugin command to change tariff.
Issue will still be calculating.
Single tariff is easy - can use the enphase reported WattHours for today/7days/lifetime for cost.
Simple WattHours x tarrif == new $ for the time periods
Enphase saves and can be easily repopulated/calculated if/when plugin restarted.
If Time of use/variable tariff - then this data reported by enphase doesn't help at all, and I don't think can be used.
The plugin would likely need to hourly calculate Watts Hours used in that hour (check how to) and check a user-defined schedule and then save that data away from Indigo so isn't lost on restart.
Would then need to read back in on restart to recalculate day/week/month totals...
Glenn
Tue Sep 11, 2018 4:42 am
GlennNZ offline
mclass wrote:
Glenn,
mclass
As a first start...
Try
https://github.com/Ghawken/IndigoEnphaseEnvoy
Click the clone/download button and install 0.2.0
Create your own 'Enphase Cost Device'
Should populate with $.cents cost per day/7 days/consumption/production and approx net.
Tarrif selectable within device in dollars/cents (e.g. 0.44 cents per kWh)
Quick first attempt as limited time - but if device not created will not affect the plugin at all.
Glenn
Wed Sep 12, 2018 7:43 pm
mclass offline
Thanks Glenn!
Loaded V0.2.0 and works OK. Appreciate the time!
However, I'm unsure which tariff I should be using (import or feed-in)?
I was contemplating that the two tariffs would be entered so that a comparison could be made. However the current cost device allows the "avoided cost" of solar production to be calculated - a good start!!
Like you, I'm a little busy at present, but if I have a brilliant thought(s) I'll let you know!!
Thanks again for the time you've spent and for this plugin.
mclass
Wed Sep 12, 2018 9:44 pm
GlennNZ offline
mclass wrote:
Thanks Glenn!
mclass
Thanks.
Not sure as I’m on time-of-day tariff - so doesn’t really apply to me.
But I can easily add different tariffs for the consumption/production and/or net $ - if that makes any sense for you.
Glenn
Thu Sep 13, 2018 1:15 am
GlennNZ offline
mclass wrote:
Thanks Glenn!
mclass
Hi again
Try 0.2.1
Some tidying up - hadn't converted all to kwH accidentally.
Also have added consumption tarrif and production tarrif as seperate device variables.
Also add netKwh7days and netKwhToday to device
Glenn
Mon Sep 17, 2018 12:36 am
mclass offline
Hi Glenn!
Finally made it back to my computer and downloaded latest release - but shows up as 0.2.0 that I already had. Tried downloading zip from Github with the same result.
Any ideas?
mclass
Mon Sep 17, 2018 1:01 am
GlennNZ offline
mclass wrote:
Hi Glenn!
Any ideas?
mclass
Sure?
Make sure you Click download/clone from front page
(just checked and latest commits are there)
Up to 0.2.3 now...
Tue Sep 18, 2018 3:40 pm
mclass offline
Got it thanks, Glenn. But work’s getting in the way of exploring the cost device in detail
Tue Dec 17, 2019 3:03 pm
Ironshel offline
I see that there was discussion 3 yrs ago in this thread about extracting per-panel information for older Enphase systems. I have an older system and the overall usage data is working but I am very interested in getting per-panel information (non Envoy-S unit). Any resolution to this ever discovered? I see that the Enphase website can capture the per-panel data, so I know it is in there somewhere.....
Wed Dec 18, 2019 7:27 pm
GlennNZ offline
Hi
3 years wasn't possible.. but might be possible now.
Basically the issue I believe is username, password
See here:
Some clever person has reverse engineered installer password for older models (and current) and created a Android app to get your installer password.
https://thecomputerperson.wordpress.com ... r-toolkit/
From reports it would seem if you do this, generate installer password and use installer/'generated password' - may work!
Glenn
Wed Feb 12, 2020 9:02 pm
mclass offline
Hi Glenn!
I am currently configuring a new house with Enphase solar. Downloaded "latest release" (v0.1.8 ) from the plug-in store. All worked well creating the Envoy and panel devices, until I attempted to create an Envoy cost device! Not to be found anywhere on Indigo.
In desperation, went to GitHub to find v0.2.3, and, voila, there was the cost device! Thought I was losing my grip, but now all good!
In the interests of my (and others) future sanity, might I suggest an update to the plugin store page might be in order?
Thanks again for a really useful plugin
mclass
Wed Feb 12, 2020 9:08 pm
GlennNZ offline
Oops.
Thanks will do.
It was more of a proof of concept and then the requesting user got busy with other bits and pieces (just realised that was you!) - so consider it slightly beta functionality....
Cheers
Glenn
Thu Feb 13, 2020 4:52 am
mclass offline
Thanks Glenn!
It was me and that version’s been in active reliable service since its release!
Mon Jun 15, 2020 7:27 am
roquej offline
Trying to use the plugin and running into some issues. The plugin is installed, with no error and it provides " consumptionWattsNow" data. However, nothing else:
states : States : (dict)
consumption7days : 0 (integer)
consumptionWattsNow : 1482 (integer)
consumptionWattsToday : 0 (integer)
consumptionwhLifetime : 0 (integer)
deviceIsOnline : true (bool)
deviceIsOnline.ui : Online (string)
deviceLastUpdated : 06/15/2020 at 09:22 (string)
generatingPower : true (bool)
netConsumptionWattsNow : 0 (integer)
netconsumptionwhLifetime : 0 (integer)
numberInverters : 32 (integer)
powerStatus : exporting (string)
powerStatus.exporting : true (bool)
powerStatus.importing : false (bool)
powerStatus.offline : false (bool)
powerStatus.ui : Exporting Power (string)
production7days : 0 (integer)
productionWattsNow : 1482 (integer)
productionWattsToday : 0 (integer)
productionwhLifetime : 0 (integer)
readingTime : 2020-06-15 09:22:35 (string)
secsSinceReading : 18 (integer)
storageActiveCount : 0 (integer)
storagePercentFull : 0 (integer)
storageState : idle (string)
storageWattsNow : 0 (integer)
Suggestions?
JP
Page 6 of 11 1 ... 3, 4, 5, 6, 7, 8, 9 ... 11
