Enphase Envoy-S Solar Power Plugin (with Panel Monitoring)
Mon Jan 16, 2017 12:24 am
lindauer offline
Re: Enphase Envoy-S Solar Power Plugin (with Panel Monitorin
Thanks Glenn.
That seamed to do it.
Mark
Mon Jan 16, 2017 8:41 pm
GlennNZ offline
0.1.3 Update
Minor changes to calculation to give same result as reported (when available)
Negative NetConsumption means power is being exported.
Change to StorageState reporting
Glenn
Tue Feb 21, 2017 11:33 am
cwf offline
Does this require Indigo 7?
Fri Apr 21, 2017 9:09 am
cwf offline
I'm having some troubles with the setup, the plugin is installed, it is enabled. But when I "create a new device" the envoy plugin isn't listed in the drop-down. I've tried to re-install the plugin and verified it is enabled. What am I missing?
Screen Shot 2017-04-21 at 11.06.05 AM.png (26.66 KiB) Viewed 13133 times
Screen Shot 2017-04-21 at 11.07.22 AM.png (20.48 KiB) Viewed 13133 times
Fri Apr 21, 2017 12:07 pm
GlennNZ offline
Hmm not sure - away at moment so difficult to troubleshoot for you.
What is displayed in the dropdown plugin list? (Because it should be there with about, change logging options etc)
Glenn
Fri Apr 21, 2017 1:24 pm
cwf offline
Is this the list you're asking about?
Should have looked at the logs earlier...
Reloading plugin "Enphase Envoy Plugin 0.1.3"
Starting plugin "Enphase Envoy Plugin 0.1.3" (pid 2198)
Enphase Envoy Plugin Error Error in plugin execution InitializeMain:
File "plugin.py", line 15, in <module>
ImportError: No module named requests
Screen Shot 2017-04-21 at 3.22.38 PM.png (66.23 KiB) Viewed 13120 times
Fri Apr 21, 2017 1:31 pm
GlennNZ offline
Hi
Yep - pretty sure requests is included in indigo 7
?are you running Indigo 6
ifindStuff has instructions on adding requests module here (don't need other ones)
viewtopic.php?f=181&t=14572
Not sure whether plugin is indigo6 compatible even after requests install - but can have a look when back.
Presumed there wouldn't be much point given 7 better in all aspects
G
Fri Apr 21, 2017 1:34 pm
cwf offline
Ok, thanks!
Fri Apr 21, 2017 2:11 pm
GlennNZ offline
Updated last post
G
Wed May 03, 2017 2:30 pm
shmigator offline
Hi Glenn
The plugin seems to work mostly [ Great job BTW] , but i don't think I'm getting all the data.
The Envoy-S device always shows offline. Device added, and properly generates my 43 panels.
First time I added it it showed online, but all zeroes. There was no sun , and by the morning my envoy's webpage was showing a page not found [enphase local web server error] . I had to flip the circuits on my enphase to reboot it.
In Indigo main screen, the only "device details" shown (envoy & panels) is last update for all, and not those custom states you show. I don't have the importing power column you have, but the STATE column for the panels appears to be showing current production. Control pages let me display some additional data, including Envoy-S "power production", but everything else from envoy-S is 0 or false/offline.
I can login to the enphase local webserver, and any of those json files you or others online mention.
Indigo 6, manually installed REQUESTS
Envoy-S from sunRun installed few months ago.
Wed May 03, 2017 3:25 pm
GlennNZ offline
shmigator wrote:
Hi Glenn
Thanks, took a couple of re-reads to follow.
On balance I suspect this may be the difference between indigo6 and indigo7 in the code. Indigo 7 was relatively new - but I believe I used a few 7 only functions which probably responsible for some offline/0 data.
- Have you scrolled up to see custom states? (Moving the bar)
I can't explain how you may have a different number of custom states.
Some screenshots of what you are experiencing - plus/minus the debug log (toggle enable debugging) would probably help.
I wasn't planning on having a indigo 6 and a indigo 7 version - but happy to revisit that though if needed.
Glenn
Wed May 03, 2017 4:23 pm
shmigator offline
Regarding Indigo 6, When I first installed the plugin I got the same error as user CWF, and followed the instructions to manually install REQUEST . I'll have to upgrade anyway so I'll do that sooner rather than later.
I attached some logs, and a screenshot showing the states. "Saving Values errors:list index out of range" is the recurring error.
Screenshot showing devices, and states.
Indigo-Enphase-Log.txt
Enphase Debug Log
(55.15 KiB) Downloaded 180 times
Wed May 03, 2017 5:20 pm
GlennNZ offline
Thanks for the logs. - could you double check they are on the highest debug log setting? - Doesn't seem to include every debug I would expect.
Will have a look a the value-out of range and post a fix - hopefully tonight my time
But:
If you click the bar - just above "Solar-Panels (Enphase Envoy-S)" and move upwards - does this expose the custom states?
(They should be there.)
Glenn
Wed May 03, 2017 6:24 pm
shmigator offline
yes. My bad.
Wed May 03, 2017 6:56 pm
GlennNZ offline
yes. My bad.
Thanks - double check your logging settings - (make sure on the most verbose)
The log seems to missing a few expected debug lines.
Glenn
Page 4 of 11 1, 2, 3, 4, 5, 6, 7 ... 11
