Netatmo plugin discussion
Fri Jan 29, 2016 1:05 pm
rvarela offline
got an error when creating the app at netatmo developers pag
When trying to create an application at the netatmo developers web page, I fill in only the required fields giving as a name netatmoindigo and netatmo indigo plugin as a description. Also clicked on the terms of use. I got a message saying that the name is already taken. What could be wrong? Thanks,
Ramiro
Fri Jan 29, 2016 1:38 pm
Jaska offline
Re: Netatmo plugin discussion
Hi
i have same error.
Just put something else in name field.
Any ideas why in netatmo windspeed is 1.1 m/s, but in indigo it is 2.0?
Gusts show 1.4 m/s and in indigo 4.
Fri Jan 29, 2016 1:43 pm
jeremyjjr offline
Re: got an error when creating the app at netatmo developers
Ramiro
Interesting! So it looks like as each of us create a link between Indigo and Netatmo, we need to use a unique application identifier. We'll have to update the instructions accordingly. Thanks for spotting that!
Fri Jan 29, 2016 1:45 pm
jeremyjjr offline
Jaska wrote:
Hi
i have same error.
Can you please turn on debugging. This will show you the information returned from the Netatmo servers and should trace the information being loaded in to the Indigo device attributes. If you could copy the information in the debug from a single update (you can get this if you reload the plugin) we can take a look and compare. Please also note the information shown in the Netatmo web app or mobile app at the same time - we'll need that as well!
J.
Fri Jan 29, 2016 3:31 pm
Jaska offline
Thank you for the quick reply.
Netatmo web app show following.
gusts 2.8m /s
wind speed 1.1 m/s
Debug log
Reloading plugin "Netatmo Plugin 0.6.0"
Stopping plugin "Netatmo Plugin 0.6.0" (pid 44361)
Netatmo Plugin Stopping Netatmo plugin
Stopped plugin "Netatmo Plugin 0.6.0"
Starting plugin "Netatmo Plugin 0.6.0" (pid 44378)
Netatmo Plugin Log level preferences are set to "Debug".
Started plugin "Netatmo Plugin 0.6.0"
Netatmo Plugin Debug Entered: Funct startup
Netatmo Plugin Debug versionCheck() called
Netatmo Plugin url:http://yikes.com/plugins/Netatmo.html
Netatmo Plugin Your plugin version, v0.6.0, is current.
Netatmo Plugin Debug Entered: Funct runConcurrantThread
Netatmo Plugin Debug Entered: Funct readNetatmo
Netatmo Plugin Debug Entered: ClientAuth init
Netatmo Plugin Debug Found Netatmo device 'Sadeanturi' (Sadeanturi) for station:Kaunisharju
Netatmo Plugin Debug Added Netatmo device 'Sadeanturi' to update list
Netatmo Plugin Debug Found Netatmo device 'Sisäanturi' (Sisällä) for station:Kaunisharju
Netatmo Plugin Debug Added Netatmo device 'Sisäanturi' to update list
Netatmo Plugin Debug Found Netatmo device 'Tuulimittari' (Wind Gauge) for station:Kaunisharju
Netatmo Plugin Debug Added Netatmo device 'Tuulimittari' to update list
Netatmo Plugin Debug Found Netatmo device 'Ulkoanturi' (Ulkona) for station:Kaunisharju
Netatmo Plugin Debug Added Netatmo device 'Ulkoanturi' to update list
Netatmo Plugin Debug DONE: got here wth netatmoDict:{u'Kaunisharju': {u'Sadeanturi': <indigo.Device object at 0x8942570>, u'Wind Gauge': <indigo.Device object at 0x89425b0>, u'Ulkona': <indigo.Device object at 0x89425f0>, u'Sis\xe4ll\xe4': <indigo.Device object at 0x8942430>}}
Netatmo Plugin Debug Queryng Netatmo station:Kaunisharju
Netatmo Plugin Debug Received Netatmo station authorization:<lnetatmo.ClientAuth instance at 0x8919eb8>
Netatmo Plugin Debug Received Netatmo station data:<lnetatmo.DeviceList instance at 0x8919e90>
Netatmo Plugin TTL set to:3600 seconds
Netatmo Plugin Debug Received Netatmo module:Sadeanturi, Value={u'sum_rain_24': 0, 'rf_status': 76, 'When': 1454102406, u'Rain': 0, 'battery_vp': 5668, u'sum_rain_1': 0}
Netatmo Plugin Debug Starting Netatmo device update with: Module=Sadeanturi, ID=1875224653, Sensor=sum_rain_24, Value=0
Netatmo Plugin Debug updating Netatmo device with: Module=Sadeanturi, ID=1875224653, Sensor=sum_rain_24, Value=0
Netatmo Plugin Debug using default decimal place setting = 1
Netatmo Plugin Debug Starting Netatmo device update with: Module=Sadeanturi, ID=1875224653, Sensor=rf_status, Value=76
Netatmo Plugin Debug updating Netatmo device with: Module=Sadeanturi, ID=1875224653, Sensor=rf_status, Value=76
Netatmo Plugin Debug Starting Netatmo device update with: Module=Sadeanturi, ID=1875224653, Sensor=When, Value=1454102406
Netatmo Plugin Debug updating Netatmo device with: Module=Sadeanturi, ID=1875224653, Sensor=When, Value=23:20:06
Netatmo Plugin Debug Starting Netatmo device update with: Module=Sadeanturi, ID=1875224653, Sensor=Rain, Value=0
Netatmo Plugin Debug updating Netatmo device with: Module=Sadeanturi, ID=1875224653, Sensor=Rain, Value=0
Netatmo Plugin Debug Starting Netatmo device update with: Module=Sadeanturi, ID=1875224653, Sensor=battery_vp, Value=5668
Netatmo Plugin Debug updating Netatmo device with: Module=Sadeanturi, ID=1875224653, Sensor=battery_vp, Value=5668
Netatmo Plugin Debug Starting Netatmo device update with: Module=Sadeanturi, ID=1875224653, Sensor=sum_rain_1, Value=0
Netatmo Plugin Debug updating Netatmo device with: Module=Sadeanturi, ID=1875224653, Sensor=sum_rain_1, Value=0
Netatmo Plugin Debug Received Netatmo module:Ulkona, Value={u'date_min_temp': 1454049926, 'rf_status': 78, u'Temperature': 0.40000000000000002, u'date_max_temp': 1454098933, u'min_temp': -5.7000000000000002, 'battery_vp': 5476, u'max_temp': 0.5, 'When': 1454102367, u'Humidity': 100}
Netatmo Plugin Debug Starting Netatmo device update with: Module=Ulkona, ID=596660901, Sensor=date_min_temp, Value=1454049926
Netatmo Plugin Debug updating Netatmo device with: Module=Ulkona, ID=596660901, Sensor=date_min_temp, Value=08:45:26
Netatmo Plugin Debug Starting Netatmo device update with: Module=Ulkona, ID=596660901, Sensor=rf_status, Value=78
Netatmo Plugin Debug updating Netatmo device with: Module=Ulkona, ID=596660901, Sensor=rf_status, Value=78
Netatmo Plugin Debug Starting Netatmo device update with: Module=Ulkona, ID=596660901, Sensor=Temperature, Value=0.4
Netatmo Plugin Debug updating Netatmo device with: Module=Ulkona, ID=596660901, Sensor=Temperature, Value=0.4
Netatmo Plugin Debug Starting Netatmo device update with: Module=Ulkona, ID=596660901, Sensor=date_max_temp, Value=1454098933
Netatmo Plugin Debug updating Netatmo device with: Module=Ulkona, ID=596660901, Sensor=date_max_temp, Value=22:22:13
Netatmo Plugin Debug Starting Netatmo device update with: Module=Ulkona, ID=596660901, Sensor=min_temp, Value=-5.7
Netatmo Plugin Debug updating Netatmo device with: Module=Ulkona, ID=596660901, Sensor=min_temp, Value=-5.7
Netatmo Plugin Debug Starting Netatmo device update with: Module=Ulkona, ID=596660901, Sensor=battery_vp, Value=5476
Netatmo Plugin Debug updating Netatmo device with: Module=Ulkona, ID=596660901, Sensor=battery_vp, Value=5476
Netatmo Plugin Debug Starting Netatmo device update with: Module=Ulkona, ID=596660901, Sensor=max_temp, Value=0.5
Netatmo Plugin Debug updating Netatmo device with: Module=Ulkona, ID=596660901, Sensor=max_temp, Value=0.5
Netatmo Plugin Debug Starting Netatmo device update with: Module=Ulkona, ID=596660901, Sensor=When, Value=1454102367
Netatmo Plugin Debug updating Netatmo device with: Module=Ulkona, ID=596660901, Sensor=When, Value=23:19:27
Netatmo Plugin Debug Starting Netatmo device update with: Module=Ulkona, ID=596660901, Sensor=Humidity, Value=100
Netatmo Plugin Debug updating Netatmo device with: Module=Ulkona, ID=596660901, Sensor=Humidity, Value=100
Netatmo Plugin Debug Received Netatmo module:Sisällä, Value={u'Noise': 52, u'Temperature': 22, 'When': 1454102411, u'Humidity': 35, u'Pressure': 985.60000000000002, u'CO2': 696, u'AbsolutePressure': 972.20000000000005, u'date_max_temp': 1454083241, u'min_temp': 20.199999999999999, u'date_min_temp': 1454040266, 'wifi_status': 60, u'max_temp': 22.100000000000001}
Netatmo Plugin Debug Starting Netatmo device update with: Module=Sisällä, ID=344363074, Sensor=Noise, Value=52
Netatmo Plugin Debug updating Netatmo device with: Module=Sisällä, ID=344363074, Sensor=Noise, Value=52
Netatmo Plugin Debug Starting Netatmo device update with: Module=Sisällä, ID=344363074, Sensor=Temperature, Value=22
Netatmo Plugin Debug updating Netatmo device with: Module=Sisällä, ID=344363074, Sensor=Temperature, Value=22
Netatmo Plugin Debug Starting Netatmo device update with: Module=Sisällä, ID=344363074, Sensor=When, Value=1454102411
Netatmo Plugin Debug updating Netatmo device with: Module=Sisällä, ID=344363074, Sensor=When, Value=23:20:11
Netatmo Plugin Debug Starting Netatmo device update with: Module=Sisällä, ID=344363074, Sensor=Humidity, Value=35
Netatmo Plugin Debug updating Netatmo device with: Module=Sisällä, ID=344363074, Sensor=Humidity, Value=35
Netatmo Plugin Debug Starting Netatmo device update with: Module=Sisällä, ID=344363074, Sensor=Pressure, Value=985.6
Netatmo Plugin Debug updating Netatmo device with: Module=Sisällä, ID=344363074, Sensor=Pressure, Value=985.6
Netatmo Plugin Debug Starting Netatmo device update with: Module=Sisällä, ID=344363074, Sensor=CO2, Value=696
Netatmo Plugin Debug updating Netatmo device with: Module=Sisällä, ID=344363074, Sensor=CO2, Value=696
Netatmo Plugin Debug Starting Netatmo device update with: Module=Sisällä, ID=344363074, Sensor=AbsolutePressure, Value=972.2
Netatmo Plugin Debug updating Netatmo device with: Module=Sisällä, ID=344363074, Sensor=AbsolutePressure, Value=972.2
Netatmo Plugin Debug Starting Netatmo device update with: Module=Sisällä, ID=344363074, Sensor=date_max_temp, Value=1454083241
Netatmo Plugin Debug updating Netatmo device with: Module=Sisällä, ID=344363074, Sensor=date_max_temp, Value=18:00:41
Netatmo Plugin Debug Starting Netatmo device update with: Module=Sisällä, ID=344363074, Sensor=min_temp, Value=20.2
Netatmo Plugin Debug updating Netatmo device with: Module=Sisällä, ID=344363074, Sensor=min_temp, Value=20.2
Netatmo Plugin Debug Starting Netatmo device update with: Module=Sisällä, ID=344363074, Sensor=date_min_temp, Value=1454040266
Netatmo Plugin Debug updating Netatmo device with: Module=Sisällä, ID=344363074, Sensor=date_min_temp, Value=06:04:26
Netatmo Plugin Debug Starting Netatmo device update with: Module=Sisällä, ID=344363074, Sensor=wifi_status, Value=60
Netatmo Plugin Debug updating Netatmo device with: Module=Sisällä, ID=344363074, Sensor=wifi_status, Value=60
Netatmo Plugin Debug Starting Netatmo device update with: Module=Sisällä, ID=344363074, Sensor=max_temp, Value=22.1
Netatmo Plugin Debug updating Netatmo device with: Module=Sisällä, ID=344363074, Sensor=max_temp, Value=22.1
Netatmo Plugin Debug Received Netatmo module:Wind Gauge, Value={u'date_min_temp': 1454018599, 'rf_status': 68, u'date_max_wind_str': 1454099984, u'WindHistoric': [{u'time_utc': 1454098965, u'WindStrength': 5, u'WindAngle': 33}, {u'time_utc': 1454099266, u'WindStrength': 5, u'WindAngle': 302}, {u'time_utc': 1454099567, u'WindStrength': 7, u'WindAngle': 10}, {u'time_utc': 1454099869, u'WindStrength': 2, u'WindAngle': 26}, {u'time_utc': 1454099984, u'WindStrength': 5, u'WindAngle': 345}, {u'time_utc': 1454100292, u'WindStrength': 5, u'WindAngle': 352}, {u'time_utc': 1454100593, u'WindStrength': 5, u'WindAngle': 358}, {u'time_utc': 1454100894, u'WindStrength': 4, u'WindAngle': 14}, {u'time_utc': 1454101196, u'WindStrength': 4, u'WindAngle': 14}, {u'time_utc': 1454101502, u'WindStrength': 4, u'WindAngle': 355}, {u'time_utc': 1454101804, u'WindStrength': 2, u'WindAngle': 330}, {u'time_utc': 1454102105, u'WindStrength': 4, u'WindAngle': 354}, {u'time_utc': 1454102406, u'WindStrength': 4, u'WindAngle': 336}], u'GustStrength': 10, 'When': 1454102406, u'WindStrength': 4, u'GustAngle': 1, u'min_temp': 0, u'date_max_temp': 1454018599, u'max_wind_str': 16, u'max_wind_angle': 255, 'battery_vp': 5933, u'WindAngle': 336, u'max_temp': 0}
Netatmo Plugin Debug Starting Netatmo device update with: Module=Wind Gauge, ID=1845362367, Sensor=date_min_temp, Value=1454018599
Netatmo Plugin Debug updating Netatmo device with: Module=Wind Gauge, ID=1845362367, Sensor=date_min_temp, Value=00:03:19
Netatmo Plugin Debug using decimal place setting from props = 1
Netatmo Plugin Debug Starting Netatmo device update with: Module=Wind Gauge, ID=1845362367, Sensor=rf_status, Value=68
Netatmo Plugin Debug updating Netatmo device with: Module=Wind Gauge, ID=1845362367, Sensor=rf_status, Value=68
Netatmo Plugin Debug Starting Netatmo device update with: Module=Wind Gauge, ID=1845362367, Sensor=date_max_wind_str, Value=1454099984
Netatmo Plugin Debug updating Netatmo device with: Module=Wind Gauge, ID=1845362367, Sensor=date_max_wind_str, Value=1454099984
Netatmo Plugin Debug Starting Netatmo device update with: Module=Wind Gauge, ID=1845362367, Sensor=GustStrength, Value=10
Netatmo Plugin Debug updating Netatmo device with: Module=Wind Gauge, ID=1845362367, Sensor=GustStrength, Value=10
Netatmo Plugin Debug Starting Netatmo device update with: Module=Wind Gauge, ID=1845362367, Sensor=When, Value=1454102406
Netatmo Plugin Debug updating Netatmo device with: Module=Wind Gauge, ID=1845362367, Sensor=When, Value=23:20:06
Netatmo Plugin Debug Starting Netatmo device update with: Module=Wind Gauge, ID=1845362367, Sensor=WindStrength, Value=4
Netatmo Plugin Debug updating Netatmo device with: Module=Wind Gauge, ID=1845362367, Sensor=WindStrength, Value=4
Netatmo Plugin Debug Starting Netatmo device update with: Module=Wind Gauge, ID=1845362367, Sensor=GustAngle, Value=1
Netatmo Plugin Debug updating Netatmo device with: Module=Wind Gauge, ID=1845362367, Sensor=GustAngle, Value=1
Netatmo Plugin Debug Starting Netatmo device update with: Module=Wind Gauge, ID=1845362367, Sensor=min_temp, Value=0
Netatmo Plugin Debug updating Netatmo device with: Module=Wind Gauge, ID=1845362367, Sensor=min_temp, Value=0
Netatmo Plugin Debug Starting Netatmo device update with: Module=Wind Gauge, ID=1845362367, Sensor=date_max_temp, Value=1454018599
Netatmo Plugin Debug updating Netatmo device with: Module=Wind Gauge, ID=1845362367, Sensor=date_max_temp, Value=00:03:19
Netatmo Plugin Debug Starting Netatmo device update with: Module=Wind Gauge, ID=1845362367, Sensor=max_wind_str, Value=16
Netatmo Plugin Debug updating Netatmo device with: Module=Wind Gauge, ID=1845362367, Sensor=max_wind_str, Value=16
Netatmo Plugin Debug Starting Netatmo device update with: Module=Wind Gauge, ID=1845362367, Sensor=max_wind_angle, Value=255
Netatmo Plugin Debug updating Netatmo device with: Module=Wind Gauge, ID=1845362367, Sensor=max_wind_angle, Value=255
Netatmo Plugin Debug Starting Netatmo device update with: Module=Wind Gauge, ID=1845362367, Sensor=battery_vp, Value=5933
Netatmo Plugin Debug updating Netatmo device with: Module=Wind Gauge, ID=1845362367, Sensor=battery_vp, Value=5933
Netatmo Plugin Debug Starting Netatmo device update with: Module=Wind Gauge, ID=1845362367, Sensor=WindAngle, Value=336
Netatmo Plugin Debug updating Netatmo device with: Module=Wind Gauge, ID=1845362367, Sensor=WindAngle, Value=336
Netatmo Plugin Debug Starting Netatmo device update with: Module=Wind Gauge, ID=1845362367, Sensor=max_temp, Value=0
Netatmo Plugin Debug updating Netatmo device with: Module=Wind Gauge, ID=1845362367, Sensor=max_temp, Value=0
Fri Jan 29, 2016 3:42 pm
jeremyjjr offline
Hi Jaska,
Okay so it looks like the Netatmo plugin for Indigo is doing exactly what it's being told by the Netatmo Web service. The following JSON response from the web service shows the information being returned.
We can then see these values being correctly put in to the device attributes ...
and ...
So as long as you are seeing the values 10 and 4 for Gust Strength and Wind Strength respectively, then everything in the plugin is working correctly. It will be a case of understanding why the information being shown by the Netatmo Web Site is so different. Perhaps that's a question that can be asked of Netatmo themselves, as it would seem the issue is with them. Can you ask?
If you get an answer that suggests we're not using the right data, then let me know and I'll modify accordingly.
Thanks for your help!
Jeremy.
Thu Feb 04, 2016 7:30 am
Just upgraded to Netatmo Plugin V0.6.0. :)
My Netatmo base station went u/s and I have had to buy a new one :(
I have set it up (new Base station and outdoor module) using the Netatmo App and transferred my existing three internal stations, and rain gauge to it.
I have then edited the devices to change the netatmo station name to the new station.
When I start the plugin I am getting the following error:
  Enabling plugin "Netatmo Plugin 0.6.0"
  Starting plugin "Netatmo Plugin 0.6.0" (pid 74386)
  Netatmo Plugin                  Log level preferences are set to "Intense Debug".
  Netatmo Plugin Debug            Found Netatmo device 'Netatmo Ensuite Bathroom' (Ensuite Bathroom) for station:netatmo2
  Netatmo Plugin Debug            Added Netatmo device 'Netatmo Ensuite Bathroom' to update list
  Netatmo Plugin Debug            Found Netatmo device 'Netatmo Living Room' (Living Room) for station:netatmo2
  Netatmo Plugin Debug            Added Netatmo device 'Netatmo Living Room' to update list
  Netatmo Plugin Debug            Found Netatmo device 'Netatmo Master Bedroom' (Master Bedroom) for station:netatmo2
  Netatmo Plugin Debug            Added Netatmo device 'Netatmo Master Bedroom' to update list
  Netatmo Plugin Debug            Found Netatmo device 'Netatmo Outdoor' (Outdoor) for station:netatmo2
  Netatmo Plugin Debug            Added Netatmo device 'Netatmo Outdoor' to update list
  Netatmo Plugin Debug            Found Netatmo device 'Netatmo Study' (Study) for station:netatmo2
  Netatmo Plugin Debug            Added Netatmo device 'Netatmo Study' to update list
  Netatmo Plugin Debug            Found Netatmo device 'Rain Gauge' (Rain Gauge) for station:netatmo2
  Netatmo Plugin Debug            Added Netatmo device 'Rain Gauge' to update list
  Netatmo Plugin Debug            DONE: got here wth netatmoDict:{u'netatmo2': {u'Outdoor': <indigo.Device object at 0x5f65670>, u'Master Bedroom': <indigo.Device object at 0x5f655b0>, u'Ensuite Bathroom': <indigo.Device object at 0x5f65570>, u'Rain Gauge': <indigo.Device object at 0x5f656f0>, u'Study': <indigo.Device object at 0x5f656b0>, u'Living Room': <indigo.Device object at 0x5f654b0>}}
  Netatmo Plugin Debug            Queryng Netatmo station:netatmo2
  Netatmo Plugin Debug            Received Netatmo station authorization:<lnetatmo.ClientAuth instance at 0x5f2ff30>
  Netatmo Plugin Debug            Received Netatmo station data:<lnetatmo.DeviceList instance at 0x5f2fa80>
  Netatmo Plugin Error            Plugin stopping. Reason = 'NoneType' object has no attribute 'items'
  Netatmo Plugin                  Stopping Netatmo device read loop
  Netatmo Plugin Error            plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Any ideas?
Thu Feb 04, 2016 1:01 pm
jeremyjjr offline
Do you see the same errors if you go back to plugin version v0.5.0?
Thu Feb 04, 2016 1:57 pm
Yes - The error occurred in v0.5.0 and so I thought I would upgrade to V0.6.0 :)
Thu Feb 11, 2016 11:35 am
jens offline
Thank you for a great plugin...
Is it posible to suport Netatmo WELCOME??
Best Regards
Jens
Thu Feb 11, 2016 11:41 am
berkinet offline
jens wrote:
...is it posible to suport Netatmo WELCOME??
It would not really be useful to support WELCOME in this plugin. It offers completely unrelated functionality and uses a separate API.
However, since there is an API for the WELCOME someone could certainly develop a plugin for it.
Thu Feb 11, 2016 1:41 pm
jens offline
Okey, thanks for your replay :)
Sent from my iPhone 6 using Tapatalk
Sat Mar 05, 2016 9:03 am
SpikeB offline
Can not get the plugin to work (version 0.6.0)
logging:
Plugin stopping. Reason = 'ascii' codec can't encode character u'\u2026' in position 3: ordinal not in range(128)
anybody any idea, how to solve this.
Sat Mar 05, 2016 9:53 am
berkinet offline
logging:
It sounds like you have a non-ascii character in a device name.
Sat Mar 05, 2016 10:52 am
SpikeB offline
berkinet wrote:
logging:
It sound like you have a non-as I character in a device name.
Thanks, renewed the settings and now everything works.
Page 14 of 26 1 ... 11, 12, 13, 14, 15, 16, 17 ... 26
Users browsing this forum: No registered users and 26 guests
