Netatmo plugin discussion
Mon Dec 28, 2015 11:12 am
davinci offline
Re: Netatmo plugin discussion
Thanks for your reply.
I know this device exists but I don't want to use it in Indigo. Therefore I don't need that message but I can't disable it. (removing is not an option)
Any idea what this is about? That happens from time to time:
Netatmo Plugin Error Plugin stopping. Reason = <urlopen error The read operation timed out>
Netatmo Plugin Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Wed Dec 30, 2015 4:24 am
davinci offline
Looks like a timeout of 5 second handles fixes the mentioned error message. I had the timeout set to maximum.
Regarding the "Error writing data for Netatmo unit: 'TEST'. No matching Indigo device found.", please consider making this error not appear if not wanted. I have these devices but don't use all of them in Indigo.
Because I'm monitoring the log for errors this makes it impossible to get valid data.
Wed Dec 30, 2015 12:53 pm
berkinet offline
davinci wrote:
...Regarding the "Error writing data for Netatmo unit: 'TEST'. No matching Indigo device found.", please consider making this error not appear if not wanted. I have these devices but don't use all of them in Indigo.... ...Because I'm monitoring the log for errors this makes it impossible to get valid data.
Could you explain the use case for having a device defined that you did not use? Have you tried just disabling communications for this device?
Wed Dec 30, 2015 5:45 pm
davinci offline
One sensor is shared. The other one is a wind sensor.
I will try to disable communication but this error comes before creating a device.
Wed Dec 30, 2015 5:48 pm
berkinet offline
I still do not understand why you need an Indigo device for something you do not wish to connect to? If you are not using an Indigo Netatmo "device" in the plugin, you should delete it. That device has no impact on your Netatmo account. Did you try turning off communications to that device?
Thu Dec 31, 2015 6:11 am
davinci offline
Ok, I think I have to explain the situation better.
I have the devices TEST and Wind in Netatmo. I don't want it to add to Indigo because I have no use of it or it doesn't work yet (wind). So the devices are not visible in Indigo.
For every device that hasn't been added yet I get this error message everytime Indigo updates the Netatmo values:
  Netatmo Plugin Error            Error writing data for Netatmo unit: 'Wind'. No matching Indigo device found.
u'Wind'
  Netatmo Plugin Error            Error writing data for Netatmo unit: 'TEST'. No matching Indigo device found.
u'TEST'
So yes, it can't write data because there is no device to write it in. Unless I remove the device from Netatmo I have no way of getting rid of this message.
Second problem still exists. If the timeout takes longer than x I get an error message. That's ok, but I don't really want that message to appear if it times out just once... This happens frequently on Netatmo servers. It should just retry silently which is most of the time a success.
Hope this makes it clear. Thank you for considering to fix these two issues.
Thu Dec 31, 2015 10:08 am
Maybe you could just create the devices to shut up the discovery log message, then disable them so Indigo doesn't try to use them for anything.
Thu Dec 31, 2015 10:14 am
davinci offline
Thanks I did that, but I can't do that for the wind sensor yet. Because there is no "device" for it I still get an error.
Error device "new device" state key date_min_temp not defined (ignoring update request)
Error device "new device" state key date_max_wind_str not defined (ignoring update request)
Thu Dec 31, 2015 11:59 am
berkinet offline
I am sorry, but I really do not see the pressing need to leave unused devices in Indigo. To do do that for one plugin would take far more work to change the plugin than it would take to delete and re-create the device.
Perhaps you can ask Matt and Jay to add a feature to "disable" a device as a general product capability.
Thu Dec 31, 2015 12:05 pm
If I understand this correctly, the problem is that there is NO Indigo device matching this Netatmo sensor, but the plugin is trying to find one to write the data to. So he continually gets errors because the plugin won't ignore these Netatmo devices.
Fri Jan 01, 2016 4:23 am
davinci offline
Thanks joe, thats's right.
I have a shared device in my Netatmo account. I don't want it in Indigo, so I don't add it. Because I did NOT add it I get this error message. But for me this is not an error...
Why does the plugin crash when it timeouts? Looks like a serious bug.
Mon Jan 11, 2016 11:57 am
Is anyone else getting Netatmo errors, like:
Netatmo Plugin Error Plugin stopping. Reason = 'module_name'
Started happening at 13:48 GMT.
Not sure if it is something going wrong at my end or a problem at the Netatamo end :?
Tue Jan 26, 2016 12:41 pm
berkinet offline
Version 0.6.0 of the Netatmo plugin is now available. For more information, see the Netatmo Announcement topic.
Tue Jan 26, 2016 1:00 pm
berkinet offline
Many thanks to @jeremyjjr for this link to the Netatmo online shop which is selling the new wind gauge. Pricing is in.
Unfortunately for customers outside of Europe, this link is only valid for shipping to European destinations.
Thu Jan 28, 2016 11:44 am
davinci offline
Thanks a lot for the update.
I do still get the error message for not existing modules despite having logging level to none. Looks like I have to add them.
And I still get this one as well:
Page 13 of 26 1 ... 10, 11, 12, 13, 14, 15, 16 ... 26
