Netatmo Plugin Error Plugin stopping. Reason = 'NoneType' object has no attribute 'items'
Starting plugin "Netatmo Plugin 0.7.4" (pid 33313)
Netatmo Plugin Log level preferences are set to "Intense Debug".
Started plugin "Netatmo Plugin 0.7.4"
Netatmo Plugin Debug Entered: Funct startup
Netatmo Plugin Debug versionCheck() called
Netatmo Plugin url:https://api.indigodomo.com/api/v2/pluginstore/plugin-version-info.json?pluginId=com.berkinet.Netatmo
Netatmo Plugin Your plugin version, 0.7.4, is current.
Netatmo Plugin Debug Entered: Funct runConcurrantThread
Netatmo Plugin Debug Entered: Funct readNetatmo
Netatmo Plugin Debug Found Netatmo device 'Netatmo basstation' (Garage) for station:Kronanbacken
Netatmo Plugin Debug Added Netatmo device 'Netatmo basstation' to update list
Netatmo Plugin Debug Found Netatmo device 'Netatmo mobil modul' (Mobil) for station:Kronanbacken
Netatmo Plugin Debug Added Netatmo device 'Netatmo mobil modul' to update list
Netatmo Plugin Debug Found Netatmo device 'Netatmo regnmätare' (Regnmätare) for station:Kronanbacken
Netatmo Plugin Debug Added Netatmo device 'Netatmo regnmätare' to update list
Netatmo Plugin Debug Found Netatmo device 'Netatmo utomhusmodul' (Utomhus) for station:Kronanbacken
Netatmo Plugin Debug Added Netatmo device 'Netatmo utomhusmodul' to update list
Netatmo Plugin Debug Found Netatmo device 'Netatmo vindmätare' (Vindmätare) for station:Kronanbacken
Netatmo Plugin Debug Added Netatmo device 'Netatmo vindmätare' to update list
Netatmo Plugin Debug DONE: got here wth netatmoDict:{u'Kronanbacken': {u'Garage': <indigo.Device object at 0x1116209b0>, u'Utomhus': <indigo.Device object at 0x111620b90>, u'Regnm\xe4tare': <indigo.Device object at 0x111620b18>, u'Mobil': <indigo.Device object at 0x111620a28>, u'Vindm\xe4tare': <indigo.Device object at 0x111620c08>}}
Netatmo Plugin Debug Queryng Netatmo station:Kronanbacken
Netatmo Plugin Debug Received Netatmo station authorization:<lnetatmo.ClientAuth instance at 0x11160a998>
Received Netatmo station list:
[u'Regnm\xe4tare', u'Utomhus', u'Vindm\xe4tare', u'Mobil', u'Garage']
Received Netatmo station data:
{u'Garage': {u'CO2': 497, u'Temperature': 21.6, 'When': 1605729707, u'temp_trend': u'stable', u'Humidity': 36, u'Pressure': 988.4, u'Noise': 46, u'min_temp': 20.7, u'AbsolutePressure': 985.1, u'pressure_trend': u'stable', u'date_max_temp': 1605711859, u'date_min_temp': 1605688271, 'wifi_status': 53, u'max_temp': 22.4}, u'Utomhus': {u'date_min_temp': 1605682193, 'rf_status': 68, u'Temperature': 3, 'When': 1605729667, u'temp_trend': u'stable', u'Humidity': 91, u'min_temp': 0.9, u'date_max_temp': 1605654097, 'battery_vp': 5706, u'max_temp': 5.4}, u'Regnm\xe4tare': {u'sum_rain_24': 0.1, 'rf_status': 67, 'When': 1605729706, u'Rain': 0, 'battery_vp': 5298, u'sum_rain_1': 0}, u'Mobil': {u'CO2': 748, 'rf_status': 75, u'Temperature': 2.8, 'When': 1605729699, u'temp_trend': u'stable', u'Humidity': 100, u'date_min_temp': 1605681916, u'min_temp': 0.4, u'date_max_temp': 1605656180, 'battery_vp': 5492, u'max_temp': 5.1}, u'Vindm\xe4tare': {'rf_status': 63, u'date_max_wind_str': 1605692804, u'GustStrength': 3, 'When': 1605729706, u'WindStrength': 1, u'GustAngle': 231, u'max_wind_str': 17, u'max_wind_angle': 272, 'battery_vp': 4773, u'WindAngle': 45}}
Received Netatmo station Name:
None
Netatmo Plugin TTL set to:3600 seconds
Netatmo Plugin Stopping Netatmo device read loop
Netatmo Plugin Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
None
davinci wrote:That makes sense. The fix I made was to use the home name in place of the station name, which has been deprecated by Netatmo. I have now contacted the author of the module used in the plugin and we are looking at an all-around fix.Still the same with 0.7.5:
I have a shared station in my account. So two houses. It looks like the first one (mine) works.
