Re: Meta (Pseudo) Device Plugin
Posted: Thu Oct 18, 2012 7:14 am
mikeL wrote:Where can I get version 0.9.9 that I understand is now available?
The latest version is always available from the Meta Device Announcements forum.
Software Support and Home Automation Forum
https://forums.indigodomo.com/
jamus wrote:This plugin is a huge timesaver / complexity reducer in my setup... ...My only feature request would have a additional option to mirror the state of another device.
<Action id="mirrorAnotherDevice" deviceFilter="self">
<Name>Set device onState based on another device</Name>
<CallbackMethod>mirrorAnotherDevice</CallbackMethod>
<ConfigUI>
<Field id="device" type="menu">
<Label>Device:</Label>
<List class="indigo.devices" filter="indigo.relay"/>
</Field>
</ConfigUI>
</Action>
def mirrorAnotherDevice(self,action):
if self.logLevel > 2: indigo.server.log(u"Mirror another device action called")
if self.logLevel > 3: indigo.server.log("Action received: %s" % action)
indigoDevice = indigo.devices[action.deviceId]
sourceDeviceId = int(action.props.get('device', ""))
sourceDevice = indigo.devices[sourceDeviceId]
except:
self.errorLog("Device not found. Check configuration of action")
return
indigoDevice.updateStateOnServer(key='onOffState',value=sourceDevice.onState)
elif typeId == "mirrorAnotherDevice":
deviceId = int(valuesDict.get('device',""))
except ValueError:
errorMsgDict['device']=u"You must select a device."
return (False, valuesDict, errorMsgDict)
return (True,valuesDict)
berkinet wrote:You could...
Change the brightness level in the devices window.
Change the brightness from the iTouch app (the most common use)
Change the level from a control page
Create a trigger+script to read changes in brightness from a read dimmer and then set the meta device to that level.
berkinet wrote:...But, basically, you must define an action that is invoked anytime the brightness level of the meta-device.
Dewster35 wrote:...Is there a limit to how many scenes this plugin can look at in the controller? I have 30 currrently setup.
