Phidgets Plugin Discussion
Wed Jul 20, 2022 7:59 am
midd offline
Re: Phidgets Plugin Discussion
I've been using a Davis rain gauge with a phidgets 1018 for some time. THe rain gauge sat on a metal folding stool that I never cared about since it was always in the way. I just scored a partial Davis weather station off ebay for $20! . It has the mount and sensors for wind,rain, temp/humidity. And the connections are intact . I plan on adding couplers and running lines from the weather proof box to my computer in my basement.
I'm assuming I'll need a phidget frequency counter for the wind measurements. And I should be able to use the 1018 for the temp along with the rain gauge that I use it for already.
https://photos.app.goo.gl/vUCnQeEq99oeBevg6
https://photos.app.goo.gl/iU8WyWQ6RnHh6hpv9
Indigo 7, Monterey (12.1) on a 2009 Mac Pro..
Sat Jul 23, 2022 5:37 am
berkinet offline
midd wrote:
I've been using a Davis rain gauge with a phidgets 1018 for some time. ...
I am not sure if you were looking for a response. But, yes, your plan sounds solid and the Phidgets22 plugin supports the Freq Counter.
Thu Jun 01, 2023 7:58 pm
hamw offline
Hi Berkinet,
Just got a new Mac mini which has Ventura loaded. I also upgraded to 2022.2. Now the Phidgets plugin does not recognize the boards. I reinstalled the 21 libs, and the preference pane seems to be normal and the bonjour web service is running, but the 8/8/8 devices are not loading. They are red and set to off in Indigo, and will not load the states or I/O devices in the preference pane popouts.
I looked at the debug (abbreviated):
Phidgets Plugin                 Low level phidgets libs logging stopped
   Phidgets Plugin                 Log level preferences are set to "Debug".
   Phidgets Plugin                 Phidgets plugin preferences have been updated.
   Reloading plugin "Phidgets Plugin 0.7.4" using API v1.0.0
   Stopping plugin "Phidgets Plugin 0.7.4" (pid 49475)
   Phidgets Plugin ifKit           Thread init killed for: Phidgets 8/8/8 TempHumidity
   Phidgets Plugin ifKit           Thread init killed for: Phidgets 8/8/8 Water Valves
   Stopped plugin "Phidgets Plugin 0.7.4"
   Starting plugin "Phidgets Plugin 0.7.4" (pid 49508)
   Phidgets Plugin                 Plugin attach wait time = 10.
   Started plugin "Phidgets Plugin 0.7.4"
   Phidgets Plugin                 Plugin Startup.
   Phidgets Plugin Debug           versionCheck() called
   Phidgets Plugin                 url:http://yikes.com/plugins/Phidgets.html
   Phidgets Plugin                 Your plugin version, v0.7.4, is current.
   Phidgets Plugin                 startup: pluginId:com.perceptiveautomation.indigoplugin.Phidgets, pluginDisplayName:Phidgets Plugin, pluginVersion:0.7.4, pluginPrefs:Prefs : (dict)
     at0 : 10 (string)
     pl0 : false (bool)
     pl1 : 6 (string)
     pl2 : /var/tmp/phidgetlibs.log (string)
     showDebugInfo1 : 3 (string)
     simpleSeparator0 :  (string)
     simpleSeparator1 :  (string)
     topLabel :  (string)
     v0 :  (string)
     v1 :  (string)
     v2 :  (string)
     v3 :  (string)
   Phidgets Plugin                 Entering deviceStartComm for device: Phidgets 8/8/8 TempHumidity (1650378619 - ifKit)
   Phidgets Plugin                 deviceStartComm: Read device:
address : 127.0.0.1
batteryLevel : None
buttonGroupCount : 0
configured : True
description : 277957 set address to 127.0.0.1
deviceTypeId : ifKit
displayStateId : onOffState
displayStateImageSel : None
displayStateValRaw : online
displayStateValUi : online
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState : offline
folderId : 55617734
     com.indigodomo.indigoserver : (dict)
     com.perceptiveautomation.indigoplugin.Phidgets : (dict)
          address : 127.0.0.1 (string)
          ifKitCommType : IP (string)
          ifKitDigitalInputs :  (string)
          ifKitDigitalOutputs :  (string)
          ifKitIpAddress : 127.0.0.1 (string)
          ifKitIpPort : 5001 (string)
          ifKitModel : 1018 (string)
          ifKitSensorRate_0 : 16 (string)
          ifKitSensorRate_1 : 16 (string)
          ifKitSensorRate_2 : 16 (string)
          ifKitSensorRate_3 : 16 (string)
          ifKitSensorRate_4 : 16 (string)
          ifKitSensorRate_5 : 16 (string)
          ifKitSensorRate_6 : 16 (string)
          ifKitSensorRate_7 : 16 (string)
          ifKitSensorTrigger_0 :  (string)
          ifKitSensorTrigger_1 :  (string)
          ifKitSensorTrigger_2 :  (string)
          ifKitSensorTrigger_3 :  (string)
          ifKitSensorTrigger_4 :  (string)
          ifKitSensorTrigger_5 :  (string)
          ifKitSensorTrigger_6 :  (string)
          ifKitSensorTrigger_7 :  (string)
          ifKitSensors :  (string)
          ifKitSerial : 277957 (string)
          ifKitSerialPort :  (string)
          ratiometric : true (bool)
lastChanged : 2023-03-24 21:25:53
lastSuccessfulComm : 2023-03-24 21:25:53
model : Phidget Interface Kit
name : Phidgets 8/8/8 TempHumidity
ownerProps : com.perceptiveautomation.indigoplugin.Phidgets : (dict)
pluginId : com.perceptiveautomation.indigoplugin.Phidgets
pluginProps : com.perceptiveautomation.indigoplugin.Phidgets : (dict)
protocol : Plugin
remoteDisplay : True
states : States : (dict)
     lastUpdate : 2023-03-24 21:25:53 (string)
     onOffState : online (string)
subModel :
subType :
supportsAllOff : False
supportsOnState : False
supportsStatusRequest : False
version : None
   Phidgets Plugin                 deviceStartComm: Found ifKit device Phidgets 8/8/8 TempHumidity
   Phidgets Plugin ifKit           Thread starting for: Phidgets 8/8/8 TempHumidity
   Phidgets Plugin ifKit           Thread init finished for: Phidgets 8/8/8 TempHumidity
   Phidgets Plugin ifKit           Thread run() called
   Phidgets Plugin ifKit           ifKit thread run() finished error handler declaration
   Phidgets Plugin ifKit           ifKit thread run() finished sensor change handler declaration
   Phidgets Plugin ifKit           ifKit thread run() finished input change handler declaration
   Phidgets Plugin ifKit           ifKit thread run() finished output change handler declaration
   Phidgets Plugin ifKit           ifKit thread run() finished handler declarations
   Phidgets Plugin ifKit           Start attach for device: Phidgets 8/8/8 TempHumidity
   Phidgets Plugin ifKit           Creating interfacekit for serial: 277957
   Phidgets Plugin                 deviceStartComm: Created ifKit thread: device: 1650378619, serial:277957
   Phidgets Plugin ifKit           IfKit thread run() Created the IfKit object
   Phidgets Plugin ifKit           IfKit thread run() set all the handlers
   Phidgets Plugin Debug           Opening phidget object....
   Phidgets Plugin ifKit           IfKit thread run() opened the Phidget device Phidgets 8/8/8 TempHumidity
   Phidgets Plugin                 deviceStartComm: Added type:ifKit, name:Phidgets 8/8/8 TempHumidity, serial:277957
   Phidgets Plugin                 exiting deviceStartComm with:[<_MainThread(MainThread, started 140704480625472)>, <ifkit(Thread-1, started 123145442246656)>]
   Phidgets Plugin                 Entering deviceStartComm for device: Phidgets 8/8/8 Water Valves (1733213442 - ifKit)
address : 127.0.0.1
batteryLevel : None
configured : True
description : 278307 set address to 127.0.0.1
enabled : True
folderId : 55617734
          ifKitDigitalInputs : 8 (string)
          ifKitDigitalOutputs : 8 (string)
          ifKitSensorRateMax_0 : 16 (integer)
          ifKitSensorRateMax_1 : 16 (integer)
          ifKitSensorRateMax_2 : 16 (integer)
          ifKitSensorRateMax_3 : 16 (integer)
          ifKitSensorRateMax_4 : 16 (integer)
          ifKitSensorRateMax_5 : 16 (integer)
          ifKitSensorRateMax_6 : 16 (integer)
          ifKitSensorRateMax_7 : 16 (integer)
          ifKitSensorRateMin_0 : 1000 (integer)
          ifKitSensorRateMin_1 : 1000 (integer)
          ifKitSensorRateMin_2 : 1000 (integer)
          ifKitSensorRateMin_3 : 1000 (integer)
          ifKitSensorRateMin_4 : 1000 (integer)
          ifKitSensorRateMin_5 : 1000 (integer)
          ifKitSensorRateMin_6 : 1000 (integer)
          ifKitSensorRateMin_7 : 1000 (integer)
          ifKitSensorTrigger_0 : 10 (string)
          ifKitSensorTrigger_1 : 10 (string)
          ifKitSensorTrigger_2 : 10 (string)
          ifKitSensorTrigger_3 : 10 (string)
          ifKitSensorTrigger_4 : 10 (string)
          ifKitSensorTrigger_5 : 10 (string)
          ifKitSensorTrigger_6 : 10 (string)
          ifKitSensorTrigger_7 : 10 (string)
          ifKitSensors : 8 (string)
          ifKitSerial : 278307 (string)
lastChanged : 2023-03-24 21:25:35
lastSuccessfulComm : 2023-03-24 21:25:35
name : Phidgets 8/8/8 Water Valves
protocol : Plugin
     lastUpdate : 2023-03-24 21:25:35 (string)
subModel :
subType :
version : None
   Phidgets Plugin                 deviceStartComm: Found ifKit device Phidgets 8/8/8 Water Valves
   Phidgets Plugin ifKit           Thread starting for: Phidgets 8/8/8 Water Valves
   Phidgets Plugin ifKit           Thread init finished for: Phidgets 8/8/8 Water Valves
   Phidgets Plugin ifKit           Start attach for device: Phidgets 8/8/8 Water Valves
   Phidgets Plugin ifKit           Creating interfacekit for serial: 278307
   Phidgets Plugin                 deviceStartComm: Created ifKit thread: device: 1733213442, serial:278307
   Phidgets Plugin ifKit           IfKit thread run() opened the Phidget device Phidgets 8/8/8 Water Valves
   Phidgets Plugin                 deviceStartComm: Added type:ifKit, name:Phidgets 8/8/8 Water Valves, serial:278307
   Phidgets Plugin                 exiting deviceStartComm with:[<_MainThread(MainThread, started 140704480625472)>, <ifkit(Thread-1, started 123145442246656)>, <ifkit(Thread-2, started 123145448062976)>]
   Phidgets Plugin                 Entering deviceStartComm for device: Phidgets Relay A House Valve Close (23085881 - phDoIfKit)
address : Phidgets 8/8/8 |do 0
batteryLevel : None
buttonConfiguredCount : 0
configured : True
description : Digital Output 0 Yellow
deviceTypeId : phDoIfKit
displayStateImageSel : PowerOff
displayStateValRaw : False
displayStateValUi : off
enabled : True
errorState :
folderId : 55617734
          address : Phidgets 8/8/8 |do 0 (string)
          buttonFlagDo : false (bool)
          phDoIfKitId : 1733213442 (string)
          phDoIfKitModel : phDoIfKit (string)
          phDoIfKitOutput : 0 (string)
          phDoIfKitSerial : 277957 (string)
lastChanged : 2023-05-29 17:44:29
lastSuccessfulComm : 2023-05-29 17:44:29
ledStates : []
model : InterfaceKit Digital Output
name : Phidgets Relay A House Valve Close
onState : False
protocol : Plugin
     lastUpdate : 2023-03-24 19:25:57 (string)
subModel :
subType :
supportsOnState : True
supportsStatusRequest : True
version : None
   Phidgets Plugin                 Added Digital Output: Phidgets Relay A House Valve Close
   Phidgets Plugin                 Added Output entry: ifKitDevice:277957, port:0, = 23085881
   Phidgets Plugin                 deviceStartComm: Added type:phDoIfKit, name:Phidgets Relay A House Valve Close, serial:Digital Input on 277957 index 0
   Phidgets Plugin                 Entering deviceStartComm for device: Phidgets Relay A House Valve Open (92152270 - phDoIfKit)
address : Phidgets 8/8/8 |do 1
batteryLevel : None
configured : True
description : Digital Output 1 Green
enabled : True
errorState :
folderId : 55617734
          address : Phidgets 8/8/8 |do 1 (string)
          phDoIfKitOutput : 1 (string)
lastChanged : 2023-03-24 19:25:57
lastSuccessfulComm : 2023-03-24 19:25:57
ledStates : []
name : Phidgets Relay A House Valve Open
onState : False
protocol : Plugin
subModel :
subType :
version : None
continues for the rest of the defined devices.....
version : None
   Phidgets Plugin                 Added Sensor: TH CrawlSp 3 Game Rm Humidity
   Phidgets Plugin                 Added sensor entry: ifKitDevice:277957, port:4, = {'model': u'1125h', 'id': 761629564}
   Phidgets Plugin                 deviceStartComm: Added type:phIfKitSensor, name:TH CrawlSp 3 Game Rm Humidity, serial:Analog Sensor on 277957 index 4
   Phidgets Plugin                 Entering deviceStartComm for device: TH CrawlSp 3 Game Rm Temp (1877267478 - phIfKitSensor)
address : Phidgets 8/8/8 TempHumidity |a 5
batteryLevel : None
configured : True
description :
deviceTypeId : phIfKitSensor
displayStateId : state
displayStateValRaw : 63.0
displayStateValUi : 63
enabled : True
errorState :
folderId : 55617734
          address : Phidgets 8/8/8 TempHumidity |a 5 (string)
          buttonFlagSensor : false (bool)
          cVal1 :  (string)
          cVal2 :  (string)
          decimalPlaces : 0 (string)
          phIfKitSensorModel : 1125t (string)
          phSensorIfKitAnalogInput : 5 (string)
          phSensorIfKitId : 1650378619 (string)
          phSensorIfKitSerial : 277957 (string)
          phTemp1 : fh (string)
lastChanged : 2023-03-24 21:12:49
lastSuccessfulComm : 2023-03-24 21:12:49
model : InterfaceKit Sensor
name : TH CrawlSp 3 Game Rm Temp
     cVal1 :  (string)
     cVal2 :  (string)
     cVal1 :  (string)
     cVal2 :  (string)
protocol : Plugin
     lastUpdate : 2023-03-24 21:12:49 (string)
     state : 63 (real)
     temperature : 63 (real)
subModel :
subType :
version : None
   Phidgets Plugin                 Added Sensor: TH CrawlSp 3 Game Rm Temp
   Phidgets Plugin                 Added sensor entry: ifKitDevice:277957, port:5, = {'model': u'1125t', 'id': 1877267478}
   Phidgets Plugin                 deviceStartComm: Added type:phIfKitSensor, name:TH CrawlSp 3 Game Rm Temp, serial:Analog Sensor on 277957 index 5
   Phidgets Plugin                 Entering runConcurrentThread
   Phidgets Plugin Error           interfaceKit: Could not attach to device Phidgets 8/8/8 TempHumidity. It has been set to offline
   Phidgets Plugin Error           interfaceKit: Could not attach to device Phidgets 8/8/8 Water Valves. It has been set to offline
To me it seems the plugin is working fine and seeing the boards. If that is the case, I wonder why it doesn't work? is that a Phidgets Lib issue, Ventura or Indigo 2022.2?
Please help if you can. This is an important part of my system.... :-)
Fri Jun 02, 2023 12:14 am
berkinet offline
hamw wrote:
Hi Berkinet,
Can you see the devices through the Phidgets control panel?
Fri Jun 02, 2023 5:01 am
hamw offline
here are a couple of photos... I think the plugin is working but not sure about the Phidgets Lib.
Here is a little automated behavior to turn on and off an unused output for. a trigger..,
 Phidgets Plugin                 Entering actionControlDimmerRelay for device: Phidgets Relay B No Longer Used Close/0 (1277650443 - phDoIfKit)
   Phidgets Plugin                 metaMode:TurnOn
   Phidgets Plugin ifKit           Entered writeDigitalOutput: device: Phidgets 8/8/8 Water Valves, Set index:2 to True, pulseLength: 0
   Phidgets Plugin ifKit Error     writeDigitalOutput: device: Phidgets 8/8/8 Water Valves is not attached. Cannot set index:2
   Phidgets Plugin                 sent "Phidgets Relay B No Longer Used Close/0" on
   Phidgets Plugin                 Entering didDeviceCommPropertyChange for device: Phidgets Relay B No Longer Used Close/0 (1277650443 - phDoIfKit)
   Phidgets Plugin                 didDeviceCommPropertyChange: No plugin property changes for: phDoIfKit Phidgets Relay B No Longer Used Close/0
   Phidgets Plugin                 metaMode:TurnOff
   Phidgets Plugin ifKit           Entered writeDigitalOutput: device: Phidgets 8/8/8 Water Valves, Set index:2 to False, pulseLength: 0
   Phidgets Plugin                 sent "Phidgets Relay B No Longer Used Close/0" off
   Received INSTEON                "Thermostat GameRm" temperature changed to 74.0
Maybe I need to roll back the Mac OS or install Ph Lib 22? if Ph 22, I guess it will recognize and control an 8/8/8 so I don't have buy new VINT devices? Does one just recreate the devices and re-point the action/triggers to the new devices?
Ph Webserver.png (69.91 KiB) Viewed 2666 times
Fri Jun 02, 2023 7:45 am
berkinet offline
The Ph22 libs won't make any difference if you are running the Ph21 libs on the Phidgets server. Are your Phidhets connected directly to the Mac?
But, what you need to look in the Bonjour tab of the Control Panel to see if your ifKit appears there.
Fri Jun 02, 2023 12:01 pm
hamw offline
Phidgets are connected directly to the Mac. I think this is the image you need?
Thanks again!
Ph Pane Not Seen.png (181.1 KiB) Viewed 2646 times
Fri Jun 02, 2023 12:22 pm
hamw offline
I went to settings on the IF kit and tried to do a read. It timed out. Here is the debug:
Phidgets Plugin                 Entered getIfKitList: %s
   Phidgets Plugin                 getIfKitList found ifKit: 0999a
   Phidgets Plugin                 getIfKitList found ifKit: 0999b
   Phidgets Plugin                 getIfKitList found ifKit: 0999c
   Phidgets Plugin                 getIfKitList found ifKit: 1010
   Phidgets Plugin                 ifKit:1010, descr:1010 - PhidgetInterfaceKit 8/8/8 Mini-Format
   Phidgets Plugin                 getIfKitList found ifKit: 1011
   Phidgets Plugin                 ifKit:1011, descr:1011 - PhidgetInterfaceKit 2/2/2
   Phidgets Plugin                 getIfKitList found ifKit: 1012
   Phidgets Plugin                 ifKit:1012, descr:1012 - PhidgetInterfaceKit 0/16/16
   Phidgets Plugin                 getIfKitList found ifKit: 1013
   Phidgets Plugin                 ifKit:1013, descr:1013 - PhidgetInterfaceKit 8/8/8 w/2 Port Hub (D)
   Phidgets Plugin                 getIfKitList found ifKit: 1014
   Phidgets Plugin                 ifKit:1014, descr:1014 - PhidgetInterfaceKit 0/0/4
   Phidgets Plugin                 getIfKitList found ifKit: 1015
   Phidgets Plugin                 getIfKitList found ifKit: 1016
   Phidgets Plugin                 getIfKitList found ifKit: 1017
   Phidgets Plugin                 ifKit:1017, descr:1017 - PhidgetInterfaceKit 0/0/8 (D)
   Phidgets Plugin                 getIfKitList found ifKit: 1018
   Phidgets Plugin                 ifKit:1018, descr:1018 - PhidgetInterfaceKit 8/8/8
   Phidgets Plugin                 getIfKitList found ifKit: 1019
   Phidgets Plugin                 ifKit:1019, descr:1019 - PhidgetInterfaceKit 8/8/8 w/6 Port Hub
   Phidgets Plugin                 getIfKitList found ifKit: 1023
   Phidgets Plugin                 getIfKitList found ifKit: 1045
   Phidgets Plugin                 getIfKitList found ifKit: 1048
   Phidgets Plugin                 getIfKitList found ifKit: 1051
   Phidgets Plugin                 getIfKitList found ifKit: 1054
   Phidgets Plugin                 getIfKitList found ifKit: 1070
   Phidgets Plugin                 ifKit:1070, descr:1070 - PhidgetSBC (D)
   Phidgets Plugin                 getIfKitList found ifKit: 1072
   Phidgets Plugin                 ifKit:1072, descr:1072 - PhidgetSBC2
   Phidgets Plugin                 getIfKitList found ifKit: 1101a
   Phidgets Plugin                 getIfKitList found ifKit: 1101b
   Phidgets Plugin                 getIfKitList found ifKit: 1101c
   Phidgets Plugin                 getIfKitList found ifKit: 1102
   Phidgets Plugin                 getIfKitList found ifKit: 1103
   Phidgets Plugin                 getIfKitList found ifKit: 1104
   Phidgets Plugin                 getIfKitList found ifKit: 1106
   Phidgets Plugin                 getIfKitList found ifKit: 1108
   Phidgets Plugin                 getIfKitList found ifKit: 1109
   Phidgets Plugin                 getIfKitList found ifKit: 1111
   Phidgets Plugin                 getIfKitList found ifKit: 1112
   Phidgets Plugin                 getIfKitList found ifKit: 1113
   Phidgets Plugin                 getIfKitList found ifKit: 1115
   Phidgets Plugin                 getIfKitList found ifKit: 1116
   Phidgets Plugin                 getIfKitList found ifKit: 1120a
   Phidgets Plugin                 getIfKitList found ifKit: 1120b
   Phidgets Plugin                 getIfKitList found ifKit: 1120c
   Phidgets Plugin                 getIfKitList found ifKit: 1121
   Phidgets Plugin                 getIfKitList found ifKit: 1122
   Phidgets Plugin                 getIfKitList found ifKit: 1124
   Phidgets Plugin                 getIfKitList found ifKit: 1125h
   Phidgets Plugin                 getIfKitList found ifKit: 1125t
   Phidgets Plugin                 getIfKitList found ifKit: 1126
   Phidgets Plugin                 getIfKitList found ifKit: 1127
   Phidgets Plugin                 getIfKitList found ifKit: 1128
   Phidgets Plugin                 getIfKitList found ifKit: 1129
   Phidgets Plugin                 getIfKitList found ifKit: 1130
   Phidgets Plugin                 getIfKitList found ifKit: 1131
   Phidgets Plugin                 getIfKitList found ifKit: 1132
   Phidgets Plugin                 getIfKitList found ifKit: 1133
   Phidgets Plugin                 getIfKitList found ifKit: 1134
   Phidgets Plugin                 getIfKitList found ifKit: 1135
   Phidgets Plugin                 getIfKitList found ifKit: 1142
   Phidgets Plugin                 getIfKitList found ifKit: 1143
   Phidgets Plugin                 getIfKitList found ifKit: 1202
   Phidgets Plugin                 ifKit:1202, descr:1202 - PhidgetTextLCD 20X2 : Blue : Integrated PhidgetInterfaceKit 8/8/8
   Phidgets Plugin                 getIfKitList found ifKit: 1203
   Phidgets Plugin                 ifKit:1203, descr:1203 - PhidgetTextLCD 20X2 : White : Integrated PhidgetInterfaceKit 8/8/8
   Phidgets Plugin                 getIfKitList found ifKit: 1204
   Phidgets Plugin                 getIfKitList found ifKit: 3130
   Phidgets Plugin                 getIfKitList found ifKit: 3500
   Phidgets Plugin                 getIfKitList found ifKit: 3501
   Phidgets Plugin                 getIfKitList found ifKit: 3502
   Phidgets Plugin                 getIfKitList found ifKit: 3503
   Phidgets Plugin                 getIfKitList found ifKit: 3507
   Phidgets Plugin                 getIfKitList found ifKit: 3508
   Phidgets Plugin                 getIfKitList found ifKit: 3510
   Phidgets Plugin                 getIfKitList found ifKit: 3511
   Phidgets Plugin                 getIfKitList found ifKit: 3512
   Phidgets Plugin                 getIfKitList found ifKit: 3513
   Phidgets Plugin                 getIfKitList found ifKit: 3514
   Phidgets Plugin                 getIfKitList found ifKit: 3515
   Phidgets Plugin                 getIfKitList found ifKit: 3516
   Phidgets Plugin                 getIfKitList found ifKit: 3517
   Phidgets Plugin                 getIfKitList found ifKit: 3518
   Phidgets Plugin                 getIfKitList found ifKit: 3519
   Phidgets Plugin                 getIfKitList found ifKit: phDiIfKit
   Phidgets Plugin                 getIfKitList found ifKit: phDoIfKit
   Phidgets Plugin                 Entering readIfKitConfig
   Phidgets                        readIfKitConfig valuesDict received: UiValuesDict : (dict)
     ifKitConfig :  (string)
     ifKitSerial : 277967 (string)
     phLabel1 :  (string)
     phLabel2 :  (string)
     phLabel3a :  (string)
     phLabel3b :  (string)
     phLabel3c :  (string)
     phLabel4a :  (string)
     phLabel4b :  (string)
     phLabel4c :  (string)
     phSeparator1 :  (string)
   Phidgets Plugin                 readIfKitConfig typeId:
ifKit
   Phidgets Plugin                 readIfKitConfig devId:
1650378619
   Phidgets Plugin                 No existing ifkit found. Creating new ifkit
   Phidgets Plugin                 Opening ifkit....
   Phidgets Plugin                 calling openRemoteIP (ip=127.0.0.1 , port=5001)
   Phidgets Plugin                 calling openRemoteIP completed (ip=127.0.0.1 , port=5001)
   Phidgets                        pre waitForAttach (ip=127.0.0.1 , port=5001)
   Error (client)                  timeout waiting for plugin response from com.perceptiveautomation.indigoplugin.Phidgets for request UiAction
   Phidgets                        Execption raised on waitForAttach (ip=127.0.0.1 , port=5001)
   Phidgets Plugin Error           Phidget Exception b (ip=127.0.0.1 , port=5001) 13: Given timeout has been exceeded.
   Phidgets Plugin Error           Phidget Exception d (ip=127.0.0.1 , port=5001) 5: Phidget not physically attached.
   Phidgets                        Sensors:0, inputs:0, outputs:0
   Phidgets Plugin                 New ifkit closed
   Phidgets Plugin                 ifkit read was successful
   Phidgets Plugin                 readIfKitConfig valuesDict returned: UiValuesDict : (dict)
     ifKitDigitalInputs : 0 (integer)
     ifKitDigitalOutputs : 0 (integer)
     ifKitSensors : 0 (integer)
     phLabel1 :  (string)
     phLabel2 :  (string)
Ph Comm w Plugin TimeOut.png (208.71 KiB) Viewed 2641 times
Fri Jun 02, 2023 12:25 pm
berkinet offline
It really looks like the Phidgetsd installation is failing in some manner. If there c control panel cannot see the ifKit, it cannot polish it to other services, like the Plugin. Have you tried calling Phiodgets tech support? They are usually pretty helpful.
Fri Jun 02, 2023 12:35 pm
hamw offline
I will give them a call… Thanks…
Sat Jul 01, 2023 2:32 pm
hamw offline
Well, to make it easy, I reverted my computer back to Big Sur and roll back Indigo to 2021.2. Everything is working.
It’s too bad that upgrades break things.
Sat Aug 12, 2023 1:05 pm
mpleeds offline
I'm considering upgrading to Ventura and wondering if anyone else has encountered problems (or success) with Phidgets plugin running under this OS? Also, any confirmation as to whether the plugin is compatible with 2022.2+ (Python 3)?
Fri Aug 18, 2023 7:05 am
berkinet offline
Unfortunately, I have no plans to upgrade this plug-in to python 3. The major issue is, Phidgets has dropped support and development for Phidgets 2.1. So, there really is no future. And the major effort required to convert to Python3 is just not be worth the effort .
If someone would like to take it over, I would be glad to assist. The other option is to switch to the new Phidgets22 plug-in.
Fri Aug 18, 2023 8:04 am
hamw offline
If I upgrade to Phidgets library 22, do I then need to upgrade to the new Phidgets VINT devices or can I keep my same old 8/8/8 I/O boards?
What is involved in going from 21 libs to 22 libs? Creating a new IF Kit device for each existing IF Kit? Then reassign the existing devices to the new Phidgets 22 IF kits?
Fri Aug 18, 2023 9:06 am
berkinet offline
You can keep all of your old devices with the 2.2 libs. However, while the 2.2 plugin will support all your devices, the phillosophy is quite different from the old plugin. The 2.2 plugin follows the 2.2 mo]device model.
