- Posted on
Thu Jan 01, 2015 10:28 am
tjm000
offline
I've been updating my home automation system over the holidays. I purchased a new MacMini and also a Phidgets Digitial IO board (1018_2 - PhidgetInterfaceKit 8/8/8). I hooked it up a couple of weeks ago and got everything working. I've got one analog sensor (temp) and 5 digital inputs (door sensors) connected. I interfaced it into some scripts that I have for checking the open/close status of my doors. Things were working as expected for a couple of weeks.
Starting yesterday I noticed that the Phidgets board is listed as being "offline" in red type. I checked the Phidgets monitor panel in System Preferences on the MacMini and everything seems OK. I can see the status of the door sensors working properly and also a reasonable value for the analog temp sensor.
I tried to enable/disable the Phidgets plugin a couple of times but that didn't make a difference, the plugin is still listed as offline. I then turned on the extensive logging capability and captured the attached log file as I enabled and then disabled the plugin.
Note that yesterday I had made another update to my MacMini that included installing the WeatherSnoop3 plugin and USB serial driver for my Davis Vantage Pro2 weather station. I had to fix the SuperCap in the weather station and so it had been offline for the past few months. I had originally installed the Phidgets plugin without the WeatherSnoop3 plugin when I had first gotten the Phidget to work. I disabled the WeatherSnoop3 plugin to see if that made a difference but the Phidgets plugin still stays offline.
Any ideas on what could be wrong?
Thanks.
Tim
Here' the log file:
Jan 1, 2015, 11:02:29 AM
Enabling plugin "Phidgets Plugin 0.6.5"
Starting plugin "Phidgets Plugin 0.6.5" (pid 4456)
Phidgets Plugin Log level preferences are set to "Intense Debug".
Started plugin "Phidgets Plugin 0.6.5"
Phidgets Plugin Plugin Startup.
Phidgets Plugin Debug versionCheck() called
Phidgets Plugin url:http://yikes.com/plugins/Phidgets.html
Phidgets Plugin Your plugin version, v0.6.5, is current.
Phidgets Plugin Entering phidgetsLibLoggingControl
Phidgets Plugin logging: True, logLevel: 1, logFile: /Users/timm/Documents/phidgetlibs.log
Phidgets Plugin Low level phidgets libs logging started at level 1 to file /Users/timm/Documents/phidgetlibs.log
Phidgets Plugin startup: pluginId:com.perceptiveautomation.indigoplugin.Phidgets, pluginDisplayName:Phidgets Plugin, pluginVersion:0.6.5, pluginPrefs:Prefs : (dict)
pl0 : true (bool)
pl1 : 1 (string)
pl2 : /Users/timm/Documents/phidgetlibs.log (string)
showDebugInfo1 : 4 (string)
simpleSeparator1 : (string)
topLabel : (string)
v0 : (string)
v1 : (string)
v2 : (string)
v3 : (string)
Phidgets Plugin Entering deviceStartComm for device: BTemp (1106110202 - phIfKitSensor)
Phidgets Plugin deviceStartComm: Read device:
address : Phid888 |a 0
batteryLevel : None
buttonGroupCount : 0
configured : True
description : Basement Temp
deviceTypeId : phIfKitSensor
displayStateId : state
displayStateValRaw : 64.0
displayStateValUi : 64.0
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 1175255907
com.perceptiveautomation.indigoplugin.Phidgets : (dict)
address : Phid888 |a 0 (string)
buttonFlagSensor : false (bool)
cVal1 : (string)
cVal2 : (string)
decimalPlaces : 1 (string)
phIfKitSensorModel : 1124 (string)
phSensorIfKitAnalogInput : 0 (string)
phSensorIfKitId : 1776438066 (string)
phSensorIfKitSerial : 315957 (string)
phTemp1 : fh (string)
lastChanged : 2014-12-25 20:16:18
model : InterfaceKit Sensor
pluginId : com.perceptiveautomation.indigoplugin.Phidgets
pluginProps : com.perceptiveautomation.indigoplugin.Phidgets : (dict)
cVal1 : (string)
cVal2 : (string)
protocol : Plugin
remoteDisplay : True
states : States : (dict)
lastUpdate : 2014-12-25 20:16:18 (string)
state : 64.0 (real)
temperature : 64.0 (real)
subModel :
supportsAllOff : False
supportsStatusRequest : False
version : 0
Phidgets Plugin Added Sensor: BTemp
Phidgets Plugin Added sensor entry: ifKitDevice:315957, port:0, = {'model': u'1124', 'id': 1106110202}
Phidgets Plugin deviceStartComm: Added type:phIfKitSensor, name:BTemp, serial:Analog Sensor on 315957 index 0
Phidgets Plugin exiting deviceStartComm with:[<_MainThread(MainThread, started -1595813420)>]
Phidgets Plugin Entering deviceStartComm for device: FamRm Deck Door (1250742925 - phDiIfKit)
address : Phid888 |di 2
batteryLevel : None
configured : True
description :
deviceTypeId : phDiIfKit
displayStateId : onOffState
displayStateValRaw : True
displayStateValUi : on
enabled : True
errorState :
address : Phid888 |di 2 (string)
buttonFlagDi : false (bool)
phDiIfKitId : 1776438066 (string)
phDiIfKitInput : 2 (string)
phDiIfKitModel : phDiIfKit (string)
phDiIfKitSerial : 315957 (string)
model : InterfaceKit Digital Input
name : FamRm Deck Door
protocol : Plugin
onOffState : on (on/off bool)
subModel :
version : 0
Phidgets Plugin Added Digital Input: FamRm Deck Door
Phidgets Plugin Added Input entry: ifKitDevice:315957, port:2, = 1250742925
Phidgets Plugin deviceStartComm: Added type:phDiIfKit, name:FamRm Deck Door, serial:Digital Output on 315957 index 2
Phidgets Plugin Entering deviceStartComm for device: FamRm Right Door (1457490337 - phDiIfKit)
address : Phid888 |di 0
batteryLevel : None
configured : True
description :
enabled : True
errorState :
address : Phid888 |di 0 (string)
phDiIfKitInput : 0 (string)
name : FamRm Right Door
protocol : Plugin
subModel :
version : 0
Phidgets Plugin Added Digital Input: FamRm Right Door
Phidgets Plugin Added Input entry: ifKitDevice:315957, port:0, = 1457490337
Phidgets Plugin deviceStartComm: Added type:phDiIfKit, name:FamRm Right Door, serial:Digital Output on 315957 index 0
Phidgets Plugin Entering deviceStartComm for device: Front Door (367486289 - phDiIfKit)
address : Phid888 |di 4
batteryLevel : None
configured : True
description :
enabled : True
errorState :
address : Phid888 |di 4 (string)
phDiIfKitInput : 4 (string)
lastChanged : 2014-12-26 15:53:55
protocol : Plugin
lastUpdate : 2014-12-26 15:53:55 (string)
subModel :
version : 0
Phidgets Plugin Added Digital Input: Front Door
Phidgets Plugin Added Input entry: ifKitDevice:315957, port:4, = 367486289
Phidgets Plugin deviceStartComm: Added type:phDiIfKit, name:Front Door, serial:Digital Output on 315957 index 4
Phidgets Plugin Entering deviceStartComm for device: Kitchen Door (1966479723 - phDiIfKit)
address : Phid888 |di 3
batteryLevel : None
configured : True
description :
enabled : True
errorState :
address : Phid888 |di 3 (string)
phDiIfKitInput : 3 (string)
lastChanged : 2014-12-31 10:42:55
protocol : Plugin
lastUpdate : 2014-12-31 10:42:55 (string)
subModel :
version : 0
Phidgets Plugin Added Digital Input: Kitchen Door
Phidgets Plugin Added Input entry: ifKitDevice:315957, port:3, = 1966479723
Phidgets Plugin deviceStartComm: Added type:phDiIfKit, name:Kitchen Door, serial:Digital Output on 315957 index 3
Phidgets Plugin Entering deviceStartComm for device: oBasement Door (4256342 - phDiIfKit)
address : Phid888 |di 1
batteryLevel : None
configured : True
description :
enabled : True
errorState :
address : Phid888 |di 1 (string)
phDiIfKitInput : 1 (string)
lastChanged : 2014-12-31 12:23:36
protocol : Plugin
lastUpdate : 2014-12-31 12:23:36 (string)
subModel :
version : 0
Phidgets Plugin Added Digital Input: oBasement Door
Phidgets Plugin Added Input entry: ifKitDevice:315957, port:1, = 4256342
Phidgets Plugin deviceStartComm: Added type:phDiIfKit, name:oBasement Door, serial:Digital Output on 315957 index 1
Phidgets Plugin Entering deviceStartComm for device: Phid888 (1776438066 - ifKit)
address : 127.0.0.1
batteryLevel : None
configured : True
description : Purchased 2014 12
deviceTypeId : ifKit
displayStateValRaw : online
displayStateValUi : online
enabled : True
errorState : offline
address : 127.0.0.1 (string)
ifKitCommType : USB (string)
ifKitDigitalInputs : 8 (string)
ifKitDigitalOutputs : 8 (string)
ifKitIpAddress : 127.0.0.1 (string)
ifKitIpPort : 5001 (string)
ifKitModel : 1018 (string)
ifKitSensorRate_0 : 500 (string)
ifKitSensorRate_1 : 500 (string)
ifKitSensorRate_2 : 500 (string)
ifKitSensorRate_3 : 500 (string)
ifKitSensorRate_4 : 500 (string)
ifKitSensorRate_5 : 500 (string)
ifKitSensorRate_6 : 500 (string)
ifKitSensorRate_7 : 500 (string)
ifKitSensorTrigger_0 : 10 (string)
ifKitSensorTrigger_1 : 10 (string)
ifKitSensorTrigger_2 : 10 (string)
ifKitSensorTrigger_3 : 10 (string)
ifKitSensorTrigger_4 : 10 (string)
ifKitSensorTrigger_5 : 10 (string)
ifKitSensorTrigger_6 : 10 (string)
ifKitSensorTrigger_7 : 10 (string)
ifKitSensors : 8 (string)
ifKitSerial : 315957 (string)
ifKitSerialPort : /dev/cu.usbserial-A6004uO2 (string)
ratiometric : true (bool)
model : Phidget Interface Kit
protocol : Plugin
onOffState : online (string)
subModel :
version : 0
Phidgets Plugin deviceStartComm: Found ifKit device Phid888
Phidgets Plugin ifKit Thread starting for: Phid888
Phidgets Plugin ifKit Thread init finished for: Phid888
Phidgets Plugin ifKit Thread run() called
Phidgets Plugin ifKit ifKit thread run() finished error handler declaration
Phidgets Plugin ifKit ifKit thread run() finished sensor change handler declaration
Phidgets Plugin ifKit ifKit thread run() finished input change handler declaration
Phidgets Plugin ifKit ifKit thread run() finished output change handler declaration
Phidgets Plugin ifKit ifKit thread run() finished handler declarations
Phidgets Plugin ifKit Start attach for device: Phid888
Phidgets Plugin deviceStartComm: Created ifKit thread: device: 1776438066, serial:315957
Phidgets Plugin deviceStartComm: Added type:ifKit, name:Phid888, serial:315957
Phidgets Plugin exiting deviceStartComm with:[<ifkit(Thread-1, started -1337315328)>, <_MainThread(MainThread, started -1595813420)>]
Phidgets Low level phidgets libs logging started for device Phid888 at level 1 to file /Users/timm/Documents/phidgetlibs.log
Phidgets Plugin ifKit Creating interfacekit for serial: 315957
Phidgets Plugin ifKit IfKit thread run() Created the IfKit object
Phidgets Plugin ifKit IfKit thread run() set all the handlers
Phidgets Plugin Debug Opening phidget object....
Phidgets Plugin ifKit IfKit thread run() opened the Phidget device
Phidgets Plugin Entering runConcurrentThread
Phidgets Plugin ifKit Entered interfaceKitError for device: Phid888
Phidgets Plugin Error interfaceKit: Wait for Attach time exceeded for device Phid888
Phidgets Plugin Error interfaceKit: Will continue waiting for 15 minutes
Disabling plugin "Phidgets Plugin 0.6.5"
Stopping plugin "Phidgets Plugin 0.6.5" (pid 4456)
Phidgets Plugin Entering stopConcurrentThread
Phidgets Plugin Exiting stopConcurrentThread
Phidgets Plugin Entering deviceStopComm for device: BTemp (1106110202 - phIfKitSensor)
Phidgets Plugin deviceStopComm: deleted sensor: BTemp
Phidgets Plugin exiting deviceStopComm
Phidgets Plugin Entering deviceStopComm for device: FamRm Deck Door (1250742925 - phDiIfKit)
Phidgets Plugin deviceStopComm: deleted digital input: FamRm Deck Door
Phidgets Plugin Entering deviceStopComm for device: FamRm Right Door (1457490337 - phDiIfKit)
Phidgets Plugin deviceStopComm: deleted digital input: FamRm Right Door
Phidgets Plugin Entering deviceStopComm for device: Front Door (367486289 - phDiIfKit)
Phidgets Plugin deviceStopComm: deleted digital input: Front Door
Phidgets Plugin Entering deviceStopComm for device: Kitchen Door (1966479723 - phDiIfKit)
Phidgets Plugin deviceStopComm: deleted digital input: Kitchen Door
Phidgets Plugin Entering deviceStopComm for device: oBasement Door (4256342 - phDiIfKit)
Phidgets Plugin deviceStopComm: deleted digital input: oBasement Door
Phidgets Plugin Entering deviceStopComm for device: Phid888 (1776438066 - ifKit)
Phidgets Plugin ifKit Thread init killed for: Phid888
Phidgets Plugin deviceStopComm: stopped thread for: Phid888
Stopped plugin "Phidgets Plugin 0.6.5"
Tim
