lochnesz wrote:Is this plugin still under development? Thanks!
philc wrote:Don't have time to go into a lot of detail right now - but installing APCUPSD on the Mac is a little bit of voodoo. As Berkinet points out, the website is extremely technical and very unhelpful for non-programming types. Short version is download the dmg and install. Then you have to wrestle the config file, which is locked, so you have to unfornicate the permissions first, then make the changes, then save it. And it is in a hidden folder, so you have to find it.
Probably could have been implemented more easily, but for free software that allows so much flexibility, I can't complain too loudly.
Try the install, then write back with any problems you have.
Phil
haavarda wrote:...When I set up the trigger I can select to trigger if battery is below limit. But where do I set this limit?
Has this something to do with the daemon ?...
