apcupsd Error Error in plugin execution CalcDeviceFunc:
File "plugin.py", line 622, in getDeviceStateList
<type 'exceptions.AttributeError'>: 'Plugin' object has no attribute 'server'
File "plugin.py", line 611, in getDeviceDisplayStateId
philc wrote:apcupsd Error Error in plugin execution CalcDeviceFunc:
UPSNAME Cellar_UPS
UPSCABLE usb
UPSTYPE usb
DEVICE
POLLTIME 60
LOCKFILE /var/tmp
SCRIPTDIR /etc/apcupsd
PWRFAILDIR /etc/apcupsd
NOLOGINDIR /var/run
ONBATTERYDELAY 30
BATTERYLEVEL 25
MINUTES 20
TIMEOUT 0
ANNOY 300
ANNOYDELAY 60
NOLOGON disable
KILLDELAY 0
NETSERVER on
NISIP 0.0.0.0
NISPORT 3551
EVENTSFILE /var/log/apcupsd.events
EVENTSFILEMAX 10
UPSCLASS standalone
UPSMODE disable
STATTIME 0
STATFILE /var/log/apcupsd.status
LOGSTATS off
DATATIME 0
0.4.2
Version: 0.5.0
EmailSubject: apcupsd Indigo Plugin Update
EmailBody: This is a minor bug release for the apcupsd Plugin.
The changes are:
- "added version update notification"
The update can be downloaded at the link below.
https://dl.dropboxusercontent.com/u/503 ... -0-4-2.zip
This email was sent to you by Indigo at the request of the plugin. You will only be emailed once per release.
To disable these emails see the apcupsd plugin's config. is available.
philc wrote:...Catching this in the log...0.4.2
Version: 0.5.0
EmailBody: This is a minor bug release for the apcupsd Plugin….
vasisht wrote:did you configure the plugin and set the log level?...
apcupsd Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 194, in runConcurrentThread
<type 'exceptions.AttributeError'>: 'Plugin' object has no attribute 'logLevel'
apcupsd Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Did I miss something?
