Can get this to work! Looking for instructions on how to connected to a JSON source with bearer authentication.
Any help would be greatly appreciate it.
JP
DaveL17 wrote:Just to make sure I understand, you're looking to chart directly from a JSON data source? That's not possible with the plugin. It only works with CSV data sources.
FlyingDiver wrote:DaveL17 wrote:Just to make sure I understand, you're looking to chart directly from a JSON data source? That's not possible with the plugin. It only works with CSV data sources.
Which is why I gave him a link to saving the JSON data to CSV.
roquej wrote:I just thought about using the GhostXML plugin to write data to a file or using variable before charting. I wonder if it works with bearer auth...need to try that.
