Chart Not Drawing
Sat Oct 10, 2020 7:48 pm
jltnol offline
Chart Not Drawing
Hey Dave
You had been a big help awhile ago while I was trying to get a Bar Chart to work. We.... You ended up with some python code to manually write the CVS files for my project, and those files were used to draw the bar chart.
I'm now trying to do a new bar chart, so have re-used the same python code as before to create the CVS files. As far as I can tell, the CVS files are being written correctly. I've opened both the new files and some of the still-in-use older ones with Numbers, and the fields look exactly the same.
But for some reason, the new bar chart png isn't being drawn, and I get this error code:
 Matplotlib Warning              [C-Rain Bar] zero-size array to reduction operation minimum which has no identity. See plugin log for more information.
   Matplotlib Debug                [C-Server Temp & Humidity] [C-Server Temp & Humidity] X axis label is suppressed to make room for the chart legend.
The X-Axis debug comes up with several charts so don't think that it is the problem. No doubtI've got something wrong somewhere, but if you could just point me in the right direction of were to look, I'm guessing I can track down my error.
Sun Oct 11, 2020 5:29 am
Re: Chart Not Drawing
The second line isn't an error -- all that's saying is that you have filled the X-Axis label field and also asked for a chart legend to be plotted. Given the nature of the plots, the plugin can't do both and is not plotting the axis label (and letting you know why). The first one is trying to tell us what the problem is, and we need to examine the plugin log for more information. Take a look at the file located at (adjust the Indigo version number for your situation if needed):
/Library/Application Support/Perceptive Automation/Indigo 7.4/Logs/com.fogbert.indigoplugin.matplotlib/
and post the complete error message. Also, please post the script you're using to generate the data for the new chart.
Sun Oct 11, 2020 11:47 am
jltnol offline
I'm attaching the log, and here is the script for writing the CVS files:
rain = indigo.variables[1938961]
inches = "{:.3f}".format(float(rain.value) *.03937) #coverts mm to inches
indigo.variable.updateValue(1852577407, inches) #updates inches variable
csv_path = '/Users/bradford/MatPlotLib/'  # put your CSV Engine data path here
values = {
    'RainToday': ('1970-01-01 00:00:00.000000,', indigo.variables[1852577407].value),  # change these variable ids to match yours
    'RainYesterday': ('1970-01-02 00:00:00.000000,', indigo.variables[35080668].value),
    'RainThisWeek': ('1970-01-03 00:00:00.000000,', indigo.variables[986779847].value),
    'RainThisMonth': ('1970-01-04 00:00:00.000000,', indigo.variables[1385001124].value),
   'RainLastMonth': ('1970-01-05 00:00:00.000000,', indigo.variables[1169660509].value),
for key in values.keys():
    with open(csv_path + key + ".csv", 'w') as outfile:
        outfile.write("Timestamp," + key + "\n")
        outfile.write(values[key][0] + values[key][1])
just a note that in Indigo, the "Rain Last Month line in Indigo is perfectly aligned with the lines above... no extraneous spaces, just tabs. And this is exactly as the last set of scripts you helped me with on another bar graph project.
And here is the log while manually re-drawing all charts:
Oct 11, 2020 at 12:33:12 PM
   Matplotlib                      [Battery Chart] Chart updated successfully.
   Matplotlib                      [C-24 Hour Polar Wind] Chart updated successfully.
   Matplotlib Debug                [C-24 Hour Rain] [C-24 Hour Rain] X axis label is suppressed to make room for the chart legend.
   Matplotlib                      [C-24 Hour Rain] Chart updated successfully.
   Matplotlib Debug                [C-24 Hour wind Line] [C-24 Hour wind Line] X axis label is suppressed to make room for the chart legend.
   Matplotlib                      [C-24 Hour wind Line] Chart updated successfully.
   Matplotlib Debug                [C-48 Temp & Humidity] [C-48 Temp & Humidity] X axis label is suppressed to make room for the chart legend.
   Matplotlib                      [C-48 Temp & Humidity] Chart updated successfully.
   Matplotlib Debug                [C-AC Cycle Bar Chart] [C-AC Cycle Bar Chart] X axis label is suppressed to make room for the chart legend.
   Matplotlib                      [C-AC Cycle Bar Chart] Chart updated successfully.
   Matplotlib Debug                [C-AC Times Bar Chart] [C-AC Times Bar Chart] X axis label is suppressed to make room for the chart legend.
   Matplotlib                      [C-AC Times Bar Chart] Chart updated successfully.
   Matplotlib                      [C-Server Temp & Humidity] Chart updated successfully.
   Matplotlib                      [Ran LineB] Chart updated successfully.
   Matplotlib                      ==================== Redraw Charts Now Menu Action Complete ====================
Thanking you in advance for your help.
plugin.log
(262.11 KiB) Downloaded 159 times
plugin.log.2020-10-10.txt
(401.94 KiB) Downloaded 164 times
Sun Oct 11, 2020 12:31 pm
The critical bit from the log is this:
2020-10-10 23:52:51.510   CRITICAL     Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2020-10-10 23:52:51.511   CRITICAL     Plugin.pluginErrorHandler           !!! Traceback (most recent call last):
2020-10-10 23:52:51.511   CRITICAL     Plugin.pluginErrorHandler           !!!   File "plugin.py", line 3451, in chart_bar
2020-10-10 23:52:51.512   CRITICAL     Plugin.pluginErrorHandler           !!!     width = np.min(np.diff(p_dict['x_obs{0}'.format(thing)])) * 0.8
2020-10-10 23:52:51.512   CRITICAL     Plugin.pluginErrorHandler           !!!   File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/numpy/core/fromnumeric.py", line 2214, in amin
2020-10-10 23:52:51.513   CRITICAL     Plugin.pluginErrorHandler           !!!     out=out, keepdims=keepdims)
2020-10-10 23:52:51.514   CRITICAL     Plugin.pluginErrorHandler           !!!   File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/numpy/core/_methods.py", line 21, in _amin
2020-10-10 23:52:51.515   CRITICAL     Plugin.pluginErrorHandler           !!!     out=out, keepdims=keepdims)
2020-10-10 23:52:51.515   CRITICAL     Plugin.pluginErrorHandler           !!! ValueError: zero-size array to reduction operation minimum which has no identity
2020-10-10 23:52:51.515   CRITICAL     Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
or more specifically, this bit:
that line of code should only be reached if you have the bar width set to 0 (zero). With that setting, the plugin tries to judge how wide to set the bars by itself based on the dates in the CSV data. So it could be that something about the dates in your data file isn't quite right and causing the plugin to get confused.
Can you attach the CSV file to this thread as a text file? Also, please ensure that there is a valid value in the bar width field (zero should be among the valid options).
Sun Oct 11, 2020 5:27 pm
jltnol offline
Hey Dave
Of course you were exactly right I had mostly left the plugin settings for the graph as they were, and am 99% sure I had exactly the same issue last time I tried to work with bar graphs, but just didn't go back to those posts to check. I've got it working now, and sorry for mostly wasting your time.
Cheers
Sun Oct 11, 2020 6:51 pm
That's great news. Thanks for letting me know.
I've included some additional safety around that setting thanks to your question (which will be included in the next release).
Mon Oct 12, 2020 9:07 am
jltnol offline
and if I may offer just a tiny suggestion... my current bar graph project is measuring rain fall. Sometimes there is a lot... most of the time, there isn't any at all. When the CVS values are 0, the bar disappears as there is no data to display. So sometimes my 4 bar graph has only 3 or 2 or 1 bars, and when that happens, they take up the available space. The "3 of 4" is what happens now when one of the data fields is "0", but the 4 of 4 is what I think would make more sense.
Cheers
4 of 4 bars.png (69.8 KiB) Viewed 3831 times
3of 4 bars.png (68.74 KiB) Viewed 3831 times
Mon Oct 12, 2020 4:54 pm
I understand completely what you're looking for. I'll have to dig into the code to see what's going on, but I doubt that I purposefully removed the bar for zero values (can't swear to that at the moment, though). Depending on your circumstance, you may be able to "trick" the chart by changing the zero value to something super tiny (like 0.0001) in the CSV data--but that's a kludge for sure.
I'll see what I can do.
Mon Oct 12, 2020 5:35 pm
jltnol offline
Already done!
Tue Oct 13, 2020 7:27 am
Had some time to do a little research on this. Apparently, it's a matplotlib "feature". Consider this:
#! /usr/bin/env python
# -*- coding: utf-8 -*-
import matplotlib
import matplotlib.pyplot as plt
x = [1, 2, 3]
y = [0, 4, 6]
plt.bar(x,y)
plt.show()
This simple plot yields:
In order to force spots for all values, we can force the x axis to show them:
import matplotlib
x = [1, 2, 3]
y = [0, 4, 6]
plt.bar(x,y)
plt.xlim([x[0], len(x)+1])
plt.show()
Thus:
I would suspect that this is a matter of taste and it would likely be better as an option. I will look to add an additional setting so we can elect to force them to show.
Tue Oct 13, 2020 8:32 am
jltnol offline
I agree that for some people in some situations, the option would be a good idea. This would probably be ideal but also seems like a lot more work for you.
Tue Oct 13, 2020 9:20 am
Not that much work honestly. The "hard" part is to not break existing stuff. :D
Tue Oct 13, 2020 12:10 pm
jltnol offline
Understood
I know nothing about coding, but please let me know if there is any other way I can help you in this process.
Tue Oct 13, 2020 2:45 pm
Thanks for the offer, but I should be good from here.
Fri Oct 23, 2020 10:35 pm
jltnol offline
So this is a little weird.
I manually changed the CVS files for Bar #2 and Bar #3 to 0, and when the chart redrew, I still have spacing for all 4 bars....
