First, absolutely no need to apologize! Its only because of the tireless efforts of people like you that make Indigo fun for people like me. Your efforts are very much appreciated! The charts and graphs have been working perfectly since I started using them awhile ago, and just recently did some updating and made a few changes, and ran into this problem.
Here is the log:- Code: Select all
2020-09-23 09:41:03.807 DEBUG Plugin.processLogQueue [AC Cycle Bar Chart] [AC Cycle Bar Chart] X axis label is suppressed to make room for the chart legend.
2020-09-23 09:41:03.807 INFO Plugin.processLogQueue [AC Cycle Bar Chart] Chart updated successfully.
2020-09-23 09:41:04.045 DEBUG Plugin.processLogQueue [AC Run Times Bar Chart] [AC Run Times Bar Chart] X axis label is suppressed to make room for the chart legend.
2020-09-23 09:41:04.046 INFO Plugin.processLogQueue [AC Run Times Bar Chart] Chart updated successfully.
2020-09-23 09:41:04.348 INFO Plugin.processLogQueue [Battery Chart] Chart updated successfully.
2020-09-23 09:41:04.486 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2020-09-23 09:41:04.487 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2020-09-23 09:41:04.487 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 3858, in chart_line
2020-09-23 09:41:04.488 CRITICAL Plugin.pluginErrorHandler !!! temp_list.append(self.host_plugin.evalExpr.eval_expr(expr))
2020-09-23 09:41:04.489 CRITICAL Plugin.pluginErrorHandler !!! File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/matplotlib.indigoPlugin/Contents/Server Plugin/DLFramework/DLFramework.py", line 230, in eval_expr
2020-09-23 09:41:04.489 CRITICAL Plugin.pluginErrorHandler !!! return self.eval_(ast.parse(expr, mode='eval').body)
2020-09-23 09:41:04.489 CRITICAL Plugin.pluginErrorHandler !!! File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/matplotlib.indigoPlugin/Contents/Server Plugin/DLFramework/DLFramework.py", line 236, in eval_
2020-09-23 09:41:04.490 CRITICAL Plugin.pluginErrorHandler !!! return self.operators[type(node.op)](self.eval_(node.left), self.eval_(node.right))
2020-09-23 09:41:04.490 CRITICAL Plugin.pluginErrorHandler !!! File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/matplotlib.indigoPlugin/Contents/Server Plugin/DLFramework/DLFramework.py", line 240, in eval_
2020-09-23 09:41:04.491 CRITICAL Plugin.pluginErrorHandler !!! raise TypeError(node)
2020-09-23 09:41:04.491 CRITICAL Plugin.pluginErrorHandler !!! TypeError: <_ast.Name object at 0x10b460890>
2020-09-23 09:41:04.492 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2020-09-23 09:41:04.494 WARNING Plugin.processLogQueue [C RAIN All] <_ast.Name object at 0x10b460890>. See plugin log for more information.
2020-09-23 09:41:04.780 DEBUG Plugin.processLogQueue [C-12 hour wind] [C-12 hour wind] X axis label is suppressed to make room for the chart legend.
2020-09-23 09:41:04.781 INFO Plugin.processLogQueue [C-12 hour wind] Chart updated successfully.
2020-09-23 09:41:05.134 DEBUG Plugin.processLogQueue [C-48 Wind] [C-48 Wind] X axis label is suppressed to make room for the chart legend.
2020-09-23 09:41:05.135 INFO Plugin.processLogQueue [C-48 Wind] Chart updated successfully.
2020-09-23 09:41:05.314 INFO Plugin.processLogQueue [C-Polar Wind Chart] Chart updated successfully.
2020-09-23 09:41:05.598 DEBUG Plugin.processLogQueue [C-Rain] [C-Rain] X axis label is suppressed to make room for the chart legend.
2020-09-23 09:41:05.599 INFO Plugin.processLogQueue [C-Rain] Chart updated successfully.
2020-09-23 09:41:05.935 DEBUG Plugin.processLogQueue [C-Server Temp & Humidity] [C-Server Temp & Humidity] X axis label is suppressed to make room for the chart legend.
2020-09-23 09:41:05.936 INFO Plugin.processLogQueue [C-Server Temp & Humidity] Chart updated successfully.
2020-09-23 09:41:06.407 DEBUG Plugin.processLogQueue [C-Solar] [C-Solar] X axis label is suppressed to make room for the chart legend.
2020-09-23 09:41:06.407 INFO Plugin.processLogQueue [C-Solar] Chart updated successfully.
2020-09-23 09:41:07.005 DEBUG Plugin.processLogQueue [C-Temp & Humidity] [C-Temp & Humidity] X axis label is suppressed to make room for the chart legend.
2020-09-23 09:41:07.006 INFO Plugin.processLogQueue [C-Temp & Humidity] Chart updated successfully.
2020-09-23 09:41:07.008 INFO Plugin.refresh_the_charts_now ==================== Redraw Charts Now Menu Action Complete ====================
From the Python CommandSep 23, 2020 at 9:32:03 AM
Script address :
batteryLevel : None
buttonGroupCount : 0
configured : True
description :
deviceTypeId : csvEngine
displayStateId : onOffState
displayStateImageSel : SensorOn
displayStateValRaw : True
displayStateValUi : Updated
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 81224377
com.fogbert.indigoplugin.matplotlib : (dict)
addKey : (string)
addSource : (string)
addSourceFilter : A (string)
addState : (string)
addValue : (string)
columnDict : {u'k10': (u'Rain Hammond daily rain accum final', u'1940074503', u'daily_rain_accumulation_final'), u'k3': (u'RAIN Bradofrd Precpit RAIN', u'1720470760', u'precipitation_type.rain'), u'k2': (u'RAIN-BRAdford Prect Type', u'1720470760', u'precipitation_type'), u'k1': (u'RAIN-Bradford Precip', u'1720470760', u'precipitation'), u'k7': (u'Rain Hammond Precipt anayysis', u'1940074503', u'precipitation_analysis_type'), u'k6': (u'Rain Hammond Precip', u'1940074503', u'precipitation'), u'k5': (u'Rain Hammond Last Precipt formatted', u'1940074503', u'last_precip_formatted'), u'k4': (u'Rain Hammond Last Precip', u'1940074503', u'last_precip'), u'k9': (u'Rain Hammond Rain Accum Final', u'1940074503', u'rain_accumulated_final'), u'k8': (u'Rain Hammond-Precitp Type', u'1940074503', u'precipitation_type')} (string)
csv_item_list : (string)
editKey : (string)
editSource : (string)
editSourceFilter : A (string)
editState : (string)
editValue : (string)
isChart : false (bool)
isColumnSelected : true (bool)
numLinesToKeep : 300 (string)
numLinesToKeepTime : 0 (string)
previousKey : k2 (string)
refreshInterval : 450 (string)
lastChanged : 2020-09-23 09:30:17
lastSuccessfulComm : 2020-09-23 09:30:17
model : CSV Engine Device
ownerProps : com.fogbert.indigoplugin.matplotlib : (dict)
addKey : (string)
addState : (string)
addValue : (string)
editKey : (string)
pluginId : com.fogbert.indigoplugin.matplotlib
protocol : Plugin
remoteDisplay : True
states : States : (dict)
csvLastUpdated : 2020-09-23 09:30:17.446553 (string)
onOffState : true (bool)
onOffState.ui : Updated (string)
subModel :
supportsAllOff : False
supportsStatusRequest : False
version : None
Just let me know if you need any more information.
