Need help with plots
Tue Apr 21, 2020 7:08 pm
farberm offline
I have created three variables: hourlyGallonscurrent, gallonscurrent, and priorhourlygallons
At the beginning of each hour (starting at 1 AM) I get the counter value from my water counter (I have checked this and its working properly) and then calculate the difference in the counter value from the prior hour. Then the difference is placed into hourly gallons used and then that value is used for the next hours "priorhour" calculation. I then update the gallons current for that hour to be the total for the day up to that point. At midnight I zero out the values and start again the next day
I am attempting to create two charts:
1) shows an hourlyusage throughout the day,
For the hours chart I used hourlygallonscurrent as the variable refreshed every hour with 24 bars, scale every day. What I get is figure in light blue below (First figure). What I want is figure similar to dark green hourly chart below (Figure 2)?
2) a monthly chart showing the total used each day. I am plotting gallonscurrent
For the daily chart I am plotting gallonsused refreshed everyday with 31 bars and scale every month. What I get is the bars in lt blue (larger plot) - Figure 3.
I want the plot below that shows things in days as one bar total for the day. If the plot is generated in the middle of the day then I want the gallons used so far for the day to be shown like the monthly chart below - Figure4.
I must be doing something basically wrong but not sure what?
Screen Shot 2020-04-21 at 8.52.04 PM.png (42.9 KiB) Viewed 4172 times
Screen Shot 2020-04-21 at 8.41.35 PM.png (36.14 KiB) Viewed 4172 times
Screen Shot 2020-04-21 at 8.57.58 PM.png (77.1 KiB) Viewed 4172 times
Screen Shot 2020-04-21 at 8.41.42 PM.png (39.64 KiB) Viewed 4172 times
Tue Apr 21, 2020 8:16 pm
Re: Need help with plots
Happy to try to help. Bar charts are a little different than other chart types due to the fact that they don't do a great job of displaying a ton of observations. That is not to say that you're trying to plot too many--rather, it explains why bar chart settings are handled so differently. For the sake of argument, I'll assume that your data files are properly configured:
Timestamp,column name
2020-04-18 21:07:55.449262,66.4
2020-04-18 21:23:09.511970,66.1
2020-04-18 21:38:23.964526,66.4
2020-04-18 21:53:38.086074,66.1
2020-04-18 22:08:52.838145,65.8
2020-04-18 22:24:06.786853,65.8
2020-04-18 22:39:20.730052,65.7
2020-04-18 22:54:34.931717,65.7
Taking your first example, if your CSV data looks like this:
2020-04-18 07:07:55.449262,42
2020-04-18 21:23:09.511970,96
Then I believe what Matplotlib is doing is interpolating the intermediate bars. I think what you'll want is a data file that looks like this:
2020-04-18 08:07:55.449262,0
2020-04-18 09:07:55.449262,0
2020-04-18 19:07:55.449262,0
2020-04-18 20:07:55.449262,0
I think the same might be the case for your second example. If I've somehow missed the mark, please share some examples of your data and it'll help me better visualize what's going on.
Wed Apr 22, 2020 3:14 pm
farberm offline
Dave:
Thanks for your help. Here is the csv snapshot. The number are not going to zero for the hours when no water usage used. If there is a better way to show water usage than bar graphs please enlighten me so I can use it. I just need to know which hours it is being used and how much each hour and each day. I have included a snapshot of my configuration for daily and hourly. Interestingly enough I can get Grafana to work somewhat, just that the data is shifted incorrectly. In other word the bars are all 1 hour too late and the day graph is one day too late I would have thought that for the 21 of April the water used would post to that day but instead it posts to the 22? (I have included that graph also. The blue and pourple chart is from grafana not MAtplot...
Thanks again fro your help.
Screen Shot 2020-04-22 at 5.09.19 PM.png (116.77 KiB) Viewed 4125 times
Screen Shot 2020-04-22 at 5.10.24 PM.png (120.55 KiB) Viewed 4125 times
Screen Shot 2020-04-22 at 5.12.57 PM.png (50.82 KiB) Viewed 4125 times
Screen Shot 2020-04-22 at 5.05.32 PM.png (191.35 KiB) Viewed 4125 times
Screen Shot 2020-04-22 at 5.06.05 PM.png (149.4 KiB) Viewed 4125 times
Wed Apr 22, 2020 5:32 pm
It's a little confusing for sure, but the settings in the plugin work a little differently than you might expect.
The X and Y settings are meant to format and scale the axes, but they don't directly impact the data that's displayed. When you set the number of bars to 24, the plot is going to take the last 24 observations from the data set. If you want to plot 24 hours with one bar per hour, then you'll need to save your data every hour. What you're getting is the last 24 observations (6 hours).
Does that makes sense?
Wed Apr 22, 2020 7:44 pm
farberm offline
So if I take readings every hour and want 24 hours worth of data on 1 bar
So No of Bars 1, Under X axis Scale every hour, days to show 31, but this only give me one day?
Getting closer. This is correct for just the day
Now how do I get all 31 days of the month on one chart?
This chart gave me just one day for the month.
Ok I reset the data input so now I will wait and recheck tomorrow and see the result. thanks for your help. and we will see if Ihave it correct tomorrow
Screen Shot 2020-04-22 at 9.40.30 PM.png (37.36 KiB) Viewed 4104 times
Screen Shot 2020-04-22 at 9.40.50 PM.png (113.61 KiB) Viewed 4104 times
Wed Apr 22, 2020 8:17 pm
The plugin doesn't do any combining of observations--like distilling hourly observations into a daily value--so you'll have to do that when saving the data to CSV. Setting the number of bars to 1 will just plot the latest single observation in the CSV file.
Say your data file contains the following:
timestamp,value
2020-04-01 00:00:00.000000,123
2020-04-02 00:00:00.000000,456
2020-04-03 00:00:00.000000,789
2020-04-28 00:00:00.000000,123
2020-04-29 00:00:00.000000,456
2020-04-30 00:00:00.000000,789
If you set the number of bars to 1, you'll just get the data for 4/30.
Fri Apr 24, 2020 2:44 pm
farberm offline
ok Nearly perfect. Here is the hourly plot working almost like I need it except for two issues. The data is from MN to 1609 pm, but it only start charting the data from the first value grater than 0? Also the data is off by one hour, for example at 11:20 there was 5.5 gallons used, at 12:08 pm there was 17.5 gallon, 1:34 19 gallons used and at 3:56 pm there was 54 gallons used. The plot is plotting them for the following hour instead of the hour they occurred in. Also how do I get the hours of 0 plotted. See csv and plot, settings.
Screen Shot 2020-04-24 at 4.42.29 PM.png (149.53 KiB) Viewed 4063 times
Screen Shot 2020-04-24 at 4.42.16 PM.png (66.28 KiB) Viewed 4063 times
Screen Shot 2020-04-24 at 4.37.25 PM.png (92.21 KiB) Viewed 4063 times
Screen Shot 2020-04-24 at 4.31.47 PM.png (66.81 KiB) Viewed 4063 times
Fri Apr 24, 2020 3:58 pm
With respect to the plugin not plotting the leading zero values, I'll need to look into that some more. This is not something that I actively sought to do, and it may be a default behavior of Matplotlib. There may be a way for me to override this behavior. Let me see what I can do.
Regarding the plot being off by an hour, what I'm seeing is that the chart is showing what the data are showing. The data is showing 5.5 gallons at 12:09 and the chart is showing 5.5 at 12:09 (the bar is centered on the plot time). Are you generating the CSV data with the plugin?
Fri Apr 24, 2020 4:14 pm
farberm offline
Maybe if I let it go another day it will post the zero values as it did for 3 oo? I will wait and see. Any suggestions on how to plot the data another way other than bar graph to post the consumption for the prior hour?
Fri Apr 24, 2020 4:33 pm
farberm offline
Dave one other thought, can I force the plugin to check at a certain time. Ie if I check at 1:59,,2:59 .... the. It would
Likely post in the correct hour. Right now it’s checking at 08 which is probably the time I start the plugin
Fri Apr 24, 2020 5:04 pm
There is no setting to key the refresh time in the CSV engine to a certain time. It does indeed proceed from the last time it was restarted.
Fri Apr 24, 2020 5:08 pm
farberm offline
Maybe I can make a schedule to start every night at 11:59 pm. That would work for both the day and hours plots
Fri Apr 24, 2020 5:17 pm
That would work, but it would drift over time. Restarting every day would probably keep the drift to a minimum.
Getting all CSV data to refresh on a precise schedule within the plugin is non-trivial because the devices "get in line" for their refreshes.
Sat Apr 25, 2020 5:42 am
After doing some research on this, it does indeed appear that Matplotlib skips plotting leading zero values when drawing bar charts. There's some debate as to whether it's a bug or a feature, but nonetheless, it is reality. The chart below was constructed by setting the first value in the series to something very small (in this case 0.1) such that the bar is plotted but effectively not visible. Note that I also changed the scale of the X axis bins to every four hours to make the axis labels more readable.
I will look into whether an optional setting could be created to adjust the data slightly such that the user can elect to have leading zero values plotted (or not), or somehow force the chart to display the desired timeline regardless of the values of the data.. Stay tuned.
Sat Apr 25, 2020 6:47 am
farberm offline
Thanks... I could always set the default value to 0.01 and then add, that way it is never zero. One other option I was thinking about was doing some scripting...
What I ideally want to do is display a calendar and the user selects a day from the calendar. The script gets the 24 values for that day (plus the first entry for the next day) from the csv file and creates a new file used to plat data ( I actually would get 25 data points.) I would then manipulate the data to delete the first data point and then plot the next 24 data points as each nours consumption. That would cause a shift in data to one hour earlier. I think it would work that way but I will need to elicit my niece for help to do the python programming cuz it will be far beyond my capabilities. I am trying to replace my failing irrigation caddy watering system -(see below) I do not know if there is a way to look at the operating programming on the irrigation caddy. I tried to contact the developer - no response) It has a web interface but not sure how to download the programming behind it. No API published that I can find.
Screen Shot 2020-04-25 at 8.42.08 AM.png (101.45 KiB) Viewed 3986 times
