Bar Graph Question
Mon Jun 10, 2019 6:48 pm
jltnol offline
Re: Bar Graph Question
Dave
The script you so graciously provided is doing its job. There are 4 new files, they all have 1 entry in them and look exactly like your example. As a test, I manually changed the values in the variables to random numbers, and manually triggered the schedule, and the values from the variable are put into the 4 files exactly as they should
I've got a bit more customization to do on the graph display, but here's what I've got (FYI, these are "fake" numbers) but clearly this does the trick!
I can't possibly thank you enough for getting this to work, as this is exactly what I was looking for.
And for the record, I do understand exactly what is happening in the script... pulling the numbers from the variables, using the 1970 part as a 'filler" , and re-writing/over-writing the CVS files every time the schedule runs. But my understanding is an ocean away from being able to make it happen. . I have no idea how hard this would be to incorporate in the the CVS Engine... perhaps a "special" engine that does just this one entry per file, but it may be helpful to others.
Again, THANKS!!
Mon Jun 10, 2019 8:08 pm
Good deal. I tested the code and it should be good to go (with your modifications) but if something doesn't work for some reason, I'm happy to help trouble shoot.
Mon Jun 10, 2019 8:11 pm
That's awesome. I'm glad that you're finding the plugin useful.
I'll add your suggestion to the feature request list.
Cheers!
Wed Jun 12, 2019 3:24 pm
jltnol offline
And as a side note, I just found out you can set up an action to re-draw charts, so I moved the re-draw function out of the schedule and to the tail end of a series of triggers involving the AC. And, I might add, was able to adapt your script for another chart, and am considering other uses for this as well.
Thanks again.
Wed Jun 12, 2019 6:16 pm
That's great. Thanks for letting me know. Hopefully your approach will be useful to other users of the plugin too.
