Good. Now we're getting someplace. I have added validation back in to ensure that users select at least two forecast elements, which will be in the next build.
- Making a precipitation bar chart option should be a fairly light lift. I think it makes sense to make it another option in the plot element list:
- Total Precipitation (Bar)
- Total Precipitation (Line)
- That one is a bit trickier. It's obviously possible, but I'm struggling to think of a way to set limits for five (could be more later) distinct ranges without overpowering the UI [temp, humidity, pressure, wind, precip]. My initial suggestion would be to have an expandable section for min/max where you could set ranges for each type of plot. At least that way you can hide them away when not in use. Let me mull this one for a bit.
I'm also working on a feature which (if successful) will allow an import of settings from another (similar) chart device -- in other words, when creating a new line chart device, you'd be able to copy the settings over from an established line chart device. This was a feature request and a dern good one if I can make it work properly.
- Screen Shot 2019-07-25 at 10.45.56 PM.png (22.6 KiB) Viewed 5629 times
