Feature Requests
Sat Sep 09, 2017 10:49 pm
kmarkley offline
Feature Requests
I have two small feature requests:
1. Convert boolean data to 0/1 so it can be plotted. Would be nice if it also handled several of the common text-boolean-equivalents (up/down, on/off, locked/unlocked, true/false, etc).
2. Linear transformations with multiplier and offset (e.g. <datum> * X + Y). Offset would be especially helpful for plotting multiple boolean values. Multiplier is nice for unit conversion or just getting two plotlines in the same neighborhood if actual value is less important than trend or correlation.
I made this plot with variables and a whole mess of triggers, but it would be cleaner if it could be done in the plugin.
Thanks.
Screen Shot 2017-09-09 at 11.36.08 PM.png (442.27 KiB) Viewed 3659 times
Sun Sep 10, 2017 5:48 am
Re: Feature Requests
Thanks.
HI - thanks for using the plugin.
These are both great suggestions, and I will add them to the list. I've been doing some house cleaning of all my plugins and have plans to take a deep dive on Matplotlib and on OWServer next.
Tue Jan 30, 2018 1:46 pm
Thanks.
It's taken me longer than I expected, but both of these suggestions will be in the next update.
I've added a converter so that these values will be converted to chartable boolean values:
        converter = {'true': 1,
                     'false': 0,
                     'open': 1,
                     'closed': 0,
                     'on': 1,
                     'off': 0,
                     'locked': 1,
                     'unlocked': 0,
                     'up': 1,
                     'down': 0,
                     '1': 1,
                     '0': 0,
                     '-99': 'NaN'}
A note on the last one. -99 is a value used in the WUnderground plugin to denote a "nonsense" value. NaN (Not a Number) should now be skipped rather than charted as -99. If you have other state values not reflected above, please let me know as they're easily added.
I've added linear transformations to the line chart device type (which seems like the only one needing it, but am open to other types) which will allow individual adjustments to be made to each line based on simple math expressions. So, for example, line 1 could be plotted as real and line two could be plotted as [ <datum> * X ] or [ <datum> + Y ] or [ <datum> * X + Y ]. The adjustment should be able to handle all "normal" mathematical operations but I expect [addition, subtraction, multiplication, division, and exponents] to be the most common. So your chart above should be easily recreated using:
Line 1
Line 2 + 2
Line 3 + 4
Line 4 + 6
Thanks again for the great suggestions. Hang tight for a forthcoming update after some more regression testing (there's lot's more changes under the hood.)
EDIT: better example for adjustment factor. See example below.
Tue Jan 30, 2018 9:10 pm
Just a quick follow-up. Testing goes well. This chart was created using only the (forthcoming) line charting device type. Obviously charting the same data four times, but with adjustments applied.
Line 1 + 1 (to move it off the x axis)
Line 2 + 3
Line 3 + 5
Line 4 + 7
Tue Apr 10, 2018 2:32 pm
Athassel offline
I love both of these new features!
Any chance to be able to plot more than 4 lines/graph in an update?
Many thanks for this and the other plugins of yours, they are really great.
Tue Apr 10, 2018 3:52 pm
Thanks for the kind words! You scared me for a bit and I had to go look at whether I had actually released those features. :D Your message was well timed. While waiting for bug reports to roll in on the latest update to the WUnderground plugin, I have started looking at the Matplotlib plugin.
Adding more lines is a bit of a double-edged sword. I should be able to add 1 or 2 more lines without much bother, but the notion of something like a dynamic number of lines would be extremely tough (given the hoops I jump through to make the charts look nice). Would 1 or 2 more lines work for you?
Another option that you might try that others have used is layering charts with transparent backgrounds. Set up two devices with the same settings and plot lines 5-8 on the second chart. Then put both charts on the same real estate on your control page. This will likely only work well if all the lines will work with the same scale.
Cheers!
Wed Apr 11, 2018 4:07 am
Athassel offline
Good point, I'll try your suggestion with transparent background first!
On a different note, could you put another 'heat': 1 line into the converter with the next update?
My central boiler has a 'heat' state when it's actually 'on'.
Cheers.
Wed Apr 11, 2018 5:33 am
Cheers.
Happy to add 'heat' to the binary converter. Does 'off' work for you as the alternate state?
Let me know how you get on with the overlays.
Wed Apr 11, 2018 1:23 pm
Athassel offline
Will do.
The 'off' state should work as already implemented in the converter.
Thanks.
Fri Jul 20, 2018 8:05 pm
Matplotlib Plugin v0.6.06. Now with more lines. :D
Sun Dec 30, 2018 4:15 pm
Closing this thread down. Please add any feature requests to this thread.
