Looking for Beta Testers
Thu Mar 07, 2019 5:06 pm
Re: Looking for Beta Testers
Busta999 wrote:
Ok
No lockups since I killed the motion tracking, every minute.
Thanks for the work, i’ll not be able to update until next week.
Thanks for reporting back.
I've pushed an additional update which improves garbage collection to better ensure that resource use is kept to a minimum. I' likely to push an official release soon, so you may want to check the Indigo plugin store first.
Sun Mar 10, 2019 6:06 am
Busta999 offline
Just got back hoe after a weekend away
MatPlotib 7.34 froze up at 22:04 last night about 12 hours ago
Stuck at processing Chart Fridge Power and Temp
All Charts pngs stop at between 22:02 and 22:17
ALL csvs halt at 22:17.
MatPllotLib stuck at
2019-03-10 12:01:19.469   INFO         Plugin.processLogQueue              [Chart - Alt Temperature] chart updated successfully.
2019-03-10 12:01:19.957   INFO         Plugin.processLogQueue              [Chart - Broadband Speed Available] chart updated successfully.
2019-03-10 12:01:20.380   INFO         Plugin.processLogQueue              [Chart - Daily Power Usage] chart updated successfully.
2019-03-10 12:01:20.816   INFO         Plugin.processLogQueue              [Chart - Daily Power Usage Lounge] chart updated successfully.
2019-03-10 12:01:21.415   INFO         Plugin.processLogQueue              [Chart - Downstairs Temperature 1] chart updated successfully.
2019-03-10 12:01:21.959   INFO         Plugin.processLogQueue              [Chart - Freezer Power and Temperature] chart updated successfully.
2019-03-10 12:01:22.202   CRITICAL     Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-03-10 12:01:22.203   CRITICAL     Plugin.pluginErrorHandler           !!! Traceback (most recent call last):
2019-03-10 12:01:22.203   CRITICAL     Plugin.pluginErrorHandler           !!!   File "plugin.py", line 5085, in plot_custom_line_segments
2019-03-10 12:01:22.203   CRITICAL     Plugin.pluginErrorHandler           !!!     for element in constants_to_plot:
2019-03-10 12:01:22.203   CRITICAL     Plugin.pluginErrorHandler           !!! TypeError: 'int' object is not iterable
2019-03-10 12:01:22.203   CRITICAL     Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-03-10 12:01:22.204   WARNING      Plugin.plot_custom_line_segments    There is a problem with the custom line segments settings. 'int' object is not iterable. See plugin log for more information.
2019-03-10 12:01:22.367   INFO         Plugin.processLogQueue              [Chart - Fridge Power and Temperature] chart updated successfully.
2019-03-10 12:01:22.732   INFO         Plugin.processLogQueue              [Chart - Fridge Temperature] chart updated successfully.
2019-03-10 12:01:23.079   INFO         Plugin.processLogQueue              [Chart - Fridge-Freezer Power Usage] chart updated successfully.
2019-03-10 12:01:23.515   INFO         Plugin.processLogQueue              [Chart - Fridge-Freezer Temperature] chart updated successfully.
2019-03-10 12:01:23.768   INFO         Plugin.processLogQueue              [Chart - Heating Demand History] chart updated successfully.
2019-03-10 12:01:24.185   INFO         Plugin.processLogQueue              [Chart - Heating Hot Water] chart updated successfully.
2019-03-10 12:01:24.605   INFO         Plugin.processLogQueue              [Chart - Heating Hot Water Tank] chart updated successfully.
2019-03-10 12:01:24.986   INFO         Plugin.processLogQueue              [Chart - Household Power Usage] chart updated successfully.
2019-03-10 12:01:25.821   INFO         Plugin.processLogQueue              [Chart - Key Temperatures] chart updated successfully.
2019-03-10 12:01:26.088   INFO         Plugin.processLogQueue              [Chart - Power Tool Charger] chart updated successfully.
2019-03-10 12:01:26.765   INFO         Plugin.processLogQueue              [Chart - Radiator - Bathroom] chart updated successfully.
2019-03-10 12:01:27.297   INFO         Plugin.processLogQueue              [Chart - Radiator - Guest Bedroom] chart updated successfully.
2019-03-10 12:01:27.825   INFO         Plugin.processLogQueue              [Chart - Radiator - Guest Ensuite] chart updated successfully.
2019-03-10 12:01:28.408   INFO         Plugin.processLogQueue              [Chart - Radiator - Kitchen] chart updated successfully.
2019-03-10 12:01:28.977   INFO         Plugin.processLogQueue              [Chart - Radiator - Lounge Back] chart updated successfully.
2019-03-10 12:01:29.557   INFO         Plugin.processLogQueue              [Chart - Radiator - Lounge Front] chart updated successfully.
2019-03-10 12:01:30.266   INFO         Plugin.processLogQueue              [Chart - Radiator - Master Bed] chart updated successfully.
2019-03-10 12:01:31.183   INFO         Plugin.processLogQueue              [Chart - Radiator - Molly] chart updated successfully.
2019-03-10 12:01:31.628   INFO         Plugin.processLogQueue              [Chart - Radiators Downstairs - Batteries] chart updated successfully.
2019-03-10 12:01:32.191   INFO         Plugin.processLogQueue              [Chart - Radiators Upstairs - Batteries] chart updated successfully.
2019-03-10 12:01:32.981   INFO         Plugin.processLogQueue              [Chart - TRV Battery Chart] chart updated successfully.
2019-03-10 12:01:33.637   INFO         Plugin.processLogQueue              [Chart - Upstairs Temperature 1] chart updated successfully.
2019-03-10 12:01:34.270   INFO         Plugin.processLogQueue              [Chart - Upstairs Temperature 2] chart updated successfully.
2019-03-10 12:01:34.613   INFO         Plugin.processLogQueue              [Chart Mini - Trend Ensuite] chart updated successfully.
2019-03-10 12:01:34.815   INFO         Plugin.processLogQueue              [Chart Mini - Trend Freezer] chart updated successfully.
2019-03-10 12:01:34.980   INFO         Plugin.processLogQueue              [Chart Mini - Trend Fridge] chart updated successfully.
2019-03-10 12:01:35.152   INFO         Plugin.processLogQueue              [Chart Mini - Trend Guest Bedroom] chart updated successfully.
2019-03-10 12:01:35.356   INFO         Plugin.processLogQueue              [Chart Mini - Trend Hallway] chart updated successfully.
2019-03-10 12:01:35.528   INFO         Plugin.processLogQueue              [Chart Mini - Trend Lounge] chart updated successfully.
2019-03-10 12:01:35.690   INFO         Plugin.processLogQueue              [Chart Mini - Trend Master Bedroom] chart updated successfully.
2019-03-10 12:01:35.876   INFO         Plugin.processLogQueue              [Chart Mini - Trend Molly Bedroom] chart updated successfully.
2019-03-10 12:01:36.097   INFO         Plugin.processLogQueue              [Chart Mini - Trend Outdoor Temp] chart updated successfully.
2019-03-10 12:01:36.098   INFO         Plugin.refresh_the_charts_now       ==================== Redraw Charts Now Menu Action Complete ====================
Sun Mar 10, 2019 7:28 am
Thanks for reporting back. Unfortunately, I've still not been able to reproduce this error and you're the only one that's seeing it.
Please install the latest version (v0.7.39) and see if you still have the error. If you still get the error, please open the configuration dialog for these two devices: Chart - Freezer Power and Temperature and Chart - Fridge Power and Temperature and then save them without making any changes and see if that clears the error. If not, please post images of the configuration dialogs for these two devices.
P.S. - I presume that there isn't another device between those two (when viewing your list alphabetically) that doesn't show up in the log. If there is such a device, that's the one that we want to take a look at.
Mon Mar 11, 2019 11:33 am
Busta999 offline
Ok
I have upgraded to 7.39
Continuous issues all day.
Here are two configs
Screenshot 2019-03-11 at 17.03.11.png (205.45 KiB) Viewed 3614 times
Screenshot 2019-03-11 at 17.03.49.png (216.75 KiB) Viewed 3614 times
Mon Mar 11, 2019 11:49 am
Busta999 offline
All charting has ceased.
Or more correctly only one chart is being updated Chart - TRV Battery Chart.png - all others are no longer being created .
I have restarted MatplotLib no error messages in Indigo log :-(
Getting this in the Matplotlib log following a Plugin restart.
2019-03-11 17:44:15.782   INFO         Plugin.refresh_the_charts_now       ==================== Redraw Charts Now Menu Action Complete ====================
2019-03-11 17:45:05.375   DEBUG   Plugin.debugLog:   Initializing DLFramework...
2019-03-11 17:45:05.375   DEBUG        Plugin.pluginEnvironmentLogger      DLFramework pluginEnvironment method called.
2019-03-11 17:45:05.375   INFO         Plugin.pluginEnvironmentLogger
2019-03-11 17:45:05.375   INFO         Plugin.pluginEnvironmentLogger      =================================================== Initializing New Plugin Session ===================================================
2019-03-11 17:45:05.375   INFO         Plugin.pluginEnvironmentLogger      Plugin name:                    Matplotlib
2019-03-11 17:45:05.375   INFO         Plugin.pluginEnvironmentLogger      Plugin version:                 0.7.39
2019-03-11 17:45:05.375   INFO         Plugin.pluginEnvironmentLogger      Plugin ID:                      com.fogbert.indigoplugin.matplotlib
2019-03-11 17:45:05.375   INFO         Plugin.pluginEnvironmentLogger      Indigo version:                 7.2.0
2019-03-11 17:45:05.376   INFO         Plugin.pluginEnvironmentLogger      Python version:                 2.7.10 (default, Feb  7 2017, 00:08:15) [GCC 4.2.1 Compatible Apple LLVM 8.0.0 (clang-800.0.34)]
2019-03-11 17:45:05.378   INFO         Plugin.pluginEnvironmentLogger      Mac OS Version:                 10.12.6
2019-03-11 17:45:05.378   INFO         Plugin.pluginEnvironmentLogger      Process ID:                     18507
2019-03-11 17:45:05.378   INFO         Plugin.pluginEnvironmentLogger      =======================================================================================================================================
2019-03-11 17:45:05.379   THREADDEBUG   Plugin.__init__                     Initializing maintenance framework.
2019-03-11 17:45:05.447   INFO         Plugin.pluginEnvironmentLogger
2019-03-11 17:45:05.447   INFO         Plugin.pluginEnvironmentLogger      ======================================================= Matplotlib Environment ========================================================
2019-03-11 17:45:05.447   INFO         Plugin.pluginEnvironmentLogger      Matplotlib version:             1.3.1
2019-03-11 17:45:05.447   INFO         Plugin.pluginEnvironmentLogger      Numpy version:                  1.8.0rc1
2019-03-11 17:45:05.448   INFO         Plugin.pluginEnvironmentLogger      Matplotlib RC Path:             /Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/matplotlib.indigoPlugin/Contents/Server Plugin/matplotlibrc
2019-03-11 17:45:05.449   INFO         Plugin.pluginEnvironmentLogger      Matplotlib Plugin log location: /Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib
2019-03-11 17:45:05.449   INFO         Plugin.pluginEnvironmentLogger      Number of Chart Devices:        38
2019-03-11 17:45:05.449   INFO         Plugin.pluginEnvironmentLogger      Number of CSV Engine Devices:   3
2019-03-11 17:45:05.449   THREADDEBUG   Plugin.pluginEnvironmentLogger      Matplotlib base rcParams:       {'figure.subplot.right': 0.9, 'animation.frame_format': 'png', 'mathtext.cal': 'cursive', 'font.fantasy': ['Comic Sans MS', 'Chicago', 'Charcoal', 'ImpactWestern', 'fantasy'], 'grid.alpha': 1.0, 'xtick.minor.pad': 4, 'tk.pythoninspect': False, 'pgf.texsystem': 'xelatex', 'svg.fonttype': 'path', 'font.cursive': ['Apple Chancery', 'Textile', 'Zapf Chancery', 'Sand', 'cursive'], 'figure.subplot.hspace': 0.2, 'keymap.fullscreen': ('f', 'ctrl+f'), 'mathtext.bf': 'serif:bold', 'savefig.extension': 'png', 'xtick.direction': 'in', 'axes.facecolor': 'w', 'mathtext.fontset': 'cm', 'animation.mencoder_path': 'mencoder', 'keymap.pan': 'p', 'animation.writer': 'ffmpeg', 'path.snap': True, 'svg.image_inline': True, 'animation.bitrate': -1, 'lines.markersize': 6, 'figure.dpi': 80, 'text.usetex': False, 'image.origin': 'upper', 'patch.edgecolor': 'k', 'legend.labelspacing': 0.5, 'animation.convert_path': 'convert', 'examples.directory': '', 'text.antialiased': True, 'animation.ffmpeg_args': '', 'lines.solid_joinstyle': 'round', 'savefig.bbox': None, 'mathtext.rm': 'serif', 'axes.formatter.limits': [-7, 7], 'xtick.minor.size': 2, 'font.serif': ['Bitstream Vera Serif', 'DejaVu Serif', 'New Century Schoolbook', 'Century Schoolbook L', 'Utopia', 'ITC Bookman', 'Bookman', 'Nimbus Roman No9 L', 'Times New Roman', 'Times', 'Palatino', 'Charter', 'serif'], 'image.cmap': 'jet', 'lines.marker': 'None', 'tk.window_focus': False, 'axes.formatter.use_mathtext': False, 'ytick.major.width': 0.5, 'path.effects': [], 'figure.subplot.wspace': 0.2, 'backend.qt4': 'PyQt4', 'webagg.port_retries': 50, 'axes.xmargin': 0, 'savefig.facecolor': 'w', 'pgf.preamble': [''], 'ytick.minor.size': 2, 'savefig.pad_inches': 0.1, 'font.stretch': 'normal', 'text.dvipnghack': None, 'path.sketch': None, 'savefig.directory': '~', 'figure.subplot.bottom': 0.1, 'ytick.color': 'k', 'image.aspect': 'equal', 'lines.linestyle': '-', 'axes.ymargin': 0, 'xtick.color': 'k', 'savefig.jpeg_quality': 95, 'savefig.frameon': True, 'xtick.major.pad': 10.0, 'patch.facecolor': 'b', 'figure.figsize': [8.0, 6.0], 'axes.linewidth': 1.0, 'backend': 'agg', 'legend.handletextpad': 0.8, 'mathtext.fallback_to_cm': True, 'lines.linewidth': 1.0, 'savefig.dpi': 100, 'font.family': 'sans-serif', 'svg.image_noscale': False, 'docstring.hardcopy': False, 'font.size': 12, 'ps.fonttype': 3, 'path.simplify': True, 'keymap.all_axes': 'a', 'keymap.quit': ('ctrl+w', 'cmd+w'), 'polaraxes.grid': True, 'toolbar': 'toolbar2', 'savefig.edgecolor': 'w', 'animation.mencoder_args': '', 'legend.frameon': True, 'figure.autolayout': False, 'figure.facecolor': '0.75', 'figure.max_open_warning': 20, 'animation.convert_args': '', 'ps.usedistiller': False, 'legend.isaxes': True, 'animation.ffmpeg_path': 'ffmpeg', 'figure.edgecolor': 'w', 'mathtext.tt': 'monospace', 'contour.negative_linestyle': 'dashed', 'savefig.format': 'png', 'axes.formatter.use_locale': False, 'lines.markeredgewidth': 0.5, 'legend.fontsize': 'large', 'keymap.home': ['h', 'r', 'home'], 'axes3d.grid': True, 'legend.scatterpoints': 3, 'axes.edgecolor': 'k', 'lines.solid_capstyle': 'projecting', 'ytick.minor.width': 0.5, 'axes.titlesize': 'large', 'image.interpolation': 'bilinear', 'keymap.zoom': 'o', 'xtick.major.size': 4, 'keymap.xscale': ['k', 'L'], 'animation.avconv_args': '', 'legend.shadow': False, 'mathtext.it': 'serif:italic', 'keymap.save': ('s', 'ctrl+s'), 'font.variant': 'normal', 'text.hinting': True, 'xtick.labelsize': 'medium', 'axes.unicode_minus': True, 'figure.frameon': True, 'text.hinting_factor': 8, 'ps.distiller.res': 6000, 'pdf.compression': 6, 'pdf.fonttype': 3, 'ytick.minor.pad': 4, 'pdf.inheritcolor': False, 'axes.color_cycle': ['b', 'g', 'r', 'c', 'm', 'y', 'k'], 'lines.dash_capstyle': 'butt', 'ytick.direction': 'in', 'figure.subplot.top': 0.9, 'pdf.use14corefonts': False, 'legend.markerscale': 1.0, 'patch.antialiased': True, 'backend_fallback': True, 'font.style': 'normal', 'keymap.forward': ['right', 'v'], 'grid.linewidth': 0.5, 'legend.fancybox': False, 'grid.linestyle': ':', 'axes.labelcolor': 'k', 'text.color': 'k', 'xtick.minor.width': 0.5, 'ps.useafm': False, 'legend.loc': 'upper right', 'interactive': False, 'lines.antialiased': True, 'webagg.port': 8988, 'savefig.orientation': 'portrait', 'axes.axisbelow': False, 'ytick.major.size': 4, 'axes.grid': False, 'pgf.debug': False, 'plugins.directory': '.matplotlib_plugins', 'grid.color': 'k', 'ytick.major.pad': 5.0, 'timezone': 'UTC', 'pgf.rcfonts': True, 'legend.borderpad': 0.4, 'lines.dash_joinstyle': 'round', 'axes.labelweight': 'normal', 'datapath': '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/mpl-data', 'text.latex.unicode': False, 'legend.handleheight': 0.7, 'image.lut': 256, 'animation.avconv_path': 'avconv', 'animation.codec': 'mpeg4', 'text.latex.preamble': [''], 'legend.numpoints': 2, 'legend.handlelength': 2.0, 'keymap.grid': 'g', 'font.sans-serif': ['Bitstream Vera Sans', 'DejaVu Sans', 'Lucida Grande', 'Verdana', 'Geneva', 'Lucid', 'Arial', 'Helvetica', 'Avant Garde', 'sans-serif'], 'verbose.fileo': 'sys.stdout', 'xtick.major.width': 0.5, 'axes.labelsize': 'medium', 'patch.linewidth': 1.0, 'legend.borderaxespad': 0.5, 'mathtext.sf': 'sans\\-serif', 'axes.hold': True, 'verbose.level': 'silent', 'mathtext.default': 'it', 'figure.subplot.left': 0.125, 'legend.columnspacing': 2.0, 'webagg.open_in_browser': True, 'text.latex.preview': False, 'font.weight': 'normal', 'lines.color': 'b', 'keymap.yscale': 'l', 'image.resample': False, 'font.monospace': ['Bitstream Vera Sans Mono', 'DejaVu Sans Mono', 'Andale Mono', 'Nimbus Mono L', 'Courier New', 'Courier', 'Fixed', 'Terminal', 'monospace'], 'agg.path.chunksize': 0, 'path.simplify_threshold': 0.1111111111111111, 'ytick.labelsize': 'medium', 'ps.papersize': 'letter', 'keymap.back': ['left', 'c', 'backspace'], 'svg.embed_char_paths': True}
2019-03-11 17:45:05.450   THREADDEBUG   Plugin.pluginEnvironmentLogger      Initial Plugin Prefs:           {u'snappyConfigMenus': False, u'sqChartSize': 100, u'spineColorOther': u'#888888', u'faceColor': u'#000000', u'rectChartLabel': u'', u'infoLabel1': u'', u'fontColorOther': u'#FFFFFF', u'space7': u'', u'dataPath': u'/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/', u'gridColorOther': u'#888888', u'showDebugLevel': 50, u'chartPropsSeparator': u'', u'lineWeight': u'1.0', u'promoteCustomLineSegments': True, u'tickColor': u'#888888', u'fontColor': u'#FFFFFF', u'annotationColorOther': u'#FFFFFF', u'enableCustomLineSegments': True, u'rectChartWideLabel': u'', u'tickSize': 4, u'updaterLastCheck': 1549813376.0, u'rectChartWideSeparator': u'', u'verboseLogging': False, u'updaterEmail': u'indigo@mdhome.net', u'debugHeaderSpace': u'', u'backgroundColorOther': u'#000000', u'rectChartWideWidth': 1000, u'space07': u'', u'mainFontSize': u'10', u'space05': u'', u'enableCustomColors': False, u'space06': u'', u'gridColor': u'#888888', u'rectChartSeparator': u'', u'backgroundColor': u'#000000', u'notificationsLabel': u'', u'faceColorOther': u'#000000', u'sqChartSeparator': u'', u'space00': u'', u'infoLabel0': u'', u'chartResolution': 100, u'rectChartWideHeight': 250, u'dpiWarningFlag': True, u'tickColorOther': u'#888888', u'updaterEmailsEnabled': True, u'forceOriginLines': True, u'verboseLoggingLabel': u'', u'separator0': u'', u'space0': u'', u'showDebugSettings': False, u'space01': u'', u'fontColorAnnotation': u'#FFFFFF', u'refreshInterval': 900, u'emailLabel': u'', u'legendFontSize': 6, u'tickFontSize': u'8', u'gridStyle': u':', u'debugLabel': u'', u'chartPropsLabel': u'', u'showNotificationSettings': False, u'oldDebugLevel': u'20', u'chartPath': u'/Library/Application Support/Perceptive Automation/Indigo 7.2/IndigoWebServer/images/controls/static/', u'separator02': u'', u'separator03': u'', u'separator00': u'', u'separator01': u'', u'fontMain': u'Arial', u'notificationsHeaderSpace': u'', u'rectChartHeight': 250, u'sqChartLabel': u'', u'logEachChartCompleted': True, u'rectChartWidth': 600, u'spineColor': u'#888888', u'saveSettingsLabel': u'', u'updaterLastVersionEmailed': u'0.7.09'}
2019-03-11 17:45:05.450   INFO         Plugin.pluginEnvironmentLogger      =======================================================================================================================================
2019-03-11 17:45:05.484   DEBUG        Plugin.clean_props                  [Battery CSV Engine] prefs cleaned.
2019-03-11 17:45:05.496   DEBUG        Plugin.clean_props                  [Chart - Alt Temperature] prefs cleaned.
2019-03-11 17:45:05.507   DEBUG        Plugin.clean_props                  [Chart - Broadband Speed Available] prefs cleaned.
2019-03-11 17:45:05.519   DEBUG        Plugin.clean_props                  [Chart - Daily Power Usage] prefs cleaned.
2019-03-11 17:45:05.532   DEBUG        Plugin.clean_props                  [Chart - Daily Power Usage Lounge] prefs cleaned.
2019-03-11 17:45:05.543   DEBUG        Plugin.clean_props                  [Chart - Downstairs Temperature 1] prefs cleaned.
2019-03-11 17:45:05.556   DEBUG        Plugin.clean_props                  [Chart - Freezer Power and Temperature] prefs cleaned.
2019-03-11 17:45:05.570   DEBUG        Plugin.clean_props                  [Chart - Fridge Power and Temperature] prefs cleaned.
2019-03-11 17:45:05.583   DEBUG        Plugin.clean_props                  [Chart - Fridge Temperature] prefs cleaned.
2019-03-11 17:45:05.599   DEBUG        Plugin.clean_props                  [Chart - Fridge-Freezer Power Usage] prefs cleaned.
2019-03-11 17:45:05.613   DEBUG        Plugin.clean_props                  [Chart - Fridge-Freezer Temperature] prefs cleaned.
2019-03-11 17:45:05.626   DEBUG        Plugin.clean_props                  [Chart - Heating Demand History] prefs cleaned.
2019-03-11 17:45:05.638   DEBUG        Plugin.clean_props                  [Chart - Heating Hot Water] prefs cleaned.
2019-03-11 17:45:05.650   DEBUG        Plugin.clean_props                  [Chart - Heating Hot Water Tank] prefs cleaned.
2019-03-11 17:45:05.663   DEBUG        Plugin.clean_props                  [Chart - Household Power Usage] prefs cleaned.
2019-03-11 17:45:05.676   DEBUG        Plugin.clean_props                  [Chart - Key Temperatures] prefs cleaned.
2019-03-11 17:45:05.689   DEBUG        Plugin.clean_props                  [Chart - Power Tool Charger] prefs cleaned.
2019-03-11 17:45:05.701   DEBUG        Plugin.clean_props                  [Chart - Radiator - Bathroom] prefs cleaned.
2019-03-11 17:45:05.714   DEBUG        Plugin.clean_props                  [Chart - Radiator - Guest Bedroom] prefs cleaned.
2019-03-11 17:45:05.727   DEBUG        Plugin.clean_props                  [Chart - Radiator - Guest Ensuite] prefs cleaned.
2019-03-11 17:45:05.740   DEBUG        Plugin.clean_props                  [Chart - Radiator - Kitchen] prefs cleaned.
2019-03-11 17:45:05.751   DEBUG        Plugin.clean_props                  [Chart - Radiator - Lounge Back] prefs cleaned.
2019-03-11 17:45:05.763   DEBUG        Plugin.clean_props                  [Chart - Radiator - Lounge Front] prefs cleaned.
2019-03-11 17:45:05.774   DEBUG        Plugin.clean_props                  [Chart - Radiator - Master Bed] prefs cleaned.
2019-03-11 17:45:05.787   DEBUG        Plugin.clean_props                  [Chart - Radiator - Molly] prefs cleaned.
2019-03-11 17:45:05.805   DEBUG        Plugin.clean_props                  [Chart - Radiators Downstairs - Batteries] prefs cleaned.
2019-03-11 17:45:05.823   DEBUG        Plugin.clean_props                  [Chart - Radiators Upstairs - Batteries] prefs cleaned.
2019-03-11 17:45:05.833   DEBUG        Plugin.clean_props                  [Chart - TRV Battery Chart] prefs cleaned.
2019-03-11 17:45:05.846   DEBUG        Plugin.clean_props                  [Chart - Upstairs Temperature 1] prefs cleaned.
2019-03-11 17:45:05.860   DEBUG        Plugin.clean_props                  [Chart - Upstairs Temperature 2] prefs cleaned.
2019-03-11 17:45:05.871   DEBUG        Plugin.clean_props                  [Chart Mini - Trend Ensuite] prefs cleaned.
2019-03-11 17:45:05.883   DEBUG        Plugin.clean_props                  [Chart Mini - Trend Freezer] prefs cleaned.
2019-03-11 17:45:05.895   DEBUG        Plugin.clean_props                  [Chart Mini - Trend Fridge] prefs cleaned.
2019-03-11 17:45:05.906   DEBUG        Plugin.clean_props                  [Chart Mini - Trend Guest Bedroom] prefs cleaned.
2019-03-11 17:45:05.918   DEBUG        Plugin.clean_props                  [Chart Mini - Trend Hallway] prefs cleaned.
2019-03-11 17:45:05.929   DEBUG        Plugin.clean_props                  [Chart Mini - Trend Lounge] prefs cleaned.
2019-03-11 17:45:05.940   DEBUG        Plugin.clean_props                  [Chart Mini - Trend Master Bedroom] prefs cleaned.
2019-03-11 17:45:05.952   DEBUG        Plugin.clean_props                  [Chart Mini - Trend Molly Bedroom] prefs cleaned.
2019-03-11 17:45:05.963   DEBUG        Plugin.clean_props                  [Chart Mini - Trend Outdoor Temp] prefs cleaned.
2019-03-11 17:45:05.972   DEBUG        Plugin.clean_props                  [Main CSV Engine] prefs cleaned.
2019-03-11 17:45:05.977   DEBUG        Plugin.clean_props                  [Mini CSV Engine] prefs cleaned.
2019-03-11 17:46:37.957   CRITICAL     Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-03-11 17:46:37.957   CRITICAL     Plugin.pluginErrorHandler           !!! Traceback (most recent call last):
2019-03-11 17:46:37.958   CRITICAL     Plugin.pluginErrorHandler           !!!   File "plugin.py", line 3250, in chart_line
2019-03-11 17:46:37.958   CRITICAL     Plugin.pluginErrorHandler           !!!     self.format_axis_x_ticks(ax, p_dict, k_dict)
2019-03-11 17:46:37.958   CRITICAL     Plugin.pluginErrorHandler           !!!   File "plugin.py", line 4389, in format_axis_x_ticks
2019-03-11 17:46:37.958   CRITICAL     Plugin.pluginErrorHandler           !!!     ax.tick_params(axis='x', **k_dict['k_major_x'])
2019-03-11 17:46:37.958   CRITICAL     Plugin.pluginErrorHandler           !!! TypeError: list indices must be integers, not str
2019-03-11 17:46:37.958   CRITICAL     Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-03-11 17:46:37.960   WARNING      Plugin.processLogQueue              [Chart - Daily Power Usage] list indices must be integers, not str. See plugin log for more information.
2019-03-11 17:46:53.153   CRITICAL     Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-03-11 17:46:53.153   CRITICAL     Plugin.pluginErrorHandler           !!! Traceback (most recent call last):
2019-03-11 17:46:53.154   CRITICAL     Plugin.pluginErrorHandler           !!!   File "plugin.py", line 3250, in chart_line
2019-03-11 17:46:53.154   CRITICAL     Plugin.pluginErrorHandler           !!!     self.format_axis_x_ticks(ax, p_dict, k_dict)
2019-03-11 17:46:53.154   CRITICAL     Plugin.pluginErrorHandler           !!!   File "plugin.py", line 4389, in format_axis_x_ticks
2019-03-11 17:46:53.154   CRITICAL     Plugin.pluginErrorHandler           !!!     ax.tick_params(axis='x', **k_dict['k_major_x'])
2019-03-11 17:46:53.154   CRITICAL     Plugin.pluginErrorHandler           !!! TypeError: list indices must be integers, not str
2019-03-11 17:46:53.154   CRITICAL     Plugin.pluginErrorHandler           !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-03-11 17:46:53.156   WARNING      Plugin.processLogQueue              [Chart - Daily Power Usage Lounge] list indices must be integers, not str. See plugin log for more information.
Mon Mar 11, 2019 7:55 pm
Thanks for the report. There is definitely a bug in there somewhere.
Working on it...
Mon Mar 11, 2019 8:44 pm
Okay, that was a pesky little bugger. Took a while to trace it back to the source, but I was able to find the offending bit of code.
v0.7.40 should fix this bug:
Tue Mar 12, 2019 3:18 am
Busta999 offline
Hopefully I am a useful .....
Tue Mar 12, 2019 3:41 am
:D
Tue Mar 12, 2019 8:03 am
Busta999 offline
Mine was a.canary
Tue Mar 12, 2019 12:30 pm
Mine was a guinea pig. :D
Tue Mar 12, 2019 12:58 pm
Busta999 offline
A canary was used in mines to detect toxic gases - an indicator of a problem...
A guinea pig is ..... ?
Tue Mar 12, 2019 1:00 pm
Busta999 offline
.... a cavey
Sounds like a cave. Which could be a mine ?
Tue Mar 12, 2019 1:36 pm
In [American?] English, the term "guinea pig" is commonly used as a metaphor for a subject of scientific experimentation, or any experiment or test in modern times.
https://en.wikipedia.org/wiki/Guinea_pig#In_scientific_research
:D
Tue Mar 12, 2019 1:41 pm
Busta999 offline
I thought you were just calling a pig :-)
Kidding
Page 5 of 10 1, 2, 3, 4, 5, 6, 7, 8 ... 10
