Lutron Leap - no device issue
Fri Oct 13, 2023 1:13 pm
SMUSEBY offline
Re: Lutron Leap - no device issue
Plug-in reload (after deleting bridge, creating new bridge and pairing bridge). Was'List' you wanted for quoting event log?
Oct 13, 2023 at 12:07:53
   Reloading plugin "Lutron Leap 2022.1.1" using API v3.1
   Stopping plugin "Lutron Leap 2022.1.1" (pid 79859)
   Lutron Leap Debug               stop_concurrent_thread called
   Lutron Leap Debug               Set house to Occupied=f(button): Removing Trigger
   Lutron Leap Debug               Set house to Vacant=f(button) : Removing Trigger
   Lutron Leap Debug               Lutron Bridge: Stopping Device
   Stopped plugin "Lutron Leap 2022.1.1"
   Starting plugin "Lutron Leap 2022.1.1" (pid 80368)
   Started plugin "Lutron Leap 2022.1.1"
   Lutron Leap Debug               startup
   Lutron Leap Debug               run_async_thread starting
   Lutron Leap Debug               async_main starting
   Lutron Leap Debug               startup complete
   Lutron Leap Debug               Lutron Bridge: Starting Device
   Lutron Leap Debug               Set house to Occupied=f(button): Adding Trigger
   Lutron Leap Debug               Set house to Vacant=f(button) : Adding Trigger
   Lutron Leap Debug               Lutron Bridge: Creating bridge at Lutron-0584ecc2.local.
   Lutron Leap Debug               Lutron Bridge: Bridge Connected
   Lutron Leap Debug               Lutron Bridge: Bridge Data: {'device_id': '1', 'current_state': -1, 'fan_speed': None, 'zone': '1', 'name': 'Toy cabinet Processor 001', 'button_groups': None, 'type': 'RadioRa3Processor', 'model': 'JanusProcRA3', 'serial': 92597442, 'area': '209', 'device_name': 'Processor 001'}
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 Laundry_N wall Position 1 Keypad (548) - 560
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 Laundry_N wall Position 1 Keypad (548) - 564
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 Laundry_N wall Position 1 Keypad (548) - 568
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 Laundry_N wall Position 1 Keypad (548) - 572
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 Laundry_N wall Position 1 Keypad (548) - 576
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 Laundry_N wall Position 1 Keypad (548) - 580
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 Laundry_N wall Position 1 Keypad (548) - 584
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 Laundry_N wall Position 1 Keypad (548) - 586
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 Front Hall_1 Front Hall Position 1 Keypad (925) - 940
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 Front Hall_1 Front Hall Position 1 Keypad (925) - 944
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 Front Hall_1 Front Hall Position 1 Keypad (925) - 948
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 Front Hall_1 Front Hall Position 1 Keypad (925) - 952
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 Front Hall_1 Front Hall Position 1 Keypad (925) - 956
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 Front Hall_1 Front Hall Position 1 Keypad (925) - 960
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 Front Hall_1 Front Hall Position 1 Keypad (925) - 964
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 Front Hall_1 Front Hall Position 1 Keypad (925) - 966
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 mstrBdRm_w wall by door Position 1 Keypad (651) - 666
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 mstrBdRm_w wall by door Position 1 Keypad (651) - 670
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 mstrBdRm_w wall by door Position 1 Keypad (651) - 674
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 mstrBdRm_w wall by door Position 1 Keypad (651) - 678
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 mstrBdRm_w wall by door Position 1 Keypad (651) - 682
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 mstrBdRm_w wall by door Position 1 Keypad (651) - 686
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 mstrBdRm_w wall by door Position 1 Keypad (651) - 690
   Lutron Leap Debug               Lutron Bridge: Found Button: 1 mstrBdRm_w wall by door Position 1 Keypad (651) - 692
   Lutron Leap Debug               Lutron Bridge: Found Area: {'id': '3', 'name': 'Glenbrook', 'parent_id': None}
   Lutron Leap Debug               Lutron Bridge: Found Area: {'id': '32', 'name': '1 Laundry', 'parent_id': '3'}
   Lutron Leap Debug               Lutron Bridge: Found Area: {'id': '209', 'name': 'Toy cabinet', 'parent_id': '3'}
   Lutron Leap Debug               Lutron Bridge: Found Area: {'id': '522', 'name': '1 Front Hall', 'parent_id': '3'}
   Lutron Leap Debug               Lutron Bridge: Found Area: {'id': '597', 'name': '1 mstrBdRm', 'parent_id': '3'}
   Lutron Leap Debug               Lutron Bridge: Notifying devices of connection
Followed by create new devices from Bridge:
Oct 13, 2023 at 12:11:30
   Lutron Leap                     Creating Devices, Grouping = Area
   Lutron Leap Warning             Unknown device type RadioRa3Processor
   Lutron Leap Debug               Skipping Sensor device type SeeTouchKeypad
Fri Oct 13, 2023 1:21 pm
No, "Code":
Screenshot 2023-10-13 at 3.16.49 PM.png (34.52 KiB) Viewed 856 times
That's the entire log after activating the menu command? It just stops there? Are all your devices active in the mobile app? It should be showing a bunch more after that. Do the bridge data dump again and post it.
Fri Oct 13, 2023 1:22 pm
Hmm. I thought there was more the last time you did the create devices, but there wasn't. You just did it twice. I need to look at the code again.
Fri Oct 13, 2023 2:01 pm
Looks like it might be a problem with the device creation, since RRa3 does the location info different than Caseta.
Try: https://github.com/FlyingDiver/Indigo-L ... g/2022.1.2
Wed Oct 18, 2023 10:19 pm
SMUSEBY offline
I'm not at the house and therefore unable to push the keypad button. I assume it will work.
Thank you
Wed Nov 01, 2023 1:03 pm
SMUSEBY offline
I've installed Lutron Leap plug-in 2022.1.2. I restarted Indigo, and it does not recognize the control. Status request log:
Nov 1, 2023 at 11:59:52
   Error                           "1 fHall-fPorch&Garage fHallKPL" status request; send failed (no acknowledgment)
(I am able to control the light from my phone with the Lutron RRD3 app).
Wed Nov 01, 2023 1:07 pm
I don't care about status requests. This thread was about devices not being created. Did you re-run the device creation menu command? I need to see the debug log when you do that.
Wed Nov 01, 2023 2:24 pm
SMUSEBY offline
I did execute the create device in the plug-in. (FWIW, 3 digits appended to the device name created in the Lutron Designer change).
Event log:
Nov 1, 2023 at 13:21:03
   Lutron Leap Debug               LogLevel = 5
   Lutron Leap Debug               1 Front Hall_1 Front Hall Position 1 Keypad Front Porch LED (933): actionControlDimmerRelay: action = actionValue : 0
configured : True
delayAmount : 900
description : turn on device
deviceAction : TurnOn
deviceId : 166165602
replaceExisting : True
textToSpeak :
Wed Nov 01, 2023 2:28 pm
I can't figure what you're actually trying to report. So I'm closing this thread. I'll have an RRa3 processor and keypad in a week or so, and I'll test the Keypad LEDs then. Until then, just don't use them.
