Pico Trigger Issue
Sat Sep 09, 2023 11:01 am
dz1rfj offline
Pico Trigger Issue
New to Pico Triggers, but kicking myself for not exploring sooner, fantastic use case!
Using the latest Lutron Plugin. I have setup several buttons and triggers. They all work fine with my Caseta Pro bridge.
I noticed after successfully installing an ADDITIONAL Lutron RA2 Select hub, the pico triggers on most picos would no longer work, but one pico worked every time, even with the new RA2 Select hub enabled.
Why? Thats way above my knowledge, but I can tell you if I enable / disable that RA2 Select bridge in Indigo, all pico triggers work or don't work consistently. EXCEPT a single pico.
Photos -
1 - Plug in version
2- list of buttons. With the RA2 installed AND enabled, device 35 / button 3 works EVERY time, and is further away from hubs than button 13
With the RA2 installed AND enabled, device 13 / button 3 NEVER works , and is closer to the hubs than device 35 / button 3
3. This is the trigger that works EVERY time, no matter the status of the RA2 Select hub being enabled
4. This photo shows the method I finally used vs uninstalling the RA2 select as I tested this issue.
So, 2 basic questions:
1. Any thoughts on why one pico device would consistently work even with the RA2 Select hub enabled while the others wont ?
2. Any suggestions on why the pico triggers seem to get "Confused" when that 2nd hub is enabled ?
Method used to enable / disable 2nd hub
4- RA2 disbled.png (68.98 KiB) Viewed 1230 times
Works even if RA2 Select is enabled
3- this works EVERY time.png (289.38 KiB) Viewed 1230 times
device testing scenarios using these two devices
2-test cases - Pico 35 works every time .png (231.97 KiB) Viewed 1230 times
PluginVersion
-Brian
Sat Sep 09, 2023 11:20 am
Re: Pico Trigger Issue
Multiple hubs/bridges usually work totally independent of each other, so I'm not sure what could be going on. You're only enabling/disabling the new Select hub in Indigo, right? You're not physically disconnecting it from power or network when the behavior changes?
Also, do the buttons actually work to do what they're programmed to do in the hubs? Or are they all unprogrammed for Indigo triggers only?
Those screenshots do me no good. The info you can see in the UI isn't that useful, and I can't read the text on those images anyway. So don't bother with those unless I ask for something specific.
Also, please open a new issue to track this on GitHub at https://github.com/FlyingDiver/Indigo-radiora2/issues
I'm leaving in less than 48 hours for three weeks on vacation, so all this needs to be tracked where I can find it easier later, which is not the forums. :)
What I need is for you to enable debug logging (NOT detailed debugging), restart the plugin, then activate the pico buttons with and without the Select hub enabled. The turn off debug logging and post the log info in the GitHub issue. That should give me something to work with to see what might be going on.
Sat Sep 09, 2023 11:38 am
Also, just so you know, I've never had a Select system to test with, and I've never actually been able to test multiple independent hubs. Others have, but there certainly could be some edge conditions. I suspect that there's something wrong with the way that device addresses are constructed or compared for triggers when there's multiple hubs.
Mon Sep 11, 2023 10:23 am
dz1rfj offline
Joe, Thanks for the notes. I will prepare this for your return. We just got back from a Viking "
MEDITERRANEAN ODYSSEY ", would love to hear your plans, always looking for ideas for future travels if you care to share :D
Brian
-Brian
Mon Sep 11, 2023 10:28 am
This is a scuba diving trip to Indonesia.
Tue Sep 12, 2023 7:39 pm
Dual offline
Awesome. Enjoy! Bali? Lembeh? Wakatobi? Raja Ampat? So many possibilities. All great! Hope you have a wonderful trip.
Tue Sep 12, 2023 10:39 pm
Wakatobi
Tue Sep 12, 2023 11:08 pm
Dual offline
Awesome resort. Great diving. I will be there in October. Have a wonderful time.
Tue Sep 12, 2023 11:38 pm
It’s our 9th trip there. We’ve been going since 2004.
Mon Oct 09, 2023 9:03 pm
I'm back, so if you want to pick this up please create a GitHub issue.
