Lutron Leap protocol plugin - now available
Mon Jan 09, 2023 2:17 pm
The new plugin for Lutron systems that use the Leap protocol is now available: https://www.indigodomo.com/pluginstore/278/
This plugin supports the following systems:
Lutron Caséta Smart Hub (L-BDG2-WH)
Lutron Caséta Smart Bridge PRO (L-BDGPRO2-WH)
RadioRA 2 Select Main Repeater (RR-SEL-REP2-BL)
RadioRA 3 All-in-One Processor (RR-PROC3)
Homeworks QSX Processor (HQP7)
Note that the Caséta Smart Bridge PRO is also supported by the existing Lutron plugin. There's no pressing need to switch to the new plugin if you have one of these systems. Also, I believe you could run both plugins at the same time, if you wanted to check the new one out.
Please read the plugin store page for what's been tested and what hasn't. If you have systems or devices that were not tested please give it a try and post your results here.
You will need to install the pylutron_caseta Python module. The plugin will print instructions to the Indigo log on startup.
