Lutron RadioRa2 Keypad, button #7
Thu Sep 29, 2022 12:09 pm
SMUSEBY offline
Might it be possible to control the LED associated with button 7? Mine are always on.
From the event log when pressing button #7:
Lutron RRA2/Caséta Debug Received a keypad button/LED status message: GNET> ~DEVICE,16,7,3
Lutron RRA2/Caséta Debug buttonTriggerCheck: deviceID: 16, componentID: 7, gatewayID: 68394
Lutron RRA2/Caséta Debug Received: Dimmer 1 k - Dimmer 76 - stove&sink level set to 0.0
Lutron RRA2/Caséta Debug Received: Dimmer 1 k - Dimmer 79 - uCab N level set to 0.0
Lutron RRA2/Caséta Debug Received: Dimmer 1 k - Dimmer 88 - table level set to 0.0
Lutron RRA2/Caséta Debug Received: Switch 1 k - Dimmer 37 - uCab S turned Off
Lutron RRA2/Caséta Debug buttonMultiPressCheck: Timeout reached for keypadid = 68394:16.7, presses = 1
There is no LED for 7 in the device list.
Thu Feb 16, 2023 6:17 pm
SMUSEBY offline
Re: Lutron RadioRa2 Keypad, button #7
I now have a 7th button on some of my keypads (on these, I ordered the custom engraving for a 7th button, replacing the raise/lower buttons). Is it not possible to add a button 7 LED to the device list? I have a vague recollection that you thought there was no 7th LED (which there isn't on the factory standard issue).
Thu Feb 16, 2023 7:16 pm
What version of the plugin are you using?
Thu Feb 16, 2023 7:23 pm
SMUSEBY offline
2022.0.7
Thu Feb 16, 2023 7:56 pm
Current version is 2022.1.2, which has changes to LED 7 handling.
Thu Feb 16, 2023 9:46 pm
SMUSEBY offline
Excellent.
thanks.
