Unable to use Pico with Indigo
Fri Apr 08, 2022 9:43 am
docbjr offline
I had to completely redo my Indigo setup thanks to Cincinnati Bell's router issues. I now have a generic router that works fine, but I lost the ability to control Insteon devices with my PICO.
I have a Bridge Pro, but when I attempt to create devices from the Bridge pro, my only choice is from my Ra2 main repeater. The bridge pro is not a choice.
Fri Apr 08, 2022 10:17 am
Re: Unable to use Pico with Indigo
I suspect that the IP address of the smart bridge changed, or possibly it’s no longer on the correct wifi network.
Verify those and check that the indigo gateway device matches.
Fri Apr 08, 2022 12:11 pm
docbjr offline
Should I be able to use the PICO without the Caseta bridge, if I add it to my Ra2 setup? I think I may have had it setup that way previously.
thx
Fri Apr 08, 2022 12:57 pm
I use Picos with my RRa2 repeater. Not sure what the process is to move them from one hub to another.
