Lutron main repeater disconnected
Posted: Wed Mar 23, 2022 6:18 pm
Greetings!
Here is what I see. It's been a couple of days since it worked.
TIA
TIA
- Code: Select all
Mar 23, 2022 at 8:03:43 PM
Reloading plugin "Lutron RRA2/Caséta 7.4.0"
Stopping plugin "Lutron RRA2/Caséta 7.4.0" (pid 1064)
Lutron RRA2/Caséta Debug IP stop called
Lutron RRA2/Caséta Shutting down Lutron
Stopped plugin "Lutron RRA2/Caséta 7.4.0"
Starting plugin "Lutron RRA2/Caséta 7.4.0" (pid 1520)
Lutron RRA2/Caséta Debug logLevel = 10
Started plugin "Lutron RRA2/Caséta 7.4.0"
Lutron RRA2/Caséta Starting up Lutron
Lutron RRA2/Caséta No linked Devices
Lutron RRA2/Caséta Lutron Caseta Hub: Running IP Start
Lutron RRA2/Caséta Lutron Caseta Hub: Connecting via IP to 192.168.200.79:23
Mar 23, 2022 at 8:04:21 PM
Lutron RRA2/Caséta Error Lutron Caseta Hub: Unable to connect to Lutron gateway. Timed out.
Lutron RRA2/Caséta Lutron Main Repeater: Running IP Start
Lutron RRA2/Caséta Lutron Main Repeater: Connecting via IP to 192.168.200.108:23
Lutron RRA2/Caséta Debug Lutron Main Repeater: self.connIP.read: login:
Lutron RRA2/Caséta Debug Lutron Main Repeater: Sending username
Lutron RRA2/Caséta Debug Lutron Main Repeater: self.connIP.read: password:
Lutron RRA2/Caséta Debug Lutron Main Repeater: Sending password
Lutron RRA2/Caséta Debug Lutron Main Repeater: Login process complete, connected
Mar 23, 2022 at 8:05:06 PM
Lutron RRA2/Caséta Debug Received a pico button status message: GNET> ~DEVICE,9,3,3
Lutron RRA2/Caséta Debug buttonTriggerCheck: deviceID: 9, componentID: 3, gatewayID: 1166431303
Lutron RRA2/Caséta Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 1054, in runConcurrentThread
File "plugin.py", line 159, in poll
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/telnetlib.py", line 430, in read_eager
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/telnetlib.py", line 576, in fill_rawq
error: [Errno 54] Connection reset by peer
Lutron RRA2/Caséta Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Lutron RRA2/Caséta Error Lutron Main Repeater: EOFError: telnet connection closed
Lutron RRA2/Caséta Debug buttonMultiPressCheck: Timeout reached for keypadid = 1166431303:9.3, presses = 1
