Got a Lutro Caséta starter kit from Lowes -- No luck
Wed Nov 25, 2020 2:34 pm
boisy offline
Hi all,
I bought a Caséta starter kit from Lowes which includes the hub (not the Pro model), a dimmer switch, and a Pico remote.
I downloaded 7.3.2 of the Lutron RRA2/Caséta plug-in for Indigo 7.4.1 and have it installed.
The hub is on my network, and I used LanScan to identify its IP address.
I created a new Network Connected Gateway device, but the log is stuck on "Connecting via IP to 192.168.0.207:23"
Doing a port scan on the hub shows that ports 22, 8081, and 8083 are open.
Then I saw on the instructions here: https://github.com/FlyingDiver/Indigo-r ... on-for-Caséta-and-RRA2-Select-Systems
That the Pro hub is needed. Is this indeed the case?
Wed Nov 25, 2020 2:35 pm
Re: Got a Lutro Caséta starter kit from Lowes -- No luck
Yes it is. The non-Pro hub doesn't implement the automation interface.
Wed Nov 25, 2020 2:37 pm
Huh. Weird. The ReadMe on the GitHub repository has the requirements, but that ReadMe didn't get updated on the Plugin Store.
https://github.com/FlyingDiver/Indigo-radiora2
I need to fix that.
Edit: Fixed
Wed Nov 25, 2020 2:44 pm
boisy offline
Drats... ok, so all I need is a Pro hub and I'm good to go?
Wed Nov 25, 2020 2:45 pm
Yup.
Wed Nov 25, 2020 2:51 pm
boisy offline
Awesome. If you have any suggested places online where I can get one, please share.
This gives me the opportunity to test the Caséta switch, and I have to say, I like the feel of it. Seems more natural than an Insteon Keypad Linc which is what I'm replacing for this test.
Wed Nov 25, 2020 3:03 pm
http://hankselectric.supply/Lutron-Case ... _p_89.html
That's where I buy all my Lutron gear.
Fri Dec 04, 2020 2:45 pm
boisy offline
Ok, got my Lutron Pro Starter Kit from Hanks. Took a bit to get the Pro Hub up and running with Indigo, but I'm there. What I learned:
1. You have to find the IP address of the hub yourself (once you turn on Telnet in the Lutron iOS App's advanced settings)
2. I had to use the reporting feature in the Lutron iOS app to give me a list of devices so I could obtain the IDs which are needed when creating a new Lutron dimmer device.
So it's a little more involved in setup than Insteon, but if the reliability is much better, then I'm already sold. What I especially like about this is the hub is ethernet based so I can place it in an area that propagates the best signal, and not just have it tethered to my Mac like the Insteon PowerLinc.
I added it as a HomeKit Bridge device and can control it with Siri. I'll play with it some more. So far I like the Pico remote. Very handy.
Speaking of... is there any advantage to adding the Pico remote as an Indigo device?
Fri Dec 04, 2020 3:00 pm
Actually, there's a way to export a report from the iOS app which will email you a JSON data string. You can import that directly into the plugin and it will create all the devices for you.
Fri Dec 04, 2020 3:02 pm
If you want to do custom actions based on button presses on the Pico, yes. I use mine that way and don't program the actions into the Hub. That way I can do double-click, triple-click, etc. So I can make the different buttons control different devices (including non-Lutron ones). But you do loose some functionality that the Hub can do directly.
Fri Dec 04, 2020 3:07 pm
boisy offline
Thanks. I'll make note of that.
Speaking of reliability, I don't mean just signal integrity and 100% response. I'm also talking about reliability of the hardware. Insteon switches seem to start having issues after 2-3 years for whatever reason. At least that's what I've experienced. I really want something that I can install and forget -- it just works.
