Lutron repeater disconnects
Thu Sep 10, 2020 5:49 pm
docbjr offline
Ok, this is weird. This afternoon, the lights on my main repeater started ping ponging back and forth. The tech at Lutron asked if I was running another piece of software that communicates with the main repeater, because the pinging would indicate that. I tried to explain Indigo to him and he insisted that it must be communicating with the repeater and causing the ping ponging.
What say you? I'm stumped.
Thu Sep 10, 2020 5:54 pm
Re: Lutron keypads
You might have some trigger going that's creating an infinite loop. Turn on debug logging and see if there's a lot of traffic going back and forth.
Thu Sep 10, 2020 6:01 pm
docbjr offline
Re: Lutron keypads
Do you see anything here?
And was he correct in that Indigo is indeed speaking to the main repeater?
Sep 10, 2020 at 7:58:58 PM
   Reloading plugin "Lutron RRA2/Caséta 7.3.2"
   Stopping plugin "Lutron RRA2/Caséta 7.3.2" (pid 4159)
   Lutron RRA2/Caséta Debug       Removing Trigger Group 010 - Laundry Room Occupied (1572628468)
   Lutron RRA2/Caséta Debug       Removing Trigger Group 010 - Laundry Room Unoccupied (350836916)
   Lutron RRA2/Caséta Debug       Removing Trigger office ceiling and wall  to 5% (1821414239)
   Lutron RRA2/Caséta Debug       IP stop called
   Lutron RRA2/Caséta             Shutting down Lutron
   Stopped plugin "Lutron RRA2/Caséta 7.3.2"
   Starting plugin "Lutron RRA2/Caséta 7.3.2" (pid 4163)
   Lutron RRA2/Caséta Debug       logLevel = 5
   Started plugin "Lutron RRA2/Caséta 7.3.2"
   Lutron RRA2/Caséta             Starting up Lutron
   Lutron RRA2/Caséta             No linked Devices
   Lutron RRA2/Caséta             Lutron Gateway: Running IP Start
   Lutron RRA2/Caséta             Lutron Gateway: Connecting via IP to 192.168.200.108:23
   Lutron RRA2/Caséta Error       exception in deviceStartComm(Lutron Gateway): [Errno 61] Connection refused
   Lutron RRA2/Caséta Threaddebug Starting Trigger 'Group 010 - Laundry Room Occupied', pluginProps = com.jimandnoreen.indigoplugin.lutron-radiora2 : (dict)
     gateway : 1749948471 (string)
     group : 10 (string)
     occupancyPopUp : 3 (string)
   Lutron RRA2/Caséta Debug       Adding Group Trigger Group 010 - Laundry Room Occupied, group = 10, gateway = 1749948471
   Lutron RRA2/Caséta Threaddebug Starting Trigger 'Group 010 - Laundry Room Unoccupied', pluginProps = com.jimandnoreen.indigoplugin.lutron-radiora2 : (dict)
     gateway : None (empty)
     group : 1749948471:Group.10 (string)
     occupancyPopUp : 4 (string)
   Lutron RRA2/Caséta             Group 010 - Laundry Room Unoccupied: Added default Gateway (None)
   Lutron RRA2/Caséta Debug       Adding Group Trigger Group 010 - Laundry Room Unoccupied, group = 1749948471:Group.10, gateway = None
   Lutron RRA2/Caséta Threaddebug Starting Trigger 'office ceiling and wall  to 5%', pluginProps = com.jimandnoreen.indigoplugin.lutron-radiora2 : (dict)
     buttonID : 1574255090 (string)
     clicks : 2 (string)
     room : Office (string)
   Lutron RRA2/Caséta Debug       Adding keypadMultiButtonPress Trigger 'office ceiling and wall  to 5%', buttonID = 1574255090
Thu Sep 10, 2020 6:04 pm
docbjr offline
Re: Lutron keypads
BTW, after I cured the ping ponging by powering down the repeater for a couple of minutes, I no longer can access it with Indigo..I should have mentioned that before I sent the data.
Thu Sep 10, 2020 6:09 pm
Re: Lutron keypads
Yes, that's how automation systems work with an RRa2 system. They communicate with the main repeater, either over the LAN or serial.
Nothing in that log. You need an excerpt from when you see the ping ponging. If it only does it for a few seconds, ignore it. If it does it continuously then it might be an issue.
If you reboot the repeater, you need to restart the plugin.
Thu Sep 10, 2020 6:16 pm
docbjr offline
Re: Lutron keypads
I just power cycled the Mac, and the Lutron Gateway shows as connected.
What kind of commands might I have attempted with Indigo to cause this?
Thu Sep 10, 2020 6:17 pm
docbjr offline
Re: Lutron keypads
I attempted to change a setting of one of the dimmers through Indigo and it failed, knocking the Reader offline. Here is what shows....
Sep 10, 2020 at 8:14:35 PM
   Lutron RRA2/Caséta Debug       Office Ceiling!: actionControlDimmerRelay sending: '#OUTPUT,6,1,0' to gateway 1749948471
   Lutron RRA2/Caséta Debug       Lutron Gateway: Sending command: '#OUTPUT,6,1,0'
   Lutron RRA2/Caséta Error       Error in plugin execution runConcurrentThread:
  File "plugin.py", line 1049, in runConcurrentThread
  File "plugin.py", line 154, in poll
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/telnetlib.py", line 430, in read_eager
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/telnetlib.py", line 576, in fill_rawq
error: [Errno 54] Connection reset by peer
   Lutron RRA2/Caséta Error       plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
   Lutron RRA2/Caséta Error       Lutron Gateway: EOFError: telnet connection closed
Thu Sep 10, 2020 6:19 pm
Re: Lutron keypads
You don't need to restart the Mac. There's a restart command in the menu for every plugin.
Every command to the Lutron system is going to "communicate with the main repeater". Which will cause an LED blink.
docbjr offline
Re: Lutron keypads
That should have read repeater, not reader. Sorry
Thu Sep 10, 2020 6:21 pm
Re: Lutron keypads
I don't know what to tell you. This used to work, right? So what did you actually change?
Thu Sep 10, 2020 6:25 pm
docbjr offline
Re: Lutron keypads
Not sure. I was just playing with Indigo to see what I could accomplish. Maybe I did something but I have no idea what.
Thu Sep 10, 2020 6:30 pm
Re: Lutron keypads
Well, restart the plugin and make sure there's no errors in the log from that.
Thu Sep 10, 2020 7:01 pm
docbjr offline
Re: Lutron keypads
I did restart the plugin with no luck. Rebooting the Mac fixed it then.
However, I can no longer get the gateway to be seen. I have rebooted the gateway, rebooted the Mac, and restarted the plugin to no avail.
This is the latest message..
Thu Sep 10, 2020 7:10 pm
docbjr offline
Re: Lutron keypads
I just rebooted the Mac and Indigo, and for a few seconds the gateway was connected. But just a couple of seconds later it became disconnected with this message..
Thu Sep 10, 2020 7:21 pm
Re: Lutron keypads
Check to make sure you don't have multiple gateway devices.
