Error message while loading plugin
Sat Aug 01, 2020 8:21 pm
Job1 offline
Anyone seen this before? Same error on two different macs. Also tried both versions of 7.4. Deleted every file and reinstalled multiple times.
Sat Aug 01, 2020 8:23 pm
Re: Error message while loading plugin
Is this a new install of the plugin or was the old version previously working?
Sat Aug 01, 2020 8:28 pm
Job1 offline
New install of both the software and plugin.
Sat Aug 01, 2020 8:37 pm
OK, I'll look at the code tomorrow. I think there might be an assumption about a previous install that's not warranted.
Sun Aug 02, 2020 12:06 pm
Sun Aug 02, 2020 12:31 pm
Job1 offline
It loads without errors now. But the configure screen is still missing all the connection info.
Sun Aug 02, 2020 12:35 pm
It's no longer in the plugin config dialog. You need to create a gateway device.
Sun Aug 02, 2020 12:45 pm
Job1 offline
Sweet, thanks for your help!
Sun Aug 09, 2020 8:13 am
Job1 offline
One more question :D . What's the best way to replicate (with RA2 keypads) the Pico button function with Lutron shades without assigning a pico to each shade? With the pico, after you press the open/close, you can stop the shade at any position by pressing a button again.
So I would have 4 keypad buttons dedicated to the shade: Open, Preset 1, Preset 2, Close.
If I send the open command through the software and then press it again, it doesn't stop the shade. If I add a Pico and then use those buttons instead, it functions like I want.
Sun Aug 09, 2020 8:16 am
I would program a double-click of the button to send a stop command. That's probably as close as you can get to the native programming.
