help for beginner with Lutron
Fri Aug 28, 2020 8:21 am
docbjr offline
Re: help for beginner with Lutron
Now I think that you need to go into Essentials and create a new Integration user with full permissions, then use that username/password in the plugin device. I had a similar problem when I upgraded to the latest version of Inclusive (12.7.0).
I created a new user but could not see how to bring over my existing data.
In the meantime, I removed and recreated the gateway in Indigo and now can not activate the gateway. There are messages about the telenet connection being closed.
Sorry to bug you
Fri Aug 28, 2020 8:45 am
If you created a new user in the Integration tab of Essentials, it's all the same project and there's no need to "bring over" any data. It's all there already.
Or did you do something else?
What do you mean by "activate" the gateway? That's not a term used in Indigo.
You will probably need to edit each (other) Lutron device and update the Gateway property to point to the new Gateway device that you created. Each device is linked to a specific gateway as it's possible to have more than one gateway defined.
There was nothing wrong with your setup, as far as I can tell. It's just a weird glitch in the Lutron software that it's not sending the status messages to the existing Integration user. Adding a new Integration user seems to solve that.
Screen Shot 2020-08-28 at 10.47.30 AM.png (1.52 MiB) Viewed 5316 times
Fri Aug 28, 2020 8:50 am
Also, I just posted 7.3.2 to the plugin store. It fixes a few bugs, including incorrect display of the gateway status.
Fri Aug 28, 2020 9:46 am
docbjr offline
Success! I can now control the dimmers from my phone and Mac with the resulting conditions showing on both. I also have the dimmers working in Homekit.
Thanks for your help.
Sat Aug 29, 2020 4:10 pm
docbjr offline
Tell me if this is normal...When I do a transfer in Radio ra 2, I get the following message in Indigo, "Lutron Gateway: EOFError: telnet connection closed", and the gateway becomes disconnected and devices that had been working in Indigo no longer work until I remove and re-add the gateway.
thx
Sat Aug 29, 2020 4:19 pm
thx
Yeah, that's normal at this time. Except you just need to restart the plugin. Don't mess with the gateway device.
The repeater closes the telnet connection and my re-connect code isn't working quite right. So until I get around to fixing that, plan on restarting the plugin any time you do a transfer to the repeater.
Sat Aug 29, 2020 5:27 pm
docbjr offline
Sat Aug 29, 2020 5:54 pm
And, FWIW, that's a good rule of thumb for any Indigo plugin. First, restart the plugin. Then look for other things.
Fri Jan 21, 2022 12:21 pm
docbjr offline
After changing from ra2 to ra3 and back to ra2, I have a problem. Previously I had a pico that controlled several Insteon devices. My Indigo device page would show both Lutron Main Repeater and Lutron Caseta hub as both connected. Now the Caseta hub shows as None.
Also, I don't see how to have Indigo show the pico.
I had ra2 create an integration report which does show the pico in the Family room where I wanted it. But it does not show in Indigo. I have attached the integration report.
integration.txt
(6.42 KiB) Downloaded 75 times
Fri Jan 21, 2022 12:28 pm
First, does everything work in RRA2? Can you program the Pico to do something useful?
Do you have Indigo devices for the Pico buttons? Did you previously? There's no one device for the pico itself, just for the individual buttons.
You can use the plugin menu command to create any Indigo devices that are missing.
joe
Fri Jan 21, 2022 2:05 pm
docbjr offline
Yes, I programmed the pico in RRA2 and it did do what it was supposed to do. RRA2 works fine.
I used to have Indigo devices for the 4 Pico buttons but don't remember what I did to accomplish that.
Now when I attempt to create devices from either the repeater or the smart bridge, I get the message that it is unable to do so because the process is already running. This started after I programmed the pico to do something in RRA2.
The smart bridge is plugged in to power and the internet.
Fri Jan 21, 2022 2:08 pm
Restart the plugin, enable debugging logging, and try to create the devices using the menu command from the RRa2 repeater only. This process takes a minute or two, so don't rush it. Show log output and/or screen shots if you have errors.
Fri Jan 21, 2022 2:15 pm
docbjr offline
Also, the integration report actually shows the Pico in the Family room.
Family room, Family room Pico, Family room pico, PJ2-4B-GWH-L31, 17
, , , , , Button 8, 8, On
, , , , , Button 9, 9, Medium
, , , , , Button 10, 10, Low
, , , , , Button 11, 11, Off
Fri Jan 21, 2022 2:25 pm
docbjr offline
Again, the family room Pico shows up.
Jan 21, 2022 at 3:17:35 PM
   Reloading plugin "Lutron RRA2/Caséta 7.4.0"
   Stopping plugin "Lutron RRA2/Caséta 7.4.0" (pid 3583)
   Lutron RRA2/Caséta Debug       IP stop called
   Lutron RRA2/Caséta             Shutting down Lutron
   Stopped plugin "Lutron RRA2/Caséta 7.4.0"
   Debugging plugin "Lutron RRA2/Caséta 7.4.0" (pid 3998)
   Lutron RRA2/Caséta Debug       logLevel = 10
   Started plugin "Lutron RRA2/Caséta 7.4.0"
   Lutron RRA2/Caséta             Starting up Lutron
   Lutron RRA2/Caséta             No linked Devices
   Lutron RRA2/Caséta             Lutron Caseta Hub: Running IP Start
   Lutron RRA2/Caséta             Lutron Caseta Hub: Connecting via IP to 192.168.200.79:23
Jan 21, 2022 at 3:18:15 PM
   Lutron RRA2/Caséta Error       Lutron Caseta Hub: Unable to connect to Lutron gateway. Timed out.
   Lutron RRA2/Caséta             Lutron Main Repeater: Running IP Start
   Lutron RRA2/Caséta             Lutron Main Repeater: Connecting via IP to 192.168.200.108:23
   Lutron RRA2/Caséta Debug       Lutron Main Repeater: self.connIP.read: login:
   Lutron RRA2/Caséta Debug       Lutron Main Repeater: Sending username
   Lutron RRA2/Caséta Debug       Lutron Main Repeater: self.connIP.read: password:
   Lutron RRA2/Caséta Debug       Lutron Main Repeater: Sending password
   Lutron RRA2/Caséta Debug       Lutron Main Repeater: Login process complete, connected
Jan 21, 2022 at 3:19:23 PM
   Lutron RRA2/Caséta Debug       Starting device fetch thread...
   Lutron RRA2/Caséta Debug       Device fetch thread running, valuesDict = UiValuesDict : (dict)
     create_event_triggers : false (bool)
     create_group_triggers : false (bool)
     create_unused_keypad : false (bool)
     create_unused_note :  (string)
     create_unused_phantom : false (bool)
     gateway : 1166431303 (string)
     group_by : Type (string)
     local_note :  (string)
     separator0 :  (string)
     separator1 :  (string)
     separator2 :  (string)
     use_local : false (bool)
     warning_note :  (string)
     xmlFileName : ~/DbXmlInfo.xml (string)
   Lutron RRA2/Caséta             Creating RRA2 Devices from gateway 1166431303, Grouping = Type, Create unprogrammed keypad buttons = False, Create unprogrammed phantom buttons = False
   Lutron RRA2/Caséta             Creating Devices - starting data fetch...
   Lutron RRA2/Caséta             Creating Devices fetch completed, parsing data...
   Lutron RRA2/Caséta             Finding devices in 'Dad's closet'
   Lutron RRA2/Caséta Debug       Device: Device 001 (19,MOTION_SENSOR)
   Lutron RRA2/Caséta Debug       Skipping existing device: 'Dad's closet - Motion Sensor 19' (1166431303:19)
   Lutron RRA2/Caséta Debug       Skipping existing device: 'Group 018 - Dad's closet' (1166431303:Group.18)
   Lutron RRA2/Caséta             Finding devices in 'Family room'
   Lutron RRA2/Caséta Debug       Device: Family room pico (17,PICO_KEYPAD)
   Lutron RRA2/Caséta Debug       Component: 8 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 9 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 10 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 11 (BUTTON)
   Lutron RRA2/Caséta             Finding devices in 'Dad's bathroom'
   Lutron RRA2/Caséta Debug       Device: Device 001 (15,MOTION_SENSOR)
   Lutron RRA2/Caséta Debug       Skipping existing device: 'Dad's bathroom - Motion Sensor 15' (1166431303:15)
   Lutron RRA2/Caséta             Finding devices in 'Laundry Room'
   Lutron RRA2/Caséta Debug       Output: Doorway (11) NON_DIM
   Lutron RRA2/Caséta Debug       Skipping existing device: 'Laundry Room - Switch 11 - Doorway' (1166431303:11)
   Lutron RRA2/Caséta Debug       Device: Device 001 (12,MOTION_SENSOR)
   Lutron RRA2/Caséta Debug       Skipping existing device: 'Laundry Room - Motion Sensor 12' (1166431303:12)
   Lutron RRA2/Caséta             Finding devices in 'Office'
   Lutron RRA2/Caséta Debug       Output: Ceiling (6) ELV
   Lutron RRA2/Caséta Error       Unknown Output Type: Ceiling (ELV, 6)
   Lutron RRA2/Caséta Debug       Output: Wall (7) MLV
   Lutron RRA2/Caséta Debug       Skipping existing device: 'Office - Dimmer 7 - Wall' (1166431303:7)
   Lutron RRA2/Caséta Debug       Device: Desk Pico2 (13,PICO_KEYPAD)
   Lutron RRA2/Caséta Debug       Skipping existing device: 'Office - Desk Pico2 - Button 013.08 - On' (1166431303:13.8)
   Lutron RRA2/Caséta Debug       Skipping existing device: 'Office - Desk Pico2 - Button 013.09 - Medium' (1166431303:13.9)
   Lutron RRA2/Caséta Debug       Skipping existing device: 'Office - Desk Pico2 - Button 013.10 - Low' (1166431303:13.10)
   Lutron RRA2/Caséta Debug       Skipping existing device: 'Office - Desk Pico2 - Button 013.11 - Off' (1166431303:13.11)
   Lutron RRA2/Caséta Debug       Device: Desk Pico (9,PICO_KEYPAD)
   Lutron RRA2/Caséta Debug       Component: 2 (BUTTON)
   Lutron RRA2/Caséta Debug       Skipping existing device: 'Office - Desk Pico - Button 009.02 - On' (1166431303:9.2)
   Lutron RRA2/Caséta Debug       Component: 3 (BUTTON)
   Lutron RRA2/Caséta Debug       Skipping existing device: 'Office - Desk Pico - Button 009.03 - Favorite' (1166431303:9.3)
   Lutron RRA2/Caséta Debug       Component: 4 (BUTTON)
   Lutron RRA2/Caséta Debug       Skipping existing device: 'Office - Desk Pico - Button 009.04 - Off' (1166431303:9.4)
   Lutron RRA2/Caséta Debug       Component: 5 (BUTTON)
   Lutron RRA2/Caséta Debug       Skipping existing device: 'Office - Desk Pico - Button 009.05 - Raise' (1166431303:9.5)
   Lutron RRA2/Caséta Debug       Component: 6 (BUTTON)
   Lutron RRA2/Caséta Debug       Skipping existing device: 'Office - Desk Pico - Button 009.06 - Lower' (1166431303:9.6)
   Lutron RRA2/Caséta Debug       Device: Device 001 (8,MOTION_SENSOR)
   Lutron RRA2/Caséta Debug       Skipping existing device: 'Office - Motion Sensor 8' (1166431303:8)
   Lutron RRA2/Caséta             Finding devices in 'Equipment Room'
   Lutron RRA2/Caséta Debug       Device: Enclosure Device 001 (1,MAIN_REPEATER)
   Lutron RRA2/Caséta Debug       Component: 1 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 7 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 12 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 13 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 14 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 15 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 16 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 17 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 18 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 19 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 20 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 21 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 22 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 23 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 24 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 25 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 26 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 27 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 28 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 29 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 30 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 31 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 32 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 33 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 34 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 35 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 36 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 37 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 38 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 39 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 40 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 41 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 42 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 43 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 44 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 45 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 46 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 47 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 48 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 49 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 50 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 51 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 52 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 53 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 54 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 55 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 56 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 57 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 58 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 59 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 60 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 61 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 62 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 63 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 64 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 65 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 66 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 67 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 68 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 69 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 70 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 71 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 72 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 73 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 74 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 75 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 76 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 77 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 78 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 79 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 80 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 81 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 82 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 83 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 84 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 85 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 86 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 87 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 88 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 89 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 90 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 91 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 92 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 93 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 94 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 95 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 96 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 97 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 98 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 99 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 100 (BUTTON)
   Lutron RRA2/Caséta Debug       Component: 101 (LED)
   Lutron RRA2/Caséta Debug       Component: 102 (LED)
   Lutron RRA2/Caséta Debug       Component: 103 (LED)
   Lutron RRA2/Caséta Debug       Component: 104 (LED)
   Lutron RRA2/Caséta Debug       Component: 105 (LED)
   Lutron RRA2/Caséta Debug       Component: 106 (LED)
   Lutron RRA2/Caséta Debug       Component: 107 (LED)
   Lutron RRA2/Caséta Debug       Component: 108 (LED)
   Lutron RRA2/Caséta Debug       Component: 109 (LED)
   Lutron RRA2/Caséta Debug       Component: 110 (LED)
   Lutron RRA2/Caséta Debug       Component: 111 (LED)
   Lutron RRA2/Caséta Debug       Component: 112 (LED)
   Lutron RRA2/Caséta Debug       Component: 113 (LED)
   Lutron RRA2/Caséta Debug       Component: 114 (LED)
   Lutron RRA2/Caséta Debug       Component: 115 (LED)
   Lutron RRA2/Caséta Debug       Component: 116 (LED)
   Lutron RRA2/Caséta Debug       Component: 117 (LED)
   Lutron RRA2/Caséta Debug       Component: 118 (LED)
   Lutron RRA2/Caséta Debug       Component: 119 (LED)
   Lutron RRA2/Caséta Debug       Component: 120 (LED)
   Lutron RRA2/Caséta Debug       Component: 121 (LED)
   Lutron RRA2/Caséta Debug       Component: 122 (LED)
   Lutron RRA2/Caséta Debug       Component: 123 (LED)
   Lutron RRA2/Caséta Debug       Component: 124 (LED)
   Lutron RRA2/Caséta Debug       Component: 125 (LED)
   Lutron RRA2/Caséta Debug       Component: 126 (LED)
   Lutron RRA2/Caséta Debug       Component: 127 (LED)
   Lutron RRA2/Caséta Debug       Component: 128 (LED)
   Lutron RRA2/Caséta Debug       Component: 129 (LED)
   Lutron RRA2/Caséta Debug       Component: 130 (LED)
   Lutron RRA2/Caséta Debug       Component: 131 (LED)
   Lutron RRA2/Caséta Debug       Component: 132 (LED)
   Lutron RRA2/Caséta Debug       Component: 133 (LED)
   Lutron RRA2/Caséta Debug       Component: 134 (LED)
   Lutron RRA2/Caséta Debug       Component: 135 (LED)
   Lutron RRA2/Caséta Debug       Component: 136 (LED)
   Lutron RRA2/Caséta Debug       Component: 137 (LED)
   Lutron RRA2/Caséta Debug       Component: 138 (LED)
   Lutron RRA2/Caséta Debug       Component: 139 (LED)
   Lutron RRA2/Caséta Debug       Component: 140 (LED)
   Lutron RRA2/Caséta Debug       Component: 141 (LED)
   Lutron RRA2/Caséta Debug       Component: 142 (LED)
   Lutron RRA2/Caséta Debug       Component: 143 (LED)
   Lutron RRA2/Caséta Debug       Component: 144 (LED)
   Lutron RRA2/Caséta Debug       Component: 145 (LED)
   Lutron RRA2/Caséta Debug       Component: 146 (LED)
   Lutron RRA2/Caséta Debug       Component: 147 (LED)
   Lutron RRA2/Caséta Debug       Component: 148 (LED)
   Lutron RRA2/Caséta Debug       Component: 149 (LED)
   Lutron RRA2/Caséta Debug       Component: 150 (LED)
   Lutron RRA2/Caséta Debug       Component: 151 (LED)
   Lutron RRA2/Caséta Debug       Component: 152 (LED)
   Lutron RRA2/Caséta Debug       Component: 153 (LED)
   Lutron RRA2/Caséta Debug       Component: 154 (LED)
   Lutron RRA2/Caséta Debug       Component: 155 (LED)
   Lutron RRA2/Caséta Debug       Component: 156 (LED)
   Lutron RRA2/Caséta Debug       Component: 157 (LED)
   Lutron RRA2/Caséta Debug       Component: 158 (LED)
   Lutron RRA2/Caséta Debug       Component: 159 (LED)
   Lutron RRA2/Caséta Debug       Component: 160 (LED)
   Lutron RRA2/Caséta Debug       Component: 161 (LED)
   Lutron RRA2/Caséta Debug       Component: 162 (LED)
   Lutron RRA2/Caséta Debug       Component: 163 (LED)
   Lutron RRA2/Caséta Debug       Component: 164 (LED)
   Lutron RRA2/Caséta Debug       Component: 165 (LED)
   Lutron RRA2/Caséta Debug       Component: 166 (LED)
   Lutron RRA2/Caséta Debug       Component: 167 (LED)
   Lutron RRA2/Caséta Debug       Component: 168 (LED)
   Lutron RRA2/Caséta Debug       Component: 169 (LED)
   Lutron RRA2/Caséta Debug       Component: 170 (LED)
   Lutron RRA2/Caséta Debug       Component: 171 (LED)
   Lutron RRA2/Caséta Debug       Component: 172 (LED)
   Lutron RRA2/Caséta Debug       Component: 173 (LED)
   Lutron RRA2/Caséta Debug       Component: 174 (LED)
   Lutron RRA2/Caséta Debug       Component: 175 (LED)
   Lutron RRA2/Caséta Debug       Component: 176 (LED)
   Lutron RRA2/Caséta Debug       Component: 177 (LED)
   Lutron RRA2/Caséta Debug       Component: 178 (LED)
   Lutron RRA2/Caséta Debug       Component: 179 (LED)
   Lutron RRA2/Caséta Debug       Component: 180 (LED)
   Lutron RRA2/Caséta Debug       Component: 181 (LED)
   Lutron RRA2/Caséta Debug       Component: 182 (LED)
   Lutron RRA2/Caséta Debug       Component: 183 (LED)
   Lutron RRA2/Caséta Debug       Component: 184 (LED)
   Lutron RRA2/Caséta Debug       Component: 185 (LED)
   Lutron RRA2/Caséta Debug       Component: 186 (LED)
   Lutron RRA2/Caséta Debug       Component: 187 (LED)
   Lutron RRA2/Caséta Debug       Component: 188 (LED)
   Lutron RRA2/Caséta Debug       Component: 189 (LED)
   Lutron RRA2/Caséta Debug       Component: 190 (LED)
   Lutron RRA2/Caséta Debug       Component: 191 (LED)
   Lutron RRA2/Caséta Debug       Component: 192 (LED)
   Lutron RRA2/Caséta Debug       Component: 193 (LED)
   Lutron RRA2/Caséta Debug       Component: 194 (LED)
   Lutron RRA2/Caséta Debug       Component: 195 (LED)
   Lutron RRA2/Caséta Debug       Component: 196 (LED)
   Lutron RRA2/Caséta Debug       Component: 197 (LED)
   Lutron RRA2/Caséta Debug       Component: 198 (LED)
   Lutron RRA2/Caséta Debug       Component: 199 (LED)
   Lutron RRA2/Caséta Debug       Component: 200 (LED)
   Lutron RRA2/Caséta             Finding Timeclock events...
   Lutron RRA2/Caséta             Finding HVAC devices...
   Lutron RRA2/Caséta             Creating Devices done.
Fri Jan 21, 2022 2:38 pm
Sure looks like it found the pico:
Are you sure it didn't create the devices for it? There will be four, With names something like "Family room - Family Room pico - Button 17.08"
