help for beginner with Lutron
Thu Aug 27, 2020 5:15 pm
docbjr offline
Re: help for beginner with Lutron
Sorry.. I missed that.
Aug 27, 2020 at 7:13:36 PM
   Lutron RRA2/Caséta Debug       Office - Dimmer 7 - Wall: actionControlDimmerRelay sending: '#OUTPUT,7,1,100' to gateway 106652295
   Lutron RRA2/Caséta Debug       lutron gateway 2: Sending command: '#OUTPUT,7,1,100'
   Lutron RRA2/Caséta Warning     lutron gateway 2: Error sending IP command, resetting connection:  'int' object has no attribute 'sendall'
Aug 27, 2020 at 7:13:51 PM
   Lutron RRA2/Caséta Debug       Office - Dimmer 6 - Ceiling: actionControlDimmerRelay sending: '#OUTPUT,6,1,100' to gateway 106652295
   Lutron RRA2/Caséta Debug       lutron gateway 2: Sending command: '#OUTPUT,6,1,100'
Thu Aug 27, 2020 5:17 pm
docbjr offline
Aug 27, 2020 at 7:16:52 PM
   Lutron RRA2/Caséta Debug       Office - Desk Pico - Button 009.03 - Favorite: actionControlDimmerRelay sending: '#DEVICE,9,3,3' to gateway 1052303706
   Lutron RRA2/Caséta Error       Unable to send cmd #DEVICE,9,3,3 to gateway 1052303706.  Possible disabled gateway device.
Aug 27, 2020 at 7:17:08 PM
   Lutron RRA2/Caséta Debug       Office - Desk Pico - Button 009.06 - Lower: actionControlDimmerRelay sending: '#DEVICE,9,6,3' to gateway 1052303706
   Lutron RRA2/Caséta Error       Unable to send cmd #DEVICE,9,6,3 to gateway 1052303706.  Possible disabled gateway device.
Thu Aug 27, 2020 5:47 pm
docbjr offline
Seems to me that there are 2 different addresses fir the repeater and I have no idea why or what to do about it.
Thu Aug 27, 2020 5:53 pm
Post a screenshot of the Gateway device configuration dialog.
Thu Aug 27, 2020 6:14 pm
Looks like you have at least two different gateway devices. Or you didn't delete all the Lutron devices when you created the new Gateway device. You need to delete ALL devices associated with the plugin and start over.
And those numbers are the Indigo DeviceID of the gateway device, not the address of the gateway. The address will be the IP number of the gateway, but it might not be showing properly at this time.
Thu Aug 27, 2020 6:20 pm
docbjr offline
This?
gateway config.jpg (26.28 KiB) Viewed 5756 times
Screen Shot 2020-08-27 at 8.13.17 PM.png (46.44 KiB) Viewed 5756 times
Thu Aug 27, 2020 6:22 pm
That looks right. You don't have two of them, do you? You posted two screen shots.
Restart the plugin and post the log for that.
Thu Aug 27, 2020 6:46 pm
docbjr offline
No, just 1 of them.
Aug 27, 2020 at 8:44:42 PM
Reloading plugin "Lutron RRA2/Caséta 7.3.0"
Stopping plugin "Lutron RRA2/Caséta 7.3.0" (pid 6147)
Lutron RRA2/Caséta Debug Removing Trigger Group 005 - Office Occupied (1105215616)
Lutron RRA2/Caséta Debug Removing Trigger Group 005 - Office Unoccupied (105526642)
Lutron RRA2/Caséta Debug IP stop called
Lutron RRA2/Caséta Shutting down Lutron
Stopped plugin "Lutron RRA2/Caséta 7.3.0"
Starting plugin "Lutron RRA2/Caséta 7.3.0" (pid 7146)
Lutron RRA2/Caséta Debug logLevel = 5
Started plugin "Lutron RRA2/Caséta 7.3.0"
Lutron RRA2/Caséta Starting up Lutron
Lutron RRA2/Caséta No linked Devices
Lutron RRA2/Caséta Converting to multiple gateway system
Lutron RRA2/Caséta Error Error in plugin execution startup:
File "plugin.py", line 372, in startup
KeyError: key ip_address not found in dict
Lutron RRA2/Caséta lutron gateway 2: Running IP Start
Lutron RRA2/Caséta lutron gateway 2: Connecting via IP to 192.168.200.101:23
Aug 27, 2020 at 8:45:20 PM
Lutron RRA2/Caséta Error lutron gateway 2: Unable to connect to Lutron gateway. Timed out.
Lutron RRA2/Caséta Threaddebug Starting Trigger 'Group 005 - Office Occupied', pluginProps = com.jimandnoreen.indigoplugin.lutron-radiora2 : (dict)
gateway : None (empty)
group : 106652295:Group.5 (string)
occupancyPopUp : 3 (string)
Lutron RRA2/Caséta Group 005 - Office Occupied: Added default Gateway (None)
Lutron RRA2/Caséta Debug Adding Group Trigger Group 005 - Office Occupied, group = 106652295:Group.5, gateway = None
Lutron RRA2/Caséta Threaddebug Starting Trigger 'Group 005 - Office Unoccupied', pluginProps = com.jimandnoreen.indigoplugin.lutron-radiora2 : (dict)
occupancyPopUp : 4 (string)
Lutron RRA2/Caséta Group 005 - Office Unoccupied: Added default Gateway (None)
Lutron RRA2/Caséta Debug Adding Group Trigger Group 005 - Office Unoccupied, group = 106652295:Group.5, gateway = None
Lutron RRA2/Caséta Debug Office - Dimmer 6 - Ceiling: actionControlDimmerRelay sending: '?OUTPUT,6,1,' to gateway 106652295
Lutron RRA2/Caséta Debug lutron gateway 2: Sending command: '?OUTPUT,6,1,'
Lutron RRA2/Caséta Warning lutron gateway 2: Error sending IP command, resetting connection: 'NoneType' object has no attribute 'write'
Lutron RRA2/Caséta Debug Office - Dimmer 7 - Wall: actionControlDimmerRelay sending: '?OUTPUT,7,1,' to gateway 106652295
Lutron RRA2/Caséta Debug lutron gateway 2: Sending command: '?OUTPUT,7,1,'
Lutron RRA2/Caséta Debug Phantom Button 001.001: actionControlDimmerRelay sending: '?DEVICE,1,101,9,' to gateway 1052303706
Lutron RRA2/Caséta Error Unable to send cmd ?DEVICE,1,101,9, to gateway 1052303706. Possible disabled gateway device.
Thu Aug 27, 2020 6:47 pm
Thu Aug 27, 2020 6:55 pm
docbjr offline
Aug 27, 2020 at 8:52:27 PM
Upgrading plugin Lutron RRA2/Caséta to newer version 7.3.1 (previous version moved to trash)
Loading plugin "Lutron RRA2/Caséta 7.3.1"
Starting plugin "Lutron RRA2/Caséta 7.3.1" (pid 7180)
Started plugin "Lutron RRA2/Caséta 7.3.1"
Error (client) timeout waiting for plugin response from com.jimandnoreen.indigoplugin.lutron-radiora2 for request UiGetValues1
Error (client) received unexpected packet response UiGetValues1 (waiting for CallPluginFunc)
Aug 27, 2020 at 8:53:03 PM
Lutron RRA2/Caséta Debug Office - Dimmer 6 - Ceiling: actionControlDimmerRelay sending: '#OUTPUT,6,1,0' to gateway 106652295
Lutron RRA2/Caséta Debug lutron gateway 2: Sending command: '#OUTPUT,6,1,0'
Aug 27, 2020 at 8:54:15 PM
Thu Aug 27, 2020 7:11 pm
docbjr offline
I removed the dimmers from Indigo and had the repeater create the devices again.
Aug 27, 2020 at 9:08:59 PM
Lutron RRA2/Caséta Threaddebug get_gateway_list: typeId = createAll, targetId = 0, valuesDict = UiValuesDict : (dict)
Lutron RRA2/Caséta Threaddebug menuChanged, typeId = createAll, valuesDict = UiValuesDict : (dict)
create_event_triggers : false (bool)
create_group_triggers : false (bool)
create_unused_keypad : false (bool)
create_unused_note : (string)
create_unused_phantom : false (bool)
gateway : 106652295 (string)
group_by : Type (string)
local_note : (string)
separator0 : (string)
separator1 : (string)
separator2 : (string)
use_local : false (bool)
warning_note : (string)
xmlFileName : ~/DbXmlInfo.xml (string)
Lutron RRA2/Caséta Warning Unable to create devices, no connection to repeater.
Thu Aug 27, 2020 7:15 pm
docbjr offline
Currently RA2 Essentials is saying there are no main repeaters online.
Thu Aug 27, 2020 7:17 pm
docbjr offline
Ethernet cable was loose...fixed.
Thu Aug 27, 2020 7:27 pm
docbjr offline
I removed the gateway from Indigo and re-installed it. Things are looking good.
Aug 27, 2020 at 9:20:18 PM
Lutron RRA2/Caséta Debug Office - Dimmer 6 - Ceiling: actionControlDimmerRelay sending: '#OUTPUT,6,1,100' to gateway 1558364475
Lutron RRA2/Caséta Debug new device 1: Sending command: '#OUTPUT,6,1,100'
Aug 27, 2020 at 9:21:30 PM
WebServer Indigo Touch client connected from 192.168.200.67
Aug 27, 2020 at 9:21:53 PM
Lutron RRA2/Caséta Debug Office - Dimmer 7 - Wall: actionControlDimmerRelay sending: '#OUTPUT,7,1,100' to gateway 1558364475
Lutron RRA2/Caséta Debug new device 1: Sending command: '#OUTPUT,7,1,100'
Aug 27, 2020 at 9:23:08 PM
Lutron RRA2/Caséta Debug Office - Dimmer 6 - Ceiling: actionControlDimmerRelay sending: '#OUTPUT,6,1,30' to gateway 1558364475
Lutron RRA2/Caséta Debug new device 1: Sending command: '#OUTPUT,6,1,30'
Lutron RRA2/Caséta Debug Office - Dimmer 7 - Wall: actionControlDimmerRelay sending: '#OUTPUT,7,1,36' to gateway 1558364475
Lutron RRA2/Caséta Debug new device 1: Sending command: '#OUTPUT,7,1,36'
Indigo still does not show the status of the dimmers and they do not appear on the iPhone. But there is progress!
Thu Aug 27, 2020 7:38 pm
Now I think that you need to go into Essentials and create a new Integration user with full permissions, then use that username/password in the plugin device. I had a similar problem when I upgraded to the latest version of Inclusive (12.7.0).
Users browsing this forum: Google [Bot] and 1 guest
