Unable to add Lutron Shade to Indigo Action Group
Thu May 07, 2020 2:22 pm
ryandenver offline
Greetings
I am trying to setup our Lutron Shades via Caseta hub to work with our Insteon keypads with Indigo via triggers. (Same as I've done with our Casseta dimmers). However, when trying to create am n action group for a fan, no devices appear.
I've done the following:
Confirmed the devices (shades) exist in Indigo
Action Group/new
Type: Star Shade Raising
Device: No devices listed
Am I approaching this incorrectly?
Thanks for your help
Ryan
Screen Shot 2020-05-07 at 2.21.33 PM.jpg (115.24 KiB) Viewed 2309 times
Thu May 07, 2020 3:00 pm
Re: Unable to add Lutron Shade to Indigo Action Group
Can you control the shades directly? Using the Indigo UI?
Those particular actions are new, as I recall. Not really used much. Mostly people use the "brightness" type commands to set how far to open/close the shades.
Thu May 21, 2020 11:25 am
ryandenver offline
Thanks for your help.
Question, is there an intent to activate those other commands via Indigo/Insteon Keypads? I ask as 100% open/close is working, but there are some shades that depending on the time of day or activity, need to be opened to varying degrees. Being able to press a button to start and stop the open/close motion would be perfect rather than searching for a Pico remote or phone/app.
Ryan
Thu May 21, 2020 11:44 am
I'll take a look at it. It would help if you filed a bug report on the HitHub repository so that I don't forget. ;)
Fri May 22, 2020 8:48 am
This was already fixed in my development branch, but had not gotten pushed to the released plugin yet. I'm doing a pre-release of the new version, which has the fixes in it. Read the release notes carefully.
https://github.com/FlyingDiver/Indigo-r ... /tag/7.3.0
Wed May 27, 2020 9:49 am
ryandenver offline
Perfect, again thanks for them quick responses!
