- Posted on
Wed Dec 18, 2019 5:13 pm
online
I’m assuming you actually mean the fade time field, as it’s not a rate value. That was never supposed to support fractional seconds. The old code just passed the string to the repeater, and I assume it just ignored the decimal portion. At least, the Lutron docs all show an integer value in that field. Did you actually test your values and did it actually do fractional seconds?
I made change back in June to support fade times greater than 60 seconds, and to do that I needed to convert the string to an integer. So a decimal value is going to fail.
If fractional seconds actually do work, I’ll have to change that code again. But the easiest thing would be to just make all your fade times integers.
If fractional seconds are supposed to work, please open an issue on GitHub.
