Plugin can now do auto-creation of Indigo Devices to match all defined Lutron devices.
Plugin now supports multiple main repeaters. Phantom buttons on each repeater can be used.
GHPU (GitHub Plugin Updater) has been removed.
This is BETA. Be sure you have a good backup of your Indigo database.
There's a menu command to kick off the device creation process. There's a popup list for organizing the created devices. The plugin will create folders per room (area in Lutron speak), or per device type. Or it'll put them all in the root (DEVICES) folder. The last option is not recommended.
There's a checkbox to enable creating Keypad Button and Phantom button devices for buttons that have not been programmed with any actions.
There's also a checkbox for "simulation" mode, where the plugin will log what it's doing, but not actually create any devices. Very useful for testing.
Reading the XML file from the repeater can take a while. Be patient.
Sample data for additional devices is needed. See the other thread in this forum.
