Strange trigger behavior
Tue Jan 09, 2018 2:37 pm
gt3mike offline
(Apologies if this isn't the right place to post this.)
I have a trigger set up to take an action based on a keypad button press. The ID of the keypad is 3 and the ID of the button is 7.
I see log messages such as the one below letting me know that the trigger ISN'T firing when other system events occur.
Jan 9, 2018 at 1:21:40 PM
Trigger Nest Home -> RR2 Timeclock Home
Lutron RRA2/Caséta Sending Raw Command: "#TIMECLOCK,17,1,3"
Lutron RRA2/Caséta Debug Sending network command: #TIMECLOCK,17,1,3
Lutron RRA2/Caséta Debug Received a TimeClock message: GNET> ~TIMECLOCK,17,1,3
Lutron RRA2/Caséta Debug Trigger RR2 House Off - Sonos Stop (825620404), Type: keypadButtonPress does not have eventNumber
Lutron RRA2/Caséta Debug Skipping Trigger RR2 House Off - Sonos Stop (825620404), wrong type: keypadButtonPress
Lutron RRA2/Caséta Debug Received a Device message: ~DEVICE,33,94,9,0
Lutron RRA2/Caséta Debug Received a Device message: ~DEVICE,33,95,9,1
But when I actually push the keypad button, nothing shows up in the log at all regarding the trigger
Jan 9, 2018 at 1:22:11 PM
Lutron RRA2/Caséta Debug Received a Device message: ~DEVICE,3,7,3
Lutron RRA2/Caséta Debug Received an Output message: ~OUTPUT,20,1,0.00
Lutron RRA2/Caséta Debug Received an Output message: ~OUTPUT,69,30,1,0.00
Trigger setup is below. Condition is set to "always" and Actions sends a stop to Sonos (action tested and seems to work fine).
What am I missing?
Mike
Tue Jan 09, 2018 5:47 pm
gt3mike offline
Re: Strange trigger behavior
OK, I think I figured this out. I hadn't created a device in Indigo for the keypad button I was using for the trigger. I didn't think this was necessary since the trigger dialog asked for the device and component IDs. I'll keep playing with this to make sure I'm right that it is working 100%.
If there is a doc that spells out this kind of thing, if someone can please point me to it that would be great!
Mike
Jan 9, 2018 at 4:43:19 PM
Lutron RRA2/Caséta Debug Received a keypad button/LED status message: ~DEVICE,3,7,3
Lutron RRA2/Caséta Debug Received a Keypad Button press message, checking triggers: ~DEVICE,3,7,3
Lutron RRA2/Caséta Debug Executing Trigger RR2 House Off - Sonos Stop (825620404), keypad button: 3, 7
Sonos ZonePlayer: Sonos Kitchen, Stop
Wed Mar 28, 2018 2:48 pm
7.1.0 will have a popup menu to pick which button you're monitoring, and it'll only show up on that menu if you've created the device for that button.
