Lutron Plug-In errors - required "reload"
Wed Dec 20, 2017 6:01 pm
spiv offline
Just saw this in my error log when trying to use Lutron plug-in (that had been working) with RA2 Select:
Dec 20, 2017, 3:54:20 PM
Received INSTEON "Mini Remote (Office)" on (button 3)
Trigger Mini Remote 3 Instant On (Office)
Lutron RRA2/Caséta sent "Lutron Secretary Desk Lamp (Office)" on
Lutron RRA2/Caséta Debug Sending network command: #OUTPUT,2,1,100
Lutron RRA2/Caséta Error Error in plugin execution ExecuteAction:
File "plugin.py", line 1032, in actionControlDimmerRelay
File "plugin.py", line 562, in _sendCommand
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/telnetlib.py", line 283, in write
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/socket.py", line 228, in meth
error: (32, 'Broken pipe')
I did a "reload plug-in" and it resumed working. Nothing else changed. Here is the reload info with version numbers etc:
Dec 20, 2017, 3:55:58 PM
Reloading plugin "Lutron RRA2/Caséta 7.0.5"
Stopping plugin "Lutron RRA2/Caséta 7.0.5" (pid 4464)
Lutron RRA2/Caséta Debug Deleted dimmer: 2
Lutron RRA2/Caséta Shutting down Lutron
Stopped plugin "Lutron RRA2/Caséta 7.0.5"
Starting plugin "Lutron RRA2/Caséta 7.0.5" (pid 11535)
Lutron RRA2/Caséta Debug logLevel = 10
Started plugin "Lutron RRA2/Caséta 7.0.5"
Lutron RRA2/Caséta Starting up Lutron
Lutron RRA2/Caséta Running ipStartup
Lutron RRA2/Caséta Connecting via IP to 192.168.168.132
Lutron RRA2/Caséta Debug self.connIP.read: login:
Lutron RRA2/Caséta Debug Sending username.
Lutron RRA2/Caséta Debug self.connIP.read: password:
Lutron RRA2/Caséta Debug Sending password.
Lutron RRA2/Caséta Debug End of connection process.
Lutron RRA2/Caséta Debug updateFrequency = 86400.0
Lutron RRA2/Caséta Debug Watching dimmer: 2
Lutron RRA2/Caséta Checking for updates...
Lutron RRA2/Caséta Debug Sending network command: ?OUTPUT,2,1,
Lutron RRA2/Caséta Debug Plugin version detected: 7.0.5
Lutron RRA2/Caséta Debug Sent: "Lutron Secretary Desk Lamp (Office)" False ?OUTPUT,2,1,
Lutron RRA2/Caséta Debug Current version is: 7.0.5
Lutron RRA2/Caséta Debug Getting latest release from FlyingDiver/Indigo-radiora2...
Lutron RRA2/Caséta Debug GET /repos/FlyingDiver/Indigo-radiora2/releases/latest
Lutron RRA2/Caséta Debug HTTP 200 OK
Lutron RRA2/Caséta Debug Latest release is: 7.0.5
Lutron RRA2/Caséta No updates are available
Wed Dec 20, 2017 6:53 pm
Re: Lutron Plug-In errors - required "reload"
Looks like some kind of network failure. Was there any interruption on your LAN? Or a power outage?
Wed Dec 20, 2017 11:57 pm
spiv offline
No.
I was unable to use Lutron devices until I did "reload plug-in".
Shouldn't a temporary network glitch or failure be "self-healing" in that requests should proceed the next time I try to control a device?
I don't mind an occasional failure, but having to manually reload the plug-in is not a good recovery mechanism.
On a related note, is there a simple python script I can run on a schedule to automatically reload the plug=in every 4 hours? I assume reloading when not necessary would do no harm and that would insure no "outrage" lasted longer than 4 hours?
Thu Dec 21, 2017 6:34 am
Searching the forums (box at top of page) would lead you to this: viewtopic.php?f=79&t=19199
You can file a bug report/enhancement request here: https://github.com/FlyingDiver/Indigo-radiora2/issues
Sun Jan 07, 2018 5:51 pm
gt3mike offline
Just experienced something similar. Reload fixed it. I'm unaware of any network issues. I'll log a bug report/enhancement request if it happens again.
Jan 7, 2018 at 2:51:16 PM
Trigger Nest Home - Office On
Lutron RRA2/Caséta Sending Raw Command: "#OUTPUT,69,1,50,1"
Lutron RRA2/Caséta Debug Sending network command: #OUTPUT,69,1,50,1
File "plugin.py", line 1166, in sendRawCommand
Mon Jan 08, 2018 4:24 pm
I've made a change to the code to restart the IP connection when it gets a write error. It's the latest commit on GitHub, but I have not marked it as a release yet. I want to look at attempting to re-send the command that got the error. But I need to make sure it doesn't get into a retry loop.
Mon Jan 22, 2018 3:41 pm
gt3mike offline
Just got this error again.
Jan 22, 2018 at 2:17:18 PM
Lutron RRA2/Caséta Sending: "House Off Button" off
This error happened when I turned off an Indigo RR2 Keypad Button device using the Indigo Console Client on my Mac. A reload of the plugin fixed things.
But something was wrong prior to this. The reason I was tinkering with the console was I had realized Indigo triggers weren't firing based on actual RR2 keypad button presses. There were no prior errors in the log that would account for this. So whatever stopped working behind the scenes did so silently.
Is there anything I should look for if this happens again that would help diagnose this apparently silent failure?
Mike
Mon Jan 22, 2018 4:37 pm
How often are these failures happening? It's pretty clear that something is causing the Lutron unit to drop the telnet connection to the Indigo plugin. But, unfortunately, there's no good way to tell that's happened from the plugin. Reads just return no data. A write will cause the error you see. I've published a pre-release version of the plugin that resets the connection when a failure is detected.
https://github.com/FlyingDiver/Indigo-r ... /tag/7.0.6
Mon Jan 22, 2018 4:52 pm
gt3mike offline
It's difficult to know how often it is happening because I don't have a lot of RR2 triggers yet. Is there a way to set some sort of "heartbeat" that attempts a harmless write every 15 minutes or something like that? With the current code that would at least give me log evidence when it breaks, and with your updated code it would fix itself. Just thinking out loud.
How do I install the pre-release plugin? The zip doesn't contain a .indigoPlugin file.
Mike
Mon Jan 22, 2018 4:57 pm
Huh? It contains a folder with a README and the plugin file.
Mon Jan 22, 2018 5:13 pm
gt3mike offline
My bad. I wasn't expanding the zip on my Indigo machine, so the plugin just looked like a folder.
Mon Jan 22, 2018 5:30 pm
gt3mike offline
I installed 7.0.6 and I've set a schedule to send "?TIMECLOCK,17,2" (get sunrise time) every ten minutes. I've turned on debug logging and I'll let you know if I see anything interesting.
Tue Jan 23, 2018 6:50 am
gt3mike offline
What should I be looking for in the log? If the plugin catches the error and restarts the connection, what will I see?
Thanks, Mike
Tue Jan 23, 2018 7:25 am
Thanks, Mike
There will be a very explicit warning message.
Wed Mar 28, 2018 4:58 pm
gt3mike offline
FYI this is working well. I've only noticed the message once or twice. The plugin is very reliable now. Nice work!
