Lutron plugin updated for Indigo 7
Sat Nov 19, 2016 1:32 pm
Available from https://github.com/FlyingDiver/Indigo-r ... tag/v7.0.0 or using the built-in updater (if you're already running 2.3.X)
Improved logging using new Indigo 7 logging system
New Action for setting a Lutron Dimmer type device to a specific brightness with specified Fade time
Bug fixes
Mon Jan 02, 2017 5:34 pm
mathys offline
Re: Lutron plugin updated for Indigo 7
This is amazing. Thank you so much for adding all of the support that you have. I'm particularly partial to the dimming over time command that has been added! I've been trying to figure out how to add that myself for ages. Thanks!
One quick question though, I'm not sure if it's something that I'm doing differently or if it's the new version of the plugin, but I'm not able to locate some previous functionality in the current version/Indigo 7.
When Indigo 7 released, I trashed my old setup, and upgraded from the hacked together version of this plugin that I made a year ago to work with my Smart Bridge. With my previous setup, I was able to set triggers based on button presses of Pico remotes. I found this to be extremely useful in my setup, but can no longer find this functionality.
I figured out how to speak to Pico remotes, via the "Send Raw Command" option, but I haven't figured out how to trigger via an incoming press. Any tips?
