Revised Lutron Radio Ra 2 / Caséta plugin - BETA Test
Wed Jun 15, 2016 8:18 am
https://github.com/FlyingDiver/radiora2 ... tag/v2.2.1
I've been doing some revisions to Jim's plugin, and he's graciously allowed me to post the revised version for testing purposes. It's available at the link above.
Changes:
Added BrightenBy and DimBy Indigo command support.
Added support for TimeClock and Group events and triggers
Added support for the GHPU updater system
Removed configuration option for Caseta system (not needed)
Clean up duplicate code paths and normalized processing between Serial and IP versions
Hide IP information in plugin config when using Serial communication.
This SHOULD be a drop in replacement for the current (2.0.3) version, but you know how that goes. I am only able to test IP connectivity to RRA2. I can't do serial or Caséta. So make sure you keep your current plugin handy if you want to test this version.
Wed Jun 15, 2016 8:36 am
rapamatic offline
Re: Revised Lutron Radio Ra 2 / Caséta plugin - BETA Test
I'm getting the following errors when running the plugin. The errors are probably repeated dozens of times in the log, but I've only copied the first two here. Its the exact same message repeated many times. Everything was working fine under the old code.
Started plugin "Lutron RadioRA2/Caséta 2.2.0"
  Lutron RadioRA2/Caséta Debug   startup called
  Lutron RadioRA2/Caséta Debug   Plugin version detected: 2.2.0
  Lutron RadioRA2/Caséta Debug   Current version is: 2.2.0
  Lutron RadioRA2/Caséta Debug   Getting latest release from FlyingDiver/radiora2...
  Lutron RadioRA2/Caséta Debug   GET /repos/FlyingDiver/radiora2/releases/latest
  Lutron RadioRA2/Caséta Debug   HTTP 200 OK
  Lutron RadioRA2/Caséta Debug   Latest release is: 2.1.0
  Lutron RadioRA2/Caséta Debug   Running ipStartup
  Lutron RadioRA2/Caséta Debug   Connecting via IP...
  Lutron RadioRA2/Caséta Debug   login:
  Lutron RadioRA2/Caséta Debug   Connected to panel, sending username.
  Lutron RadioRA2/Caséta Debug   password:
  Lutron RadioRA2/Caséta Debug   sending password.
  Lutron RadioRA2/Caséta Debug   end of connection process.
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 27
  Lutron RadioRA2/Caséta Debug   Watching keypad: 64 LED: 7
  Lutron RadioRA2/Caséta Debug   Watching keypad: 64 LED: 87
  Lutron RadioRA2/Caséta Debug   Watching keypad: 64 LED: 6
  Lutron RadioRA2/Caséta Debug   Watching keypad: 64 LED: 86
  Lutron RadioRA2/Caséta Debug   Watching keypad: 64 LED: 2
  Lutron RadioRA2/Caséta Debug   Watching keypad: 64 LED: 82
  Lutron RadioRA2/Caséta Debug   Watching keypad: 64 LED: 1
  Lutron RadioRA2/Caséta Debug   Watching keypad: 64 LED: 81
  Lutron RadioRA2/Caséta Debug   Watching keypad: 64 LED: 5
  Lutron RadioRA2/Caséta Debug   Watching keypad: 64 LED: 4
  Lutron RadioRA2/Caséta Debug   Watching keypad: 65 LED: 1
  Lutron RadioRA2/Caséta Debug   Watching keypad: 65 LED: 81
  Lutron RadioRA2/Caséta Debug   Watching keypad: 64 LED: 3
  Lutron RadioRA2/Caséta Debug   Watching keypad: 64 LED: 83
  Lutron RadioRA2/Caséta Debug   Watching keypad: 25 LED: 4
  Lutron RadioRA2/Caséta Debug   Watching keypad: 25 LED: 84
  Lutron RadioRA2/Caséta Debug   Watching keypad: 25 LED: 3
  Lutron RadioRA2/Caséta Debug   Watching keypad: 25 LED: 83
  Lutron RadioRA2/Caséta Debug   Watching keypad: 25 LED: 2
  Lutron RadioRA2/Caséta Debug   Watching keypad: 25 LED: 82
  Lutron RadioRA2/Caséta Debug   Watching keypad: 25 LED: 1
  Lutron RadioRA2/Caséta Debug   Watching keypad: 25 LED: 81
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 37
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 34
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 35
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 63
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 9
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 14
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 8
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 13
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 17
  Lutron RadioRA2/Caséta Debug   Watching Pico: 38 button: 4
  Lutron RadioRA2/Caséta Debug   Watching Pico: 38 button: 2
  Lutron RadioRA2/Caséta Debug   Watching Pico: 38 button: 3
  Lutron RadioRA2/Caséta Debug   Watching CCO: 41
  Lutron RadioRA2/Caséta Debug   Watching CCI: 46 input: 32
  Lutron RadioRA2/Caséta Debug   Watching CCO: 42
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 58
  Lutron RadioRA2/Caséta Debug   Watching shade: 18
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 39
  Lutron RadioRA2/Caséta Debug   Watching switch: 40
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 22
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 19
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 20
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 54
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 31
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 26
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 23
  Lutron RadioRA2/Caséta Debug   Watching keypad: 21 LED: 4
  Lutron RadioRA2/Caséta Debug   Watching keypad: 21 LED: 84
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 29
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 30
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 32
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 51
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 62
  Lutron RadioRA2/Caséta Debug   Watching shade: 61
  Lutron RadioRA2/Caséta Debug   Watching shade: 60
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 48
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 50
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 53
  Lutron RadioRA2/Caséta Debug   Watching shade: 59
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 15
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 24
  Lutron RadioRA2/Caséta Debug   Watching dimmer: 56
  Lutron RadioRA2/Caséta Debug   Watching keypad: 21 LED: 6
  Lutron RadioRA2/Caséta Debug   Watching keypad: 21 LED: 86
  Lutron RadioRA2/Caséta Debug   Watching keypad: 46 LED: 3
  Lutron RadioRA2/Caséta Debug   Watching keypad: 46 LED: 83
  Lutron RadioRA2/Caséta Debug   Watching keypad: 46 LED: 2
  Lutron RadioRA2/Caséta Debug   Watching keypad: 46 LED: 82
  Lutron RadioRA2/Caséta Error   Error in plugin execution ExecuteAction:
  File "plugin.py", line 953, in actionControlDimmerRelay
  File "plugin.py", line 485, in _sendCommand
TypeError: not enough arguments for format string
Wed Jun 15, 2016 8:43 am
rapamatic offline
Looks like a simple error in the debug logging - you try to log two string variables in the log entry, but only list one variable in the function:
         self.debugLog(u"Sending network command:  %s (%s)" % cmd)
Wed Jun 15, 2016 8:52 am
Swancoat offline
I'll give this a shot when I get home tonight.
I'm excited, even in it's initial, serial-only form, Jim's plugin was a godsend and has only gotten better since.
I know beggars can't be choosers... but if there is an option for slightly less verbose logging... that would be awesome :D
http://nerdhome.jimdo.com
Wed Jun 15, 2016 9:33 am
Debug statement fixed in v2.2.1: https://github.com/FlyingDiver/radiora2 ... tag/V2.2.1
Gotta stop tweaking debug output just before a release. :(
I know what you mean. It's cleaned up a little, but not much. Mostly I removed duplicate debug output.
I'll take a look at doing some sort of tiered logging for an upcoming release.
Wed Jun 15, 2016 10:03 am
RatRanch offline
FlyingDiver wrote:
https://github.com/FlyingDiver/radiora2/releases/tag/v2.2.0
Changes:
Joe: thanks so very much for your work on the functional enhancements and putting the codebase on GitHub. This should make collaboration and deployment of future enhancements much smoother.
All: please note that support for Pico remotes is also included in this release.
-Jim
Wed Jun 15, 2016 10:05 am
Ah, right. I didn't do that, and I forgot it wasn't in the previous public release. The Picos I ordered are on back-order, so I have not been able to test that code at all.
Wed Jun 15, 2016 5:57 pm
Swancoat offline
Ran into some trouble when I enabled this...
  Starting plugin "Lutron RadioRA2/Caséta 2.2.0" (pid 21688)
That last portion gets repeated many times, I'm assuming once for each device or something.
Wed Jun 15, 2016 6:07 pm
rapamatic offline
Looks like you have 2.2.0, update to the latest 2.2.1 which fixes this.
Wed Jun 15, 2016 7:00 pm
Swancoat offline
Ahh, I saw that but assumed the link at the top of the page just had the update. Thanks!
Wed Jun 15, 2016 7:09 pm
Swancoat offline
Ok, 2.2.1 works. My bad on that one.
There are a couple of errors that pop up when all of the device statuses load (snippet included below). Not noticing any functionality deficiency or anything though.
  Lutron RadioRA2/Caséta         Received: Dimmer Guest Bedroom Main level set to 0.00
  Lutron RadioRA2/Caséta         Received: Dimmer Kitchen level set to 50.00
  Lutron RadioRA2/Caséta Error    Unrecognized command: ~ERROR,4
  Lutron RadioRA2/Caséta         Received: Switch Laundry Room turned On
Wed Jun 15, 2016 7:24 pm
Are you RRA2 or Caseta? Serial or IP?
If can, get a debug output for that time period. Hopefully there will be more info in the debug output that will let me see what that message is about.
Thu Jun 16, 2016 7:47 am
RatRanch offline
Swancoat: this is probably because an unsupported status request is being sent to a device at startup. This could happen if a device is defined wrong in indigo. For example, if you define a Pico as a keypad everything works fine except for status request. The devices are queried in alphabetical order, so sort all your devices by name and check the one below "Dimmer Kitchen".
Cheers,
-Jim
Thu Jun 16, 2016 10:10 am
Swancoat offline
Alphabetically, the next one down is the next one you see reporting successfully in the list (Laundry Room). Nonetheless, I'll recheck its definition and I'll reload the plugin again when I get home tonight, and log and post the errors.
Thu Jun 16, 2016 3:53 pm
Swancoat offline
So here's the startup with debug code on. It looks like I have some sort of button misconfigured here...
  Lutron RadioRA2/Caséta Debug   Received an Output message: ~OUTPUT,67,1,50.00
  Lutron RadioRA2/Caséta Debug   Received a Device message: GNET> GNET> ~DEVICE,122,81,9,0
  Lutron RadioRA2/Caséta Debug   Received a Device message: ~DEVICE,122,82,9,0
  Lutron RadioRA2/Caséta Debug   Received a Device message: GNET> GNET> ~DEVICE,122,83,9,0
  Lutron RadioRA2/Caséta Debug   Received a Device message: ~DEVICE,81,86,9,0
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: ~DEVICE,81,86,9,0
  Lutron RadioRA2/Caséta Debug   8186
  Lutron RadioRA2/Caséta Debug   816
  Lutron RadioRA2/Caséta Debug   Updating button status with state of LED for keypadID 816
  Lutron RadioRA2/Caséta Debug   Received a Device message: GNET> GNET> ~DEVICE,81,86,9,0
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: GNET> GNET> ~DEVICE,81,86,9,0
  Lutron RadioRA2/Caséta Debug   Received a Device message: ~DEVICE,81,81,9,0
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: ~DEVICE,81,81,9,0
  Lutron RadioRA2/Caséta Debug   8181
  Lutron RadioRA2/Caséta Debug   811
  Lutron RadioRA2/Caséta Debug   Updating button status with state of LED for keypadID 811
  Lutron RadioRA2/Caséta Debug   Received a Device message: GNET> GNET> ~DEVICE,81,81,9,0
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: GNET> GNET> ~DEVICE,81,81,9,0
  Lutron RadioRA2/Caséta Debug   Command prompt received. Device is ready.
  Lutron RadioRA2/Caséta Debug   Received a Device message: ~DEVICE,60,85,9,0
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: ~DEVICE,60,85,9,0
  Lutron RadioRA2/Caséta Debug   Received a Device message: GNET> GNET> ~DEVICE,60,85,9,0
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: GNET> GNET> ~DEVICE,60,85,9,0
  Lutron RadioRA2/Caséta Debug   Received a Device message: ~DEVICE,60,83,9,255
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: ~DEVICE,60,83,9,255
  Lutron RadioRA2/Caséta Debug   Received a Device message: GNET> GNET> ~DEVICE,60,83,9,255
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: GNET> GNET> ~DEVICE,60,83,9,255
  Lutron RadioRA2/Caséta Debug   Received a Device message: ~DEVICE,60,84,9,0
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: ~DEVICE,60,84,9,0
  Lutron RadioRA2/Caséta Debug   Received a Device message: GNET> GNET> ~DEVICE,60,84,9,0
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: GNET> GNET> ~DEVICE,60,84,9,0
  Lutron RadioRA2/Caséta Debug   Received a Device message: ~DEVICE,60,86,9,255
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: ~DEVICE,60,86,9,255
  Lutron RadioRA2/Caséta Debug   Received a Device message: GNET> GNET> ~DEVICE,60,86,9,255
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: GNET> GNET> ~DEVICE,60,86,9,255
  Lutron RadioRA2/Caséta Debug   Received a Device message: ~DEVICE,56,84,9,0
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: ~DEVICE,56,84,9,0
  Lutron RadioRA2/Caséta Debug   5684
  Lutron RadioRA2/Caséta Debug   564
  Lutron RadioRA2/Caséta Debug   Updating button status with state of LED for keypadID 564
  Lutron RadioRA2/Caséta Debug   Received a Device message: GNET> GNET> ~DEVICE,56,84,9,0
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: GNET> GNET> ~DEVICE,56,84,9,0
  Lutron RadioRA2/Caséta Debug   Received a Device message: ~DEVICE,56,85,9,255
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: ~DEVICE,56,85,9,255
  Lutron RadioRA2/Caséta Debug   5685
  Lutron RadioRA2/Caséta Debug   565
  Lutron RadioRA2/Caséta Debug   Updating button status with state of LED for keypadID 565
  Lutron RadioRA2/Caséta Debug   Received a Device message: GNET> GNET> ~DEVICE,56,85,9,255
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: GNET> GNET> ~DEVICE,56,85,9,255
  Lutron RadioRA2/Caséta Debug   Received a Device message: ~DEVICE,56,86,9,255
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: ~DEVICE,56,86,9,255
  Lutron RadioRA2/Caséta Debug   5686
  Lutron RadioRA2/Caséta Debug   566
  Lutron RadioRA2/Caséta Debug   Updating button status with state of LED for keypadID 566
  Lutron RadioRA2/Caséta Debug   Received a Device message: GNET> GNET> ~DEVICE,56,86,9,255
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: GNET> GNET> ~DEVICE,56,86,9,255
  Lutron RadioRA2/Caséta Debug   Received a Device message: ~DEVICE,44,85,9,0
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: ~DEVICE,44,85,9,0
  Lutron RadioRA2/Caséta Debug   4485
  Lutron RadioRA2/Caséta Debug   445
  Lutron RadioRA2/Caséta Debug   Updating button status with state of LED for keypadID 445
  Lutron RadioRA2/Caséta Debug   Received a Device message: GNET> GNET> ~DEVICE,44,85,9,0
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: GNET> GNET> ~DEVICE,44,85,9,0
  Lutron RadioRA2/Caséta Debug   Received a Device message: ~DEVICE,44,84,9,0
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: ~DEVICE,44,84,9,0
  Lutron RadioRA2/Caséta Debug   4484
  Lutron RadioRA2/Caséta Debug   444
  Lutron RadioRA2/Caséta Debug   Updating button status with state of LED for keypadID 444
  Lutron RadioRA2/Caséta Debug   Received a Device message: GNET> GNET> ~DEVICE,44,84,9,0
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: GNET> GNET> ~DEVICE,44,84,9,0
  Lutron RadioRA2/Caséta Debug   Received a Device message: ~DEVICE,44,81,9,0
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: ~DEVICE,44,81,9,0
  Lutron RadioRA2/Caséta Debug   4481
  Lutron RadioRA2/Caséta Debug   441
  Lutron RadioRA2/Caséta Debug   Updating button status with state of LED for keypadID 441
  Lutron RadioRA2/Caséta Debug   Received a Device message: GNET> GNET> ~DEVICE,44,81,9,0
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: GNET> GNET> ~DEVICE,44,81,9,0
  Lutron RadioRA2/Caséta Debug   Received a Device message: ~DEVICE,44,82,9,0
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: ~DEVICE,44,82,9,0
  Lutron RadioRA2/Caséta Debug   4482
  Lutron RadioRA2/Caséta Debug   442
  Lutron RadioRA2/Caséta Debug   Updating button status with state of LED for keypadID 442
  Lutron RadioRA2/Caséta Debug   Received a Device message: GNET> GNET> ~DEVICE,44,83,9,0
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: GNET> GNET> ~DEVICE,44,83,9,0
  Lutron RadioRA2/Caséta Debug   4483
  Lutron RadioRA2/Caséta Debug   443
  Lutron RadioRA2/Caséta Debug   Updating button status with state of LED for keypadID 443
  Lutron RadioRA2/Caséta Debug   Received a Device message: ~DEVICE,44,83,9,0
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: ~DEVICE,44,83,9,0
  Lutron RadioRA2/Caséta Debug   Received a Device message: GNET> GNET> ~DEVICE,44,82,9,0
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: GNET> GNET> ~DEVICE,44,82,9,0
  Lutron RadioRA2/Caséta Debug   Received a Device message: ~DEVICE,44,86,9,1
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: ~DEVICE,44,86,9,1
  Lutron RadioRA2/Caséta Debug   4486
  Lutron RadioRA2/Caséta Debug   446
  Lutron RadioRA2/Caséta Debug   Updating button status with state of LED for keypadID 446
  Lutron RadioRA2/Caséta Debug   Set status to True on Server.
  Lutron RadioRA2/Caséta Debug   Received a Device message: GNET> GNET> ~DEVICE,44,86,9,1
  Lutron RadioRA2/Caséta Debug   Received a keypad button/LED status message: GNET> GNET> ~DEVICE,44,86,9,1
  Lutron RadioRA2/Caséta Debug   Received a Device message: ~DEVICE,1,101,9,0
  Lutron RadioRA2/Caséta Debug   Received a phantom button status message: ~DEVICE,1,101,9,0
  Lutron RadioRA2/Caséta Debug   Received a Device message: GNET> GNET> ~DEVICE,1,131,9,0
  Lutron RadioRA2/Caséta Debug   Received a phantom button status message: GNET> GNET> ~DEVICE,1,131,9,0
  Lutron RadioRA2/Caséta Debug   Received a Device message: ~DEVICE,1,130,9,0
  Lutron RadioRA2/Caséta Debug   Received a phantom button status message: ~DEVICE,1,130,9,0
  Lutron RadioRA2/Caséta Debug   Received a Device message: GNET> GNET> ~DEVICE,1,115,9,0
  Lutron RadioRA2/Caséta Debug   Received a phantom button status message: GNET> GNET> ~DEVICE,1,115,9,0
  Lutron RadioRA2/Caséta Debug   Received a Device message: ~DEVICE,1,111,9,1
  Lutron RadioRA2/Caséta Debug   Received a phantom button status message: ~DEVICE,1,111,9,1
  Lutron RadioRA2/Caséta Debug   Received a Device message: GNET> GNET> ~DEVICE,1,110,9,0
  Lutron RadioRA2/Caséta Debug   Received a phantom button status message: GNET> GNET> ~DEVICE,1,110,9,0
  Lutron RadioRA2/Caséta Debug   Received an Output message: GNET> GNET> ~OUTPUT,63,1,0.00
  Lutron RadioRA2/Caséta         Received: Switch Laundry Room turned Off
  Lutron RadioRA2/Caséta Debug   Received an Output message: ~OUTPUT,112,1,0.00
  Lutron RadioRA2/Caséta         Received: Switch Laundry Room Fan turned Off
