UPS and Battery Plugin updated
Mon Nov 06, 2023 1:08 pm
There's a Python3 version of the plugin now available in the plugin store.
https://www.indigodomo.com/pluginstore/108/
Mon Nov 06, 2023 1:12 pm
Korey offline
Re: UPS and Battery Plugin updated
Thanks Joe!!!
Korey
Mon Nov 06, 2023 3:58 pm
WagnerOne offline
Excellent. Thanks!
Wed Apr 03, 2024 10:34 am
slackman1 offline
Hi Joe,
Thank you for building this plugin, however, I have a 'false positive' problem with the plugin.
Once, twice a day the plugin thinks the UPS does not have a battery, thus triggering. UPS model is CyberPower VP1600ELCD, connected through usb.
Plugin is the 2023.0.0, is there some kind of debug setting or extra log option that I can turn on to find out more than the below?
Triggers and debug messages are mine of course.
2024-04-03 17:55:22.612   UPS and Battery Monitor      Power Status    - AC Power - No Battery
2024-04-03 17:55:22.612   UPS and Battery Monitor      UPS Model       - No Battery or UPS
2024-04-03 17:55:22.612   UPS and Battery Monitor      Charging Status - False
2024-04-03 17:55:22.612   UPS and Battery Monitor      Battery Charge  - 00
2024-04-03 17:55:22.612   UPS and Battery Monitor   Refreshing in 1 Minutes
2024-04-03 17:55:22.616   Trigger   Indigo UPS battery level < 30%
2024-04-03 17:55:22.616   Trigger   UPS power status change!!!
2024-04-03 17:55:22.617   Trigger   UPS on battery!!!
2024-04-03 17:55:22.617   Trigger   Indigo UPS change!
2024-04-03 17:55:22.617   debug   UPS change!!!
2024-04-03 17:55:22.617   debug   UPS on battery
Thank you for any suggestions or advice.
Kind regards, Gerrit Jan
Wed Apr 03, 2024 10:53 am
That response is what the plugin reports when it gets an error polling the OS for the battery status (command line "pmset -g batt"). That's kinda a bogus way to do the error reporting, but I didn't originally write this and I never changed it.
Open an issue in the GitHub repo for this plugin and I'll see if I can figure out a better way to do the error reporting.
