Bond Home Plugin
Sun Oct 08, 2023 11:44 am
Re: Bond Home Plugin
Might have been a change in the Bond API that I missed. Delete the device. Turn on debug logging, restart the plugin, and recreate the device. Then open an issue on GitHub and post the log there.
Also do the "Write Device Information to log" menu command and put that in the GitHub issue.
Sat Oct 14, 2023 10:29 am
Release 2022.1.4 now available, plugin store or https://github.com/FlyingDiver/Indigo-B ... g/2022.1.4
This release fixes the issues with push updates from the Bond device. Indigo device states should now match the states as represented in the Bond app.
Sat Oct 14, 2023 5:06 pm
wow if this does what I think it does, that's HUGE! Thanks very much!
Sat Oct 14, 2023 6:04 pm
It works for all the devices I tested with, so I'm happy.
Sun Oct 15, 2023 9:02 am
On first test, it doesn’t seem to work with my exceptionally stupid fans, which don’t really have On/Off, just toggle. (And by work, I mean correctly track the fan’s state.)
But I’ll keep experimenting to make sure.
Sun Oct 15, 2023 9:04 am
Yeah, that's a problem. Turn on debug logging, send a command, then post the log segment so I can see what the Bond is reporting back to the plugin. Maybe there's something there useful.
Sun Oct 15, 2023 9:32 am
I'll get the logs, but my intuition tells me that the fan itself doesn't actually report to the Bond bridge. I think it just accepts commands.
I'll test this theory by watching the Bond app to see if it notices changes to the fan done by the stock fan controller. These fans are over ten years old.
